Old 04-29-2014, 09:03 AM   #253
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
I search for these part number on Amayama. And I found all of them.
However, it shows"cover, plastic"on these item? They are leather correct?
Anyone has any idea?
Door Panel Knee Pads:
(LH) SU003-04437
(RH) SU003-04436
Centre Console Knee Pads:
(LH) SU003-01920
(RH) SU003-01919
Speaker Grilles:
(LH) SU003-04433
(RH) SU003-04432
Speaker Grille Trim Rings:
(LH) SU003-03287
(RH) SU003-03286
6 X Speaker Grille Screws (Required for Installation of Pads):
SU003-02917 (x6)
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 04-30-2014, 10:09 AM   #254
Chaetagnath
Drives: Whiteout FRS
(LH) SU003-04437
(RH) SU003-04436
(LH) SU003-01920
(RH) SU003-01919
Speaker Grilles:
(LH) SU003-04433
(RH) SU003-04432
(LH) SU003-03287
(RH) SU003-03286
SU003-02917 (x6)
Yep, those are correct if you want the red trim items. They are the same material as what covers the armrests on the doors (I'm not sure if that is real leather, but it looks like leather).
Chaetagnath is offline   Reply With Quote
Old 04-30-2014, 10:30 AM   #255
Figo
Figo's Avatar
Thank you. seems like they are the correct one and the one that people in this thread look for. I think they are real leather.
Old 05-09-2014, 12:01 PM   #256
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Originally Posted by Trojan_SC View Post
Note: You will need 3 more screws per door to properly secure the speaker grill to the kneepad/door panel. (Part Number: SU003-02917)
May I ask which are the exact positions as to where the 3 more screws would go into holding the new speaking grill and silver trim ring? I'm looking at the door assembly diagram and could only identify the top 2 screw holes, which is the 3rd extra one?
I ordered all the parts, thinking I should let the dealer install them for me. I just want to screw together as much bits as I can before giving the stuff to the dealer.
Thanks!
krayzie is offline   Reply With Quote
Old 05-09-2014, 12:31 PM   #257
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Thanks!
Do it yourself! It's so easy! You'll kick yourself once you get it disassembled. Unless you just don't have time, but otherwise I'm willing to exchange numbers and walk you through it since I need to put on my tS black knee pad console garnishes anyways, which requires doing the same steps as here. It'll be maybe my fourth time taking that area apart.
Old 05-09-2014, 02:42 PM   #258
krayzie
Drive From Home
krayzie's Avatar
Okay thanks so much I'll PM you once I get all the parts. Waiting for them to come from Japan.
I plan to do the center console knee pads first. I was originally going to let the dealer do this too but I figured I should try this myself (had a really bad experience messing up the center console cupholder install with the Golf so now I'm soured).
Old 05-09-2014, 05:09 PM   #259
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Yeah, door is super easy and center console isn't too tricky. Just kinda... ballsy, at first. After the first time you'll puff out your chest and beat it as you gain Man Powers.
Old 05-12-2014, 12:18 PM   #260
krayzie
Drive From Home
krayzie's Avatar
Okay so knowing that my knee pads are coming in the mail today, I decided to pull the center console last night. The only tricky part is still that start button / cigarette box cubby (the center upper tab is wearing already on its 2nd ever pull). Otherwise everything else was quite simple (it helps when you have an old trusty plastic trim tool).
I'm still worried about the doors, especially with the locking cables, are the cable ends just hooks?
I found a door removal DIY that seems to be more detailed here:
http://www.ft86club.com/forums/showthread.php?t=27471
Old 05-12-2014, 01:13 PM   #261
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Congrats! Yeah, if you can deal with the center console, the doors are 10x easier. Just three screws, a tab, and pull up on the ball-mounted cables for the locks. Also unhook the puddle lights at the bottom and door switches. Voila!
Old 05-12-2014, 01:18 PM   #262
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
I don't recommend disconnecting the cables. Once the door panel is off, the entire handle assembly is removed with 2 screws and the cables remain attached to the handle assembly.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 05-14-2014, 11:28 AM   #263
krayzie
Drive From Home
krayzie's Avatar
Okay so I managed to get the handle trims off this morning (not as easy as I thought but no scratches thanks to trim tool). Now my question is with the door cables. The Subaru technical manual says to release the cables instead of unscrewing the inside handle assembly first.
I'll try and pull the door cards later in the day.
Are the cables hard to release / and put back on? How do the ball joints get held in place? Sorry for the stupid questions.
Old 05-14-2014, 12:09 PM   #264
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
No such thing as a stupid question my friend! Look at this picture.
Lift the colored sheaths out of their placement and pull the metal ends out and you're good! Cables released! When putting back on, put the metal ends in first, then click in the colored sheaths. Make sure they click or are at least held firmly in place.
Old 05-14-2014, 12:43 PM   #265
zdr93523
zdr93523's Avatar
Or you can just remove the 2 screws in the pic holding the handle to the door card and not even mess with the cables.
Sent from my LG-D800 using Tapatalk
www.makesmodels.com
www.camautomag.com
Old 05-14-2014, 01:10 PM   #266
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
I found the releasing of the cables to be much quicker.
Toyota Japan 86, FRS, Air Bag, Frameless Mirror, Knee Pad, Sun Visor, Door sill, MOR nigel-jdmparts Interior Parts (Incl. Lighting) 89 02-01-2013 04:00 PM
HID Retrofit Kit install Jidonsu NY / NJ / CT / PA 1 08-04-2012 01:24 AM
How do you install the mud guards? Moshpit37 Scion FR-S / Toyota 86 GT86 General Forum 11 07-27-2012 11:13 PM
FS: console knee foam pads 86_ZN6 Interior Parts (Incl. Lighting) 9 07-21-2012 09:46 AM
Spoiler Install CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 1 07-07-2012 10:43 AM
