, dpfarr
Old 12-27-2017, 08:03 PM   #2605
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Just curious, does Canada only do an OBD2 readiness check? Here in California, they do both the OBD2, a sniffer and a visual check, so anything that looks non-stock, even if it is catted, gets flagged.
New2subaru is correct. They don’t require load testing for obd2 cars—just obd1. Obd2 just gets a visual and a readiness test.
Originally Posted by new2subaru View Post
If I recall, we used to just have sniffer, now it's OBD2 ready. But, i'm told new laws are coming into effect where the cars will have to get a full safety, which would include visuals and emissions test. I'm not certain on all of this.
Possibly but I don’t see the point.
Old 12-27-2017, 08:15 PM   #2606
new2subaru
Weight Weenie
Drives: 15 FR-S
I'm not seeing any changes right now
https://www.ontario.ca/page/safety-s...cate#section-2
I was told that cars that were 8 years and older will have to start getting safty'd every few years. We'll see...
Old 12-28-2017, 09:36 PM   #2607
gahooligan
Drives: 2017 BRZ Premium
Originally Posted by TOLM View Post
Good thread.. I am currently on page 50.. slowly reading through the whole thing
Anyone knows if the kit would work on 2017 BRZ? (I am in Canada)
Thanks
Yes, it will with some modifications. Once you get upwards of page 170 or so you will find the posts from a guy that worked it out. I have a 17 BRZ and plan on ordering as soon as Counter Space opens back up for business.
gahooligan is offline   Reply With Quote
Old 12-30-2017, 06:33 PM   #2608
xwd
Anyone know the part number for the water pump they are using in the kit? I have a more custom setup and using a Bosch pump but it's hard to find a place to fit it, the pump Edelbrock is using is a bit more compact.
Old 12-31-2017, 06:07 PM   #2609
shr133
shr133's Avatar
Drives: 2013 FRS
Well it's winter now, but I want to convert to E85 and build my maps before I put on the supercharger. So I have my starter maps for E85 built I have to wait for spring to get them calibrated and get a flex fuel kit. For now I have 2 custom maps 1 for Total Fuel and 1 for Timing. I think when I add the super charger I dial it in on 93 and than convert over to a Mix of E85. I think everyone says most of the gain is up to E50 or E60... What size injectors should I plan on?? 700 cc is what I was thinking...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Old 01-01-2018, 06:41 PM   #2610
700 is tried and proven. Larger if you'll build the motor later and bump up boost.
Unless you hit MBT, you keep gaining more power with more ethanol.
shr133 (01-04-2018)
Old 01-02-2018, 11:35 AM   #2611
jordanthebass
Judson
jordanthebass's Avatar
Drives: 15 FRS 6spd Edelbrock SC
This kit was so simple, me and my buddy (two 18 year old buffoons), where able to install it perfectly the first time. The tuning part including in the tuning kit was a little confusing but after we loaded the carb tune we took her out, did some driving to set closed loop data, checked temperatures and if there where any leaks. Easy-peasy lemon squeezy. The car pulls like a monster now.
However, I have a few questions for anyone that may have answers.
First, after the first start up my Battery has been acting up. We had to replace the oem battery because it got all corroded and greasy and autozone said it was a goner. So we got a new battery and now when I drive with the AC on (Even though I live in GA the temperatures can go from 60 to 28 in a day, one day the car will start and a week ago I was stuck at Kohls for an hour waiting for a jump) the car acts like it loses power. The power windows stop working, my whole dash becomes a christmas tree, with EVERY single light activating, the high beams flash, and I wet my pants all at the same time. Does anyone have even the slightest idea as to why my car is doing this? When I turn the AC off I cannot replicate that at all. Also when idling with AC on the car almost stalls every 5-10 seconds when the condenser turns on.
Second, I already have a high flow fuel pump sitting on my desk, but would the DW 700cc injectors be enough to get me to 300whp? (of course after we solve the above issue )
jordanthebass is offline   Reply With Quote
The Following User Says Thank You to jordanthebass For This Useful Post:
CSG Mike (01-03-2018)
Old 01-02-2018, 01:58 PM   #2612
Kodename47
Kodename47's Avatar
Drives: UK GT86
That could be a poor earth or something similar electrical. Wires around the compressor OK?
Are you going to be using E85? If so, then those will be enough. If not, then no need for injectors or pump.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-03-2018, 06:17 PM   #2613
Soudns like you have a short somewhere.
You don't need a fuel pump unless you're going ethanol.
devtec (02-06-2018)
Old 01-04-2018, 02:14 AM   #2614
shr133
shr133's Avatar
Drives: 2013 FRS
Thanks, that's what I thought. I may go to the 3" pulley at the most to get some more torque with the auto. But Already starting to spin too much off the line N/A with 93oct so I think the 3.25 should be fine.
Old 01-10-2018, 11:12 AM   #2615
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
A bit of a necro-reply, but this has happened to me maybe 3 or 4 times over the past 2 years of owning the edelbrock (that I know of). Last night it did it when I was in the garage and the car was off and cold. The supercharger water pump turned on. I popped the hood and the coolant was indeed flowing. I let it go for about 5 mins to see if it'd turn off by itself, so when it didn't, I turned the car on and off (without starting it), and the pump stopped. My keyless entry fob was nowhere near the car when it happened - it was in another part of the house.
But it makes me wonder how often it happens when I'm not around. If it does, it obviously turns off by itself. Each time it's happened when I'm around I turn on the car and off to stop the pump.
Since I only drive short distances to work, I keep my battery fully charged by hooking it up to a charger every couple of weeks.
Originally Posted by RCSlide View Post
I've noticed that my kits water pump will turn on randomly when the car is not running.
I have heard it kick on a few times just walking through my garage when I haven't started the car in a day or two.
My room mate confirmed that he will hear it click on randomly in the middle of the night (he sleeps right next to the garage)
I've been told that it should only turn on when the ECU is powered - any ideas?
shiumai is offline   Reply With Quote
Old 01-10-2018, 04:22 PM   #2616
86fun
Drives: 2013 FRS
Mine does this all the time. I also have keyless entry, and the fancy LED emblem crap. I have no idea why it happens but it killed my battery, now I have to leave it on a charger if I don't drive it within 2-3 days. Totally dumb, a major flaw.
86fun is offline   Reply With Quote
The Following User Says Thank You to 86fun For This Useful Post:
shiumai (01-10-2018)
Old 01-10-2018, 04:50 PM   #2617
shiumai
shiumai's Avatar
How often does it do it? Does it turn off by itself?
Old 01-10-2018, 09:46 PM   #2618
gtengr
Drives: 2017 BRZ
Sounds like the relay might be faulty. The water pump splices into the EVAP harness, so unless that is cycled when the car is off the water pump should not be turning on.
gtengr is offline   Reply With Quote
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
