09-06-2012, 02:58 AM | #253 |
Drives: 6MT Raven FRS, Toyota SR5 V6 4x4
Blacked out it is then!
09-06-2012, 07:11 AM | #254 | |
I Love custom Turbo kits
Drives: Limited BRZ
Don't fall in the trap!!!! ^^^
09-06-2012, 09:05 AM | #255 | |
Drives: Limited WRB AT6 BRZ
09-06-2012, 09:13 AM | #256 | |
Drives: 2013 Subie BRZ Limited, black, 6MT
One at the center back edge of the transmission. One on each side of the engine just behind the cylinders basically. Just remove the nut from the passenger's side mount, stud stays in place in the motor mount. The other two will have plenty of play since they're rubber mounts. I placed a flat 1" thick board just under the transmission right behind the frame crossmember and fit my jack's piston up in there between the frame and I believe sway bar, and lifted from there. Here's a short night video of a first gear relatively easy acceleration with the full header back system... |
The Following 2 Users Say Thank You to boarder1995 For This Useful Post: | kwood9000 (09-06-2012), Sportsguy83 (09-06-2012) |
09-06-2012, 01:38 PM | #257 |
Another video of the full system...love the sound! What doesn't come out in these videos usually, particularly mine, is the low frequency that's produced from the exhaust. It really does have a nice deep burble to it, not a high pitched rasp like many in-line 4 bangers.
09-06-2012, 01:53 PM | #258 | |
Drives: 2013 HotLava FRS, 2005 Legacy
:happy0180: to Nameless!
HotLava FRS MT |
09-06-2012, 02:00 PM | #259 | |
Drives: Limited BRZ
[ame="http://www.youtube.com/watch?v=P2vBi-2saZI"]BRZ Nameless full exhaust.MOV - YouTube[/ame] [ame="http://www.youtube.com/watch?v=Z2FDI0ATA2E"]BRZ full Nameless exhaust.MOV - YouTube[/ame]
09-06-2012, 02:36 PM | #260 | |
Grip>Slip
so when you jacked up the motor, you just removed the passenger side nut from the motor mount and didn't touch the other two? |
09-06-2012, 02:38 PM | #261 |
is it sounding like that with just a catback? is there a resonator?
09-06-2012, 02:40 PM | #262 |
Drives: Whiteout FR-S
Factory resonator should be there, the nameless is an axleback and i think he is has the downpipe too not sure if he has the resonator on it though.
09-06-2012, 02:43 PM | #263 |
Grip>Slip
09-06-2012, 02:53 PM | #264 |
Drives: Limited BRZ
From my conversations with Jason, that's the only one needed to be touched, the other two are left alone.
09-06-2012, 02:57 PM | #265 | |
When I installed mine, I only dealt with the one on the passenger side. Lifted it an inch or two. Not as big a deal as it sounds once you are under there and see what is going on. |
The Following User Says Thank You to TrickyFrenchman For This Useful Post: | Sportsguy83 (09-06-2012) |
09-06-2012, 02:59 PM | #266 |
Drives: Limited BRZ
I want them to release that offset/offset with Groupbuy BAD.... I love this exhaust system.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | JoeBoxer (09-06-2012) |
Similar Threads | ||||
BRZ performance driving demo - looks great | Oriental Life | BRZ Photos, Videos, Wallpapers, Gallery Forum | 26 | 04-11-2012 02:20 AM |
What type of performance parts will you be looking to buy first? | bFreed | Engine, Exhaust, Transmission | 12 | 11-09-2011 05:51 PM |
Performance automatics | madfast | Engine, Exhaust, Transmission | 118 | 08-25-2011 03:26 AM |
FT-86 Article on Performance magazine | 4agze | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 01-09-2010 11:33 AM |
