Old 09-06-2012, 02:58 AM   #253
Username
Username's Avatar
Drives: 6MT Raven FRS, Toyota SR5 V6 4x4
Blacked out it is then!
Username is offline   Reply With Quote
Old 09-06-2012, 07:11 AM   #254
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by gmookher View Post
Sorry, but I dunno, looking at the Perrin bling that adorns my car(in my link below u can find pics), the black nameless looks like crap IMHO
PSA:
Don't fall in the trap!!!!
Old 09-06-2012, 09:05 AM   #255
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
Originally Posted by boarder1995 View Post
I installed the front section of the exhaust this evening without too much issue. I only had the front of the car on ramps, so it was tight towards the connection of the resonator section. The engine does need to be lifted a couple inches, otherwise it's a no-go on removing the old and installing the new system. I first only was able to get the engine up about an inch, then realized this no-go issue and had to relocate my jack. Also, not having a lift makes the install a bit of a puzzle getting the pipe routed in, but it does go with a bit of time taken. I've also got the Helmholtz resonator, so that makes it a bit more cumbersome.
Does the engine really need to be lifted/jacked up or would jacking up the car be enough?
kwood9000 is offline   Reply With Quote
Old 09-06-2012, 09:13 AM   #256
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
Even if the car is on a lift, it won't clear "snaking it in" with the cylinder heads in the way. The engine HAS to be jacked up a few inches. It's really easy to do since the engine doesn't weigh much. There are three mounting points for the engine and transmission...
One at the center back edge of the transmission.
One on each side of the engine just behind the cylinders basically.
Just remove the nut from the passenger's side mount, stud stays in place in the motor mount. The other two will have plenty of play since they're rubber mounts. I placed a flat 1" thick board just under the transmission right behind the frame crossmember and fit my jack's piston up in there between the frame and I believe sway bar, and lifted from there.
Here's a short night video of a first gear relatively easy acceleration with the full header back system...
boarder1995 is offline   Reply With Quote
The Following 2 Users Say Thank You to boarder1995 For This Useful Post:
kwood9000 (09-06-2012), Sportsguy83 (09-06-2012)
Old 09-06-2012, 01:38 PM   #257
boarder1995
Another video of the full system...love the sound! What doesn't come out in these videos usually, particularly mine, is the low frequency that's produced from the exhaust. It really does have a nice deep burble to it, not a high pitched rasp like many in-line 4 bangers.
Old 09-06-2012, 01:53 PM   #258
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
Yeah your right about that. On week 3 with mine and still loving it.
:happy0180: to Nameless!
HotLava FRS MT
Neziah is offline   Reply With Quote
Old 09-06-2012, 02:00 PM   #259
Sportsguy83
Drives: Limited BRZ
Even if the car is on a lift, it won't clear "snaking it in" with the cylinder heads in the way.....
Fixed to embed videos:
[ame="http://www.youtube.com/watch?v=P2vBi-2saZI"]BRZ Nameless full exhaust.MOV - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=Z2FDI0ATA2E"]BRZ full Nameless exhaust.MOV - YouTube[/ame]
Old 09-06-2012, 02:36 PM   #260
xjohnx
Grip>Slip
xjohnx's Avatar
so when you jacked up the motor, you just removed the passenger side nut from the motor mount and didn't touch the other two?
Old 09-06-2012, 02:38 PM   #261
gmookher
is it sounding like that with just a catback? is there a resonator?
Old 09-06-2012, 02:40 PM   #262
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Factory resonator should be there, the nameless is an axleback and i think he is has the downpipe too not sure if he has the resonator on it though.
Old 09-06-2012, 02:43 PM   #263
xjohnx
Grip>Slip
xjohnx's Avatar
he has the helmhottz in the overpipe/downpipe combo as well.
Old 09-06-2012, 02:53 PM   #264
Sportsguy83
Drives: Limited BRZ
From my conversations with Jason, that's the only one needed to be touched, the other two are left alone.
Old 09-06-2012, 02:57 PM   #265
TrickyFrenchman
TrickyFrenchman's Avatar
When I installed mine, I only dealt with the one on the passenger side. Lifted it an inch or two. Not as big a deal as it sounds once you are under there and see what is going on.
TrickyFrenchman is offline   Reply With Quote
The Following User Says Thank You to TrickyFrenchman For This Useful Post:
Old 09-06-2012, 02:59 PM   #266
Sportsguy83
Drives: Limited BRZ
I want them to release that offset/offset with Groupbuy BAD.... I love this exhaust system.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
JoeBoxer (09-06-2012)
BRZ performance driving demo - looks great Oriental Life BRZ Photos, Videos, Wallpapers, Gallery Forum 26 04-11-2012 02:20 AM
What type of performance parts will you be looking to buy first? bFreed Engine, Exhaust, Transmission 12 11-09-2011 05:51 PM
Performance automatics madfast Engine, Exhaust, Transmission 118 08-25-2011 03:26 AM
FT-86 Article on Performance magazine 4agze Scion FR-S / Toyota 86 GT86 General Forum 7 01-09-2010 11:33 AM
