#253 |
Drives: RHD Gt86
This info was taken from a uk forum by a guest, or I would have stated his name
Quote "The Turbo FA20 engine uses a 14mm wide gear set, whereas our NA engines use 12mm wide gears. (The FA20 gears run directly in the front cover.)To use the Turbo gear set, you also need the turbo engines front cover, which has different Cam pulleys on the exhaust, so is not a straight swap item"
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
#254 |
Drives: 2JZ FRS
I don't think anyone has broken an oem one yet. Motor is already torn down and parts are being organized for sale. We have spent enough time rolling the dice and trying new things, time to make power with less mystery and headache. When it's all said and done after this winter we should have a high 8, low 9 second consistent car that I can drive on the street with no issues
| The Following 4 Users Say Thank You to spitfire481 For This Useful Post: |
#255 |
Drives: RHD Gt86
Well.... Thanks for allowing us to experience this build, felt like I was in heaven for a moment or two
#256 | |
Drives: 2JZ FRS
| The Following User Says Thank You to spitfire481 For This Useful Post: | Kris86 (07-19-2016) |
#257 |
Drives: Asphalt frs
Sent from my SM-G935T using Tapatalk |
#258 |
Drives: 2013 Asphalt FRS
DUDE, IM SO SORRY TO HEAR THIS!!!!!!!!!
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
| The Following User Says Thank You to FRS Justin For This Useful Post: | spitfire481 (07-20-2016) |
#259 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
Sucks to see, but looking forward to what comes out of it
#260 |
Drives: 2JZ FRS
breaking the rest of the motor down tonight. parts that are for sale are:
engine/turbo: darton sleeved bare block with arp main bolts (stock bore still) stock ported heads with ferrea comp valves, ferrea dual springs with retainers manley turbo tuff rods with arp 625 hardware je 9.5 pistons with their largest wrist pins custom L19 head studs full blown intake manifold FIC 1650 injectors with plug and play (dyno only, maxed them out) full blown fa20 fuel rails (no lines) full blown t4 turbo manifold trans: tremec tko600 with faceplated and heat treated gears custom fa20 to tko bellhousing custom 4 puck single disk clutch/flywheel/pressure plate custom clutch master twin disk clutch (waiting on updated flywheel from CM) custom clutch fork/TO bearing setup, as well as tilton hydraulic TO setup DSS aluminum driveshaft with chromoly tremec yoke custom shifter assembly, oem location with minimal trimming involved cross member with poly mount (have to drill 6 holes for install) DSS stage 2 axles are being rebuilt by DSS, once they get back they are for sale as well since i have the 1000hp setup now
| The Following 3 Users Say Thank You to spitfire481 For This Useful Post: |
#261 |
Drives: Toyota GT86
I'll take the FBM intake manifold. Check your PM
#262 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
What a bummer. Are you staying with the same chassis just a different motorset (EJ, LS, 2JZ, etc)?
If you're parting ways with the wheels, I'd be interested to know. I'm in the market for some 15'' drag wheels.
#263 |
Project Shadow
Drives: 2015 BRZ Limited 6MT
| The Following User Says Thank You to Drakiv For This Useful Post: | Kris86 (07-20-2016) |
#264 |
Drives: 2JZ FRS
we have so many 2J parts laying around it will probably be that. not sure if id part with them or not, they are a great street setup and wont be cheap since they are one off and fully forged
#265 |
Fair enough. Hope you go the 2J route - especially since you guys know what you're doing and can probably put it together relatively quick. Good luck man, total bummer on the FA20 though.
#266 |
Drives: 2JZ FRS
It won't be done and ready until next spring. I have a pretty hefty parts list of what I want to hit my goals. Car will still be on motec m150 so all of the oem functions will work no problem
| The Following 2 Users Say Thank You to spitfire481 For This Useful Post: | slicktop (07-20-2016), Sportsguy83 (08-03-2016) |
| God's Build | GodSays | Member's Car Journals | 13 | 04-17-2013 01:31 PM |
| My build... well some of it | cruzinbill | Electronics | Audio | NAV | Infotainment | 41 | 04-01-2013 04:02 PM |
| STX build | Evil86 | Tracking / Autocross / HPDE / Drifting | 2 | 01-08-2013 03:40 PM |
| My BRZ build | brztj | Mid-Atlantic | 3 | 09-08-2012 05:52 PM |
