Old 07-30-2013, 05:11 PM   #253
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
I have an autox this weekend. I'll keep track of oil temps and post the results.
mtimney is offline   Reply With Quote
Old 08-04-2013, 06:37 PM   #254
mtimney
mtimney's Avatar
I just got back from an SCCA autox. The laminova cooler worked perfectly. The oil peaked at 211-degrees(f) a couple of times and then went back down to 202 when I got back to the paddock.
Given this is the temp of the oil after it's been cooled by the radiator, I'm reasonably certain the oil is getting hot enough to boil off any water contamination.
Additionally, the coolant temp never went above 200....and it only hit this temp when I came back to get in line for another run and left the car running for a few minutes at a standstill.
I think this is a great setup for a DD and for autox.
Old 08-04-2013, 09:15 PM   #255
defylogik
Track Junkie
Drives: White FR-S
I was going to wait for data (car only has 500 miles on it) but i ended up putting the Mishimoto oil cooler kit on my FR-S.
I can't give any data at this point, but the kit is really nice quality.
I'm not a Mishimoto fan boy (their radiators seem to leak like sieves), but the quality on the cooler/lines/plate is just as good as Mocal. Actually the cooler looks almost identical to the Mocal one I had on my STi. Except for the sticker on top of course.
Install is fairly easy and clean, and i like the centered position. It doesn't have a thermostatic sandwich plate - so keep that in mind if you live in very cold climates. I prefer not having one... make it a lot easier to check the oil, since it doesn't change in the pan dramatically like it does with a thermostatic plate (my experience). I would have preferred to build my own custom fit kit, but the price of this one (and the great sandwich plate adapters) swayed me.
I'll definitely be logging the next time out with the car and will report back.
-Scott
defylogik is offline   Reply With Quote
Old 08-12-2013, 06:28 PM   #256
MotorboatinSonOfA
MotorboatinSonOfA's Avatar
Drives: 2013 Scion FR-S - Raven MT
I'm not sure if this has been asked in this topic already as I only found a short number of posts talking about autocross / auto-x in this topic but is an oil cooler absolutely necessary for autocrossing about 2x a month?
To give you more detail, for the competition (time recorded) runs, there would probably be about 3 or 4 runs with breaks in between each run (because you have to wait about 5 minutes for everyone in your run group to go after each one of your runs)
After about a 20-30 minute break in which no cars are running, there might be 4-6 extra runs but these wouldn't have more than about 2 minutes between each run.
MotorboatinSonOfA is offline   Reply With Quote
Old 08-13-2013, 11:07 AM   #257
mtimney
mtimney's Avatar
I don't think it is absolutely necessary. Adding one might protect your engine a little more, give you a tiny bit more power, and allow you to use oil a little longer, but you could get away without it for autocross given the oil temps I was getting before I added my cooler.
Old 08-13-2013, 11:14 AM   #258
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I've got to be completely honest. I can't fathom any autox course putting a thermal strain on the FRZ. You're talking about roughly a minute on course and less than that at full throttle.
A 20 min road course session that consists of keeping the revs about 5k the entire time? Yes.
If I was just autox'ing I wouldn't bother.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 08-13-2013, 11:59 AM   #259
robispec
Drives: Black frs project
whatever oil cooler you want you may like our take off plate.
drilled for sensors too
no thermostatic option available.
robispec is offline   Reply With Quote
Old 08-13-2013, 02:07 PM   #260
Chad
Chad's Avatar
Drives: FR-S Whiteout
I'm going to be doing auto slalom about several times a year in the summer and I didn't think an oil cooler would be necessary?
My car is a DD and our winters are harsh. I would assume that it's bad to have an oil cooler in winter (ie sub -10C)?
Chad is offline   Reply With Quote
Old 08-13-2013, 03:06 PM   #261
wootwoot
Drives: FRS
Can someone explain to me what I am looking at here?
wootwoot is offline   Reply With Quote
Old 08-13-2013, 05:40 PM   #262
orthojoe
Totally agree with you, but people are going to buy a cooler and throw it on anyway. Some will do it and not even autocross just 'because' or 'just in case'.
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 08-13-2013, 08:24 PM   #263
SkullWorks
Drives: SSM LT MT BRZ
you are looking at a "sandwich plate" that was actually designed to work in your engine bay, Robi and I both saw the need for a part that would work for everyone, and he bribed me with enough redbull to get some parts in time for his latest batch of oil cooler/radiators.
SkullWorks is offline   Reply With Quote
Old 08-13-2013, 08:27 PM   #264
mtimney
mtimney's Avatar
You're seeing is an 'oil cooler sandwich plate'....a piece that fits between the engine and the oil filter so you can run oil out through lines to get to an oil cooler.
What's nice about this...at least I think it's this way...please chime in Robbie!!...is that it also serves as a spacer.' Most oil sandwich plates are more horizontal in design and will not fit on a BRZ/FRS without having a spacer between them and the car to get them high enough above the engine so the oil connectors will fit above the rim of the 'oil catch' that's under the filter. Spacers work, but they also allow for the possibility of leaking.
Additionally, many oil sandwich plates do not have a hole in them for a sensor...like an oil pressure or temp. sensor. This one does.
Nice design! I wish it had come out before I did my cooler.
Old 08-16-2013, 12:38 PM   #265
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
My cooler started leaking tonight.. the core itself. Need to look into it tomorrow. Fun times.
Did you get that fixed yet?
Old 08-18-2013, 06:22 AM   #266
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
At Roebling this weekend with overcast skies and intermittent rain. Oil temps ran 260 to 270 without a cooler. I have the Robi special in the garage that will be installed before any more track weekends.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
