Old 03-08-2015, 09:11 PM   #253
steve99
Any insight?
Seeing some FLKC/Knock correction.
Most recent OFT EL stage 2 map with Ptuning EL header.
http://datazap.me/u/andrew025/log-14...0&data=1-12-13
Pretty minor knock
IAM drops a bit to 0.8
If your concerned pull about -1.0 out of "Base Timing B" table from
RPM 2400 to 3600
Loads 0.7 to 1.4
Andrew025 (03-08-2015)
Old 03-09-2015, 03:04 AM   #254
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
Please have a look at the datalogs of this car.
The marked is 3 consecutive 3 rd gear pulls from 2500 rpm to 7200 rpm.
Datazap:
http://datazap.me/u/johanp/deef-86-u...?log=0&data=20
I'd really appreciate some feedback as this will determine where my money goes @Dammod @DeliciousTuning @steve99
GeeTee86 is offline   Reply With Quote
The Following 2 Users Say Thank You to GeeTee86 For This Useful Post:
Freedom (03-09-2015), Vic_RSA (03-09-2015)
Old 03-09-2015, 03:28 AM   #255
phrosty
Datazap:
Looks quite good.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
GeeTee86 (03-09-2015)
Old 03-09-2015, 05:12 AM   #256
steve99
Datazap:
Ok here is what I think - I'm probably biased though :-)
Running 95 Ron fuel and AEM intake from memory
IAM = 1 good
Negligible FBKC/FLCK knock couple of little spikes less than -0.7
LTFT 5% or less maf scaling good CL
AFR and Commanded AFR following each other closely under load OL Maf good
It a pretty warm day IAT=30C
looks fine, how it will go horsepower wise will be interesting but looks pretty safe to me.
The Following 3 Users Say Thank You to steve99 For This Useful Post:
Freedom (03-10-2015), GeeTee86 (03-09-2015), sav (03-09-2015)
Old 03-09-2015, 05:22 AM   #257
GeeTee86
86 Nut
GeeTee86's Avatar
Thanks mate, the owner will apparently dyno this week sometime, so lets wait and see.
Old 03-09-2015, 04:06 PM   #258
JB86'd
JB86'd's Avatar
Drives: JAWS
new datalog with my exhaust leak fixed. Stage 2 91 octane, drop in filter and OFH.
1-3rd pull, 3rd gear pull, and a bit of normal driving. How does my AFR look?
http://datazap.me/u/joshbustos86/206...4-7-9-12-13-14
here's a datalog from when I had the exhaust leak for comparison..you can see instances of high LT fuel trims of up to 10%..
http://datazap.me/u/joshbustos86/206...a=1-4-7-8-9-12
@ap5512 @Phantobe @steve99
The Following User Says Thank You to JB86'd For This Useful Post:
Phantobe (03-11-2015)
Old 03-09-2015, 04:57 PM   #259
phrosty
You're running rich.
Old 03-09-2015, 05:23 PM   #260
JB86'd
JB86'd's Avatar
Drives: JAWS
I thought I might be..seeing 11.25. Any ideas as to why I'm running rich? Maybe just the tune?
Old 03-09-2015, 07:03 PM   #261
phrosty
If you've been driving around with an exhaust leak prior to this, your fuel trims might need some time to adjust. Have you reset your ECU? Otherwise maybe still a leak? Dunno.
Old 03-09-2015, 07:53 PM   #262
JB86'd
JB86'd's Avatar
Drives: JAWS
I've since flashed a tune with some timing pulled (.35-1 degree) after fixing my exhaust leak. I'd say I've put 50 miles on this recent flash..maybe just needs a bit more time..idk.
@Shiv@Openflash any input here?
Old 03-09-2015, 08:10 PM   #263
Bergen23
Drives: '15 Halo FR-S
http://www.datazap.me/u/colekmiecik/...s1?log=0&data=
Literally no idea what I'm looking at. Can someone give me some pointers at what I should be fixing?
Bergen23 is offline   Reply With Quote
Old 03-09-2015, 08:37 PM   #264
JB86'd
JB86'd's Avatar
Drives: JAWS
Something is wrong with your logging, you may need to update your OFT with the latest template file downloaded from the openflash site. Also forget about logging MAP and 02s2 voltage, you need to log engine speed and engine load instead.
Old 03-09-2015, 08:45 PM   #265
Bergen23
Cheers.
I updated everything today, right before I started logging. Before I couldn't even get into the logging menu. Everything (at least to my knowledge) is the most current version I could find.
Old 03-09-2015, 08:53 PM   #266
JB86'd
JB86'd's Avatar
Drives: JAWS
Cheers.
You're updated here?
Reason I ask is because your FLKC is wacky
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
