Old 12-15-2014, 02:24 PM   #253
Koa
Originally Posted by Octane View Post
Toyota Tech here. I was planning to get this for my car so I started to ask around the more experienced guys at the shop, and one of the heavy line guy said he already got a few blown engine with the light weight crank pully. He works around alot of FR-S's and was also one of the techs that was invited to work at the Toyota grand prix celebrity race as a tech. Now I'm not scaring anyone away from using it, but I just want to lay the facts on the table. Also theres not much that directly links the pully to the blown engine, he just said he noticed a few of the blown ones had it and for some was the only mod as far as he can tell.
I'm nitpicking (I know it's a common phrase), but facts are commonly held truisms (some 'facts' can still be, in actuality, untrue). The trusim at current is that LWCP will not be the cause of a blown motor, all else being equal. Not to say this isn't valuable information and perspectives that will one day become fact! Thanks for the heads up and info for real
Personally staying away from LWCP after disappointing results given the effort on other platforms
Old 12-17-2014, 04:17 PM   #254
jay1989
Drives: 2014 Subaru BRZ
Wow what a PITA I just busted 2 ratchets trying to get that damn thing off crappy craftsman tools. Guess its time to go find my impact drill
jay1989 is offline   Reply With Quote
Old 12-17-2014, 07:04 PM   #255
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by alpax View Post
Would be interesting to have the actual math behind that.
Frankly speaking the whole idea of replacing the crank pulley is like that "fart in a hurricane", but everyone confirms, that the difference is noticeable. The SC parasitic load is also just "noticeable" - it's not that huge. That's why I'm simply guessing they could be the values of a similar magnitude. And because "+" of a pulley and "-" of a SC happen at the same RPM range, it's just logical to try and sum them up.
Actually during my morning drive today I did notice several times that the engine RPM climbed slightly easier. Could be a placebo effect of course.
I wouldn't expect the crank pulley to make a huge difference, but even if it would give a slight improvement for its money - why not?
I have thought a lot more about the concept of lightening rotating drivetrain components and the effect on vehicle acceleration.
I have come to the conclusion that the effect that a LWFW or a LWCP (or a light weight driveshaft) will have on vehicle acceleration should be exactly the same as just removing the same weight from the vehicle as a whole.
There will definitely be a benefit to the engine in general by having lighter components (lower internal forces) and will rev faster under no load.
However there should not be ANY noticeable difference on a dyno since the car's total momentum is not part of the equation.
You should feel faster acceleration with the lighter components, but it should not be any different than just removing the same mass of components from the carpets or the interior for example.
Old 12-17-2014, 07:32 PM   #256
CoupedUpSubie
Drives: 2013 BRZ Limited
Ratchets are not for breaking bolts free. A breaker bar is what is needed. It has a pretty solid pivot point. I used a cheaper torque wrench set at its highest setting as my breaker bar wasn't long enough, not the proper tool though just as a ratchet isn't. Go buy a new ratchet and a 36" breaker bar, you will thank yourself even if it is craftsman.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 12-17-2014, 07:41 PM   #257
jay1989
just picked them up from the parts store before reading this and did the trick. I should have known better than to try and break it loose with a ratchet but it is all I had at the moment and they have never let me down before.
Oh well what can you do, everything is going back together now thank god. It is dark and cold but that is ok Should be up and running again in another hour or so.
Old 12-25-2014, 01:40 PM   #258
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Thanks for this thread, gave me all I needed to know for my install just now.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 12-25-2014, 02:05 PM   #259
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
I never got why people change out this pulley with one with less balance and of a softer metal and same diameter with no vibe dampening
why
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 12-25-2014, 04:03 PM   #260
Malt
Drives: 2015 WRX
why
Who says the available LWCP's are less balanced than the stock one and what does a "softer" metal have anything to do with its ability to function as a pulley?
Malt is offline   Reply With Quote
Old 12-26-2014, 11:07 AM   #261
phobos512
phobos512's Avatar
why
Well, for me it,was the ability to get 4 lbs off the front of the engine. Not for engine performance per se but overall light weighting. I'm not going anywhere as extreme as some folks but I'm doing what I can and a few pounds off the forward extreme of the car helps, if only a little, to reduce MOI.
Old 12-26-2014, 01:25 PM   #262
stugray
The truth is: Unless you are building a motor from the ground up with performance in mind, the pulley will do ZERO for performance.
Shedding the weight from the pulley will have the exact same effect as shedding the weight from anywhere else on the car.
But 4 lbs IS 4lbs.
Or you could take a dump before you go out on the track - your choice.
Old 12-26-2014, 01:56 PM   #263
phobos512
phobos512's Avatar
But 4 lbs IS 4lbs.
Well, that's true with respect to gravity but if you understand moments of inertia, and your post implies that you don't, you understand that removing weight from the extreme ends of a car will increase its ability to change direction. Which is what I was talking about.
Old 12-26-2014, 03:21 PM   #264
stugray
I DO understand moments of inertia better than most on this forum.
There are a number of reasons that the pulley will make almost zero difference:
1 - the pulley is as close to the spin axis of the rotating mass as possible.
Since the moment of inertia is proportional to the square of the distance from the rotational axis, and the pulley is as close as you can get, it makes the smallest contribution to rotational inertia of any component in the drivetrain. I have stated it before, the BELT makes a greater contribution to rotational inertia than the pulley does.
2- When the car is accelerating, the engine is fighting the mass of the vehicle, NOT just the rotational mass of the drivetrain.
At this point, the limiting factor is the vehicle mass and the rotational mass is a tiny fraction of the total mass of the system.
This is why the pulley makes a difference when revving the engine by itself, but is in the noise on a dyno pull.
I do also understand polar momentum. so removing weight from either end of the car is important.
Taking the spare out of the trunk will make about a 10X difference compared to losing 4lbs from the pulley.
Old 12-27-2014, 11:19 AM   #265
eddieflyinv
eddieflyinv's Avatar
I will say I don't notice much difference as far as speed or anything, it seems to have a little bit faster acceleration but who knows maybe that's just the placebo effect,
What I do notice most, and what makes it feel entirely worth doing, is the improved engine response when heel toe shifting. it just feels, for a lack of better words, better lol.
That's me though, everyone is different and for some that change of feel may not seem like it's worth anything
I also got my 3pc set for a really good deal, so as far as I'm concerned pulleys were a solid buying decision
eddieflyinv is offline   Reply With Quote
Old 01-10-2015, 08:54 PM   #266
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
Used this to install the GrimmSpeed crank pulley, thanks OP.
I had to yank the hell out of my breaker bar in order to break the bolt loose. Torquing to 94 ft/lb afterwards felt like cake compared to breaking the bolt loose.
menikmati is offline   Reply With Quote
brz, crank pulley, diy, frs, perrin, raceseng
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
