Old 04-22-2013, 12:24 PM   #253
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
It's red??
I thought it was orange all this time! Lol.
Definitely getting this now.
Carlitoz3 is offline   Reply With Quote
Old 04-22-2013, 12:41 PM   #254
acro
Drives: GT-86
Originally Posted by tripjammer View Post
I will be able to do it, already got a ecutek tune, and getting the TRD intake sometime this week.
We eagerly await
acro is offline   Reply With Quote
Old 04-22-2013, 12:43 PM   #255
BRZ FTW
Drives: 2017 Subaru BRZ
Solid gains, nice! No offense to Perrin, but I think this is a far better option then having to remove your bumper to service the air filter. Hopefully there will be an STI branded one soon.
BRZ FTW is offline   Reply With Quote
Old 04-22-2013, 12:43 PM   #256
OrbitalEllipses
Drives: Attitude
Originally Posted by Carlitoz3 View Post
It's red??
Probably just the white balance or some other setting on the camera that took the picture.
Old 04-22-2013, 12:49 PM   #257
vtmike
vtmike's Avatar
Drives: Scion FR-S
Originally Posted by Jeff86 View Post
Thanks @Thorpedo for the job you did producing very useful results. Great intake since it produced very nice gains and did so without losing power anywhere.
For those saying tuning is going to remove the gain, that's not a worry. What these results demonstrate is that it flowed better than the stock box. That is what you want. The engine is a big pump. The more air you get flowing through it, the more power you can make. Tuning will make sure that the air/fuel mixture is correct and further improve the operation of the car. If you're going lean that demonstrates you are flowing more air in. Adding fuel with proper tuning is not going to remove the benefit of the additional air. This is a very solid choice for NA no matter who made it.
I'm not trying to say it doesn't flow better than the stock box but is inconclusive if based solely on a dyno that doesn't show af ratios.
I hope the gains are legitimately from an improved design and not maf manipulation. Even if it is from maf manipulation it still may be a good option for those who don't want a tune.
For those who say oem intakes don't mess with the maf sensor, check out the oem mazdaspeed3 intake they were selling through the dealers.
Sent from my Nexus 7 using Tapatalk HD
vtmike is offline   Reply With Quote
Old 04-22-2013, 12:58 PM   #258
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
I can make a WOT run and log the A/F with Torque, would this help?
Thorpedo is offline   Reply With Quote
Old 04-22-2013, 01:01 PM   #259
Thorpedo
The SquadWhisperer
On another note, what was the point in moving my thread? Having a legitimate piece of info in its own thread with a proper title that is easily searchable (given it was the first post) makes a LOT more sense than jamming it into the end of a wishy washy thread that is all over the place. Reducing the thread number by one isn't worth the hassle imo..
Old 04-22-2013, 01:05 PM   #260
Hanakuso
I think it's because you posted in the wrong section.
Hanakuso is offline   Reply With Quote
Old 04-22-2013, 01:30 PM   #261
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Was Mazda's intake CARB-approved and does it maintain factory warranty?
Old 04-22-2013, 01:41 PM   #262
OrbitalEllipses
Drives: Attitude
This. Then when moved, why have two threads? Consolidate into one master thread. This one has two dynos. One with A/F and one without A/F, but with baseline.
Old 04-22-2013, 01:51 PM   #263
vtmike
vtmike's Avatar
Drives: Scion FR-S
"This isn’t about specifications or numbers but a cultural phenomenon."
-Moto-P
I'm not sure if it was or not.
Might be helpful if the dynos are added to the op.
Doesn't the dyno with the baseline show a significant bump in torque at the first torque peak prior to the sag? This seems like an indication of the af ratio being manipulated because most gains in an intake due to volumetric efficiency occur higher in the power band.
Old 04-22-2013, 02:14 PM   #264
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
It's a big open box with a big ass filter in it and no electronics. It isn't manipulating anything. This is nonsense.
Jeff86 is offline   Reply With Quote
Old 04-22-2013, 02:17 PM   #265
bdub85
bdub85's Avatar
Drives: 2013 Raven FR-S
I would say that of anyone TRD would be the most conscious of designing an intake to work properly with the stock MAF sensor.
bdub85 is offline   Reply With Quote
The Following User Says Thank You to bdub85 For This Useful Post:
yamsta (04-29-2013)
Old 04-22-2013, 02:19 PM   #266
BRZ FTW
If I read Perrin's tech articles correctly, the way companies manipulate the MAF is by using a larger or smaller than stock MAF housing. If OP could measure the MAF housings on both, this will answer your question.
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
