#253 |
Drives: Vortech Supercharged FR-S
I search for these part number on Amayama. And I found all of them.
However, it shows"cover, plastic"on these item? They are leather correct? Anyone has any idea? ----------------- Door Panel Knee Pads: (LH) SU003-04437 (RH) SU003-04436 Centre Console Knee Pads: (LH) SU003-01920 (RH) SU003-01919 Speaker Grilles: (LH) SU003-04433 (RH) SU003-04432 Speaker Grille Trim Rings: (LH) SU003-03287 (RH) SU003-03286 6 X Speaker Grille Screws (Required for Installation of Pads): SU003-02917 (x6)
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
#254 | |
Drives: Whiteout FRS
Yep, those are correct if you want the red trim items. They are the same material as what covers the armrests on the doors (I'm not sure if that is real leather, but it looks like leather). |
#255 |
Thank you. seems like they are the correct one and the one that people in this thread look for. I think they are real leather.
#256 | |
Drive From Home
Drives: BRZ STI Performance
I ordered all the parts, thinking I should let the dealer install them for me. I just want to screw together as much bits as I can before giving the stuff to the dealer. Thanks! |
#257 | |
Snow Don't Hurt!
| The Following User Says Thank You to chanomatik For This Useful Post: | krayzie (05-09-2014) |
#258 | |
Drive From Home
I plan to do the center console knee pads first. I was originally going to let the dealer do this too but I figured I should try this myself (had a really bad experience messing up the center console cupholder install with the Golf so now I'm soured).
| The Following User Says Thank You to krayzie For This Useful Post: | chanomatik (05-09-2014) |
#259 | |
Snow Don't Hurt!
#260 | |
Drive From Home
I'm still worried about the doors, especially with the locking cables, are the cable ends just hooks? I found a door removal DIY that seems to be more detailed here: http://www.ft86club.com/forums/showthread.php?t=27471 |
| The Following User Says Thank You to krayzie For This Useful Post: | chanomatik (05-12-2014) |
#261 | |
Snow Don't Hurt!
| The Following User Says Thank You to chanomatik For This Useful Post: | krayzie (05-12-2014) |
#262 | |
Drives: 2013 BRZ Limited
I don't recommend disconnecting the cables. Once the door panel is off, the entire handle assembly is removed with 2 screws and the cables remain attached to the handle assembly.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
| The Following User Says Thank You to zdr93523 For This Useful Post: | krayzie (05-12-2014) |
#263 | |
Drive From Home
I'll try and pull the door cards later in the day. Are the cables hard to release / and put back on? How do the ball joints get held in place? Sorry for the stupid questions. |
| The Following User Says Thank You to krayzie For This Useful Post: | unsurety (06-23-2014) |
#264 | |
Snow Don't Hurt!
![]() Lift the colored sheaths out of their placement and pull the metal ends out and you're good! Cables released! When putting back on, put the metal ends in first, then click in the colored sheaths. Make sure they click or are at least held firmly in place. |
#265 | |
Sent from my LG-D800 using Tapatalk
| The Following User Says Thank You to zdr93523 For This Useful Post: | chanomatik (05-14-2014) |
#266 |
Snow Don't Hurt!
I found the releasing of the cables to be much quicker.
| Toyota Japan 86, FRS, Air Bag, Frameless Mirror, Knee Pad, Sun Visor, Door sill, MOR | nigel-jdmparts | Interior Parts (Incl. Lighting) | 89 | 02-01-2013 04:00 PM |
| HID Retrofit Kit install | Jidonsu | NY / NJ / CT / PA | 1 | 08-04-2012 01:24 AM |
| How do you install the mud guards? | Moshpit37 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 07-27-2012 11:13 PM |
| FS: console knee foam pads | 86_ZN6 | Interior Parts (Incl. Lighting) | 9 | 07-21-2012 09:46 AM |
| Spoiler Install | CharlieChaos | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-07-2012 10:43 AM |
