Old 07-04-2015, 01:28 PM   #2549
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Looks like I managed to brick my ECU... I guess I won't be getting the car install complete this weekend.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 07-04-2015, 01:32 PM   #2550
airmanmurphy02
Petrol head
airmanmurphy02's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Xiao Li View Post
Just finished installing my kit today and I cannot get the driver side tabs under the headlights to pop in all the way. The foglamp housing is the culprit for sure and I tried moving the piping around. I got it to be okay but it's not perfect. Is this a common issue?
I had the same problem with my BRZ. I adjusted my piping four or five times and never could make it fit right. Still makes contact enough to pop the bumper out of the clip on drivers side.
Sic Semper Tyrannis!
airmanmurphy02 is offline   Reply With Quote
Old 07-04-2015, 03:20 PM   #2551
DaiTT500
DaiTT500's Avatar
Drives:
You didn't brick it. Probably burned your license like the first time i tried to program ecutech. Just get the tuner to send you another license monday.
DaiTT500 is offline   Reply With Quote
The Following User Says Thank You to DaiTT500 For This Useful Post:
Bramick (07-04-2015)
Old 07-04-2015, 08:50 PM   #2552
If your bumper is popping out, it's usually because the clip was damaged during the initial bumper removal.
There should be *zero* contact between a charge pipe and the bumper if everything is positioned per the instructions.
Old 07-04-2015, 11:55 PM   #2553
alpax
alpax's Avatar
Drives: 2013 Subaru BRZ AT JRSC
Can someone clarify how the EcuTek licensing works?
I got the JRSC kit with EcuTek and CARB tune, used the provided license to flash the tune. Now, if I want to flash another tune (Delicious F&G, for example), do I need to buy another EcuTek license? If later I will need to flash a new version of that second tune, or will try to flash the CARB tune back, will it be possible to do with the same license, or will I need to buy another one once again?
Thanks.
alpax is offline   Reply With Quote
Old 07-04-2015, 11:56 PM   #2554
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Thanks.
Once you have a license it's in the car, you can find from anybody since you program it in yourself if it's an etune.
ScionOfHorus is offline   Reply With Quote
The Following User Says Thank You to ScionOfHorus For This Useful Post:
alpax (07-05-2015)
Old 07-05-2015, 01:57 AM   #2555
alpax
alpax's Avatar
OK, so it's a license per car, not per flash. I was just confused by the message when I flashed the CARB tune - on completion it said something like "0 licenses left". So, it meant I could not flash another car. But still can flash mine as many times as I want. Excellent!
Thank you!
Old 07-05-2015, 12:49 PM   #2556
Bramick
Bramick's Avatar
If you push on the fog light from the front and it doesn't move back then pull the bumper and the driver side headlight. That pipe going into the intercooler is the issue. Its too low and pushing on the fog light housing. I just had the same issue and just fixed it. I also grinded off the back corner part of the bumper brace where it was close to the pipe at a 90. Now it's parallel to the pipe with extra padding in between. I also had to rotate the pipe coming out of the SC (with the JRSC) sticker clockwise... shift the sticker towards the air filter. That'll keep it from touching the bumper brace behind the headlight.
The bumper isn't even bolted down and it's fitting fine now.
The Following 3 Users Say Thank You to Bramick For This Useful Post:
CSG Mike (07-05-2015), wparsons (07-07-2015), Xiao Li (07-08-2015)
Old 07-05-2015, 03:47 PM   #2557
Thank you!
To clarify, you can assign multiple licenses to that dongle, so if your friend with a FRS wanted to get a EcuTek license, then he could use your dongle and cable to flash a tune onto his car.
Once his ECU has a license, your dongle, or any master tuner dongle, can flash his car; the license is permanently attached to that ECU.
alpax (07-07-2015)
Old 07-06-2015, 07:54 AM   #2558
Bramick
Bramick's Avatar
Ok I got my ECU prgrammed Moto-Mike had to send me a new license and I tried again. Looks like to issue was the battery.
On to the next problem. The car is stalling when you let off the gas. I assume this is the MAF. Any other suggestions?
Old 07-06-2015, 08:44 AM   #2559
Bramick
Bramick's Avatar
Boost leak! On the pipe right after the MAF pipe... Fixed.
Let the breakin begin!
The Following User Says Thank You to Bramick For This Useful Post:
Xero-Limit (07-06-2015)
Old 07-06-2015, 01:45 PM   #2560
Xiao Li
Xiao Li's Avatar
Drives: '14 BRZ, '01 S2K
I will have to try your adjustments, hopefully it will pan out well. Looks like we both just got this kit up and running around the same time and bought from the same place. The boost is very addicting, already driven 150 miles during my break in.
Xiao Li is offline   Reply With Quote
The Following User Says Thank You to Xiao Li For This Useful Post:
Bramick (07-06-2015)
Old 07-06-2015, 02:50 PM   #2561
Xuningshen
Drives: Subaru BRZ
I bought this to make my life easier too... who needs a that much windshield washer fluid anyway....
http://www.ptuning.com/subdir/itemde...&ModelDesc=FRS
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
The Following User Says Thank You to Xuningshen For This Useful Post:
glamcem (07-06-2015)
Old 07-06-2015, 03:13 PM   #2562
You're in California; why did you decide to not get the CARB kit, even if it's only for the sticker?
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
