Old 04-26-2018, 01:57 AM   #253
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Originally Posted by alxtheoreo View Post
This is to replace the timing chain, tensioners & cam gears.
Sent from my SM-G930V using Tapatalk
Will they replace the ECU?
Jmonty is offline   Reply With Quote
Old 04-26-2018, 01:34 PM   #254
kinghurl
Drives: BlueBurz
This could be another surprise. The procedure calls for a step by step set of changes and testing. If the VVT learning values don't change fast enough after that, they'll recommend the ecu change as a last step. I resisted initially but power was not quite back to normal as it still showed the pending code which it would until the ecu relearned the new values. That is a SLOW SLOW(like 5K miles). Until then, the pending code will cause the cams to be set at a fixed point midway in their range. The slow adaptation of the ecu is the reason for it needing to be changed, sadly.
kinghurl is offline   Reply With Quote
Old 04-26-2018, 04:41 PM   #255
alxtheoreo
alxtheoreo's Avatar
I don't recall the dealership saying that. Plus, when I called the closest tuner shops, they didn't mention it either.
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 04-26-2018, 04:42 PM   #256
alxtheoreo
alxtheoreo's Avatar
Update: I filed a complaint with Toyota Motor Company yesterday, and they're investigating.
Old 04-27-2018, 01:40 PM   #257
EigenGuy
My nightmare continues...
Quick summary: 2013 BRZ with JR supercharger showing P0018 and P0016. Already completed new OCVs, ECM, sensors, and oil flushes. Decided to replace the intake cam sprockets.
As expected, upon removing both intake sprockets the plate that retains the internal VVT spring fell right out. Looking at it closely, Subaru's ingenious idea to retain this plate was to simply peen over in two spots. This is clearly an insufficient design. Retention of this plate needs to be integral or cap-screwed in.
Upon putting everything back together per the service manual, I still must have screwed up the timing because the engine starts but runs really rough. I shut it down after 3-4 seconds. Question for rusty959, I spent a significant amount of time ensuring the blue chain lined up with the crank key and the pink chains lined up with the sprocket indicators. I am 100% sure everything was right. I rolled the engine over a few times by hand to make sure there was no interference. Is there any scenario where something could be off?
Lastly, I haven't changed the ECM yet. As discussed, I'm assuming the codes are still going to be burned in even after getting all the mechanical stuff straightened out. I just want to prove this first.
Lessons learned for me:
1.) Never buy a vehicle within two years of it's first release.
2.) Definitely never modify a vehicle inside of warranty.
3.) I'll never buy another Subaru.
4.) From what I've read, our cars are susceptible to these CELs while using JDL UEL headers. Not sure why but it seems to be a common theme.
5.) Be careful messing with the advance on the intake sprockets (I first got the codes when data logging for a Delicious tune). Root cause in my mind is due to excessive oil pressure on the peened in retention plates. This pressure must be pushing the retention plates out.
6.) It might be good insurance to change oil filters more frequently. And always use synthetic 0w-20, rather than 5w-30 (I always did but this is a common mistake).
EigenGuy is offline   Reply With Quote
Old 04-27-2018, 02:50 PM   #258
Ultramaroon
not playing cards
Ultramaroon's Avatar
The plate is only there to keep the assembly together until it has been installed. There is zero functional difference an intact assembly and one on which the plate has slipped.
I have a group of photos supporting this but slacked on the follow-through.
Old 04-27-2018, 03:23 PM   #259
alxtheoreo
alxtheoreo's Avatar
I feel you on points 1 & 3. This is my first Subaru (granted it's labled a Scion) and I would have never expect this big of a development & manufacturing oversight from both Subaru & Toyota. This engine was beat to hell on race tracks & the street for years, right? Something should have shown up then.
Old 04-28-2018, 01:00 AM   #260
rusty959
Drives: DGM BRZ limited
The only think I'm thinking of in regard to the timing chain is ensuring the colored sections were centered over the marks on the cams and the correct side of the tab on the crank. Its possible to have the crank off by one but still over the tab. Any chance you checked the triangles on the cams at TDC to ensure they pointed together?
Mine ran super rough first start as well. I also had just installed a new ECU, which could have played into it. I seem to recall it backfiring once and something that sounded like detonation which concerned me a bit, obviously, but when I started it again it was fine. One thing to think about is you emptied the cam sprockets of oil, and they have more adjustablility than being off by one link would cause. No idea what happens to them as they fill back up.
rusty959 is offline   Reply With Quote
Old 04-28-2018, 01:01 AM   #261
rusty959
I could be convinced this is the case, but it just concerns me that it could be something else. Just hope that something else is still within the cam sprockets and some of us aren't going to have this code pop back up again in 10k miles or something.
Old 04-28-2018, 01:21 AM   #262
Ultramaroon
not playing cards
I can dig out the pics and do some markups but basically, the difference between in, and out of place is valve-closed, and valve-more-closed.
Old 04-28-2018, 09:44 AM   #263
Teseo
Drives: frs
How a header mess up a harware part?
Old 04-28-2018, 02:56 PM   #264
Ultramaroon
not playing cards
Meh. It doesn't.
Teseo (04-28-2018)
Old 04-28-2018, 04:43 PM   #265
Teseo
Drives: frs
Meh. It doesn't.
So thought i was on rethorical question thread, sorry uncle
Old 04-28-2018, 04:52 PM   #266
Ultramaroon
not playing cards
Teseo (04-28-2018)
P0016 fixable without new ECU? Mr.Jay Issues | Warranty | Recalls / TSB 8 02-06-2022 06:15 AM
P0016/P0017 cause AVOturboworld Issues | Warranty | Recalls / TSB 18 04-17-2021 12:09 AM
P0016 Code Shady195 Engine, Exhaust, Transmission 30 02-21-2019 03:31 PM
p0016 need help asap lol Issues | Warranty | Recalls / TSB 25 10-30-2018 04:49 PM
OFT P0016 and TSB question mmmcambelsoup Software Tuning 10 05-24-2017 10:24 AM
