Old 07-14-2015, 10:38 AM   #2549
STV3
Señor Member
STV3's Avatar
Originally Posted by Thehermdawg View Post
From all the videos I've seen, I haven't heard all that much rumble from this header. Maybe a little, but it's almost like an EL to me. Of course, videos don't really do justice. So how is the rumble?
Mine is plenty rumbley when I am cruising around. It does smooth out a bit in the higher rpms but I actually like that.
STV3 is offline
Old 07-14-2015, 11:26 AM   #2550
bass_114
bass_114's Avatar
Drives: wrb brz
Same as above for me best rumble party is under 4k revs
bass_114 is offline
Old 07-14-2015, 01:59 PM   #2551
rick s
rick s's Avatar
Drives: 2013 FR-S Ultramarine 6MT
Originally Posted by DGM86 View Post
I was under the impression that disabling the CEL would cause the ECU to not run its readiness checks. You would fail the inspection due to that even though you are not throwing a CEL. Tuning them out doesn't turn them off it just tells them to shut up. That was the case for my previous car at least, but I was running megasquirt in parallel, so its a bit different.
If you can tune out CELs with OFT on these cars and not hinder the ECU readiness checks, i'm going to be thrilled.
This is the answer I got from the OFT guys.
"The P0420 is turned off when you run our stage2 map and no CEL will be present.
We are disabling the O2 monitor.
If you "catted" header is emissions friendly then you can simply run a stock tune when you need to pass your state emissions test. "
I assume if they disable the O2 monitor you will not pass inspection as the monitor will not be in a "ready" state.
I have a "hypothetical" acquaintance who shall remain nameless .
He/she runs a catless header with an OFT stage 2 tune and supposedly gets the car passed emissions.
I will be seeing said "imaginary person" in a few weeks and pry out the secret from him/her
rick s is offline
Old 07-14-2015, 02:56 PM   #2552
STV3
Señor Member
STV3's Avatar
I just passed a few weeks ago running the Stage 2 UEL tune. Didn't do anything special. Although my mechanic did have some trouble getting the machine to read my car the first few attempts...
STV3 is offline
Old 07-14-2015, 04:00 PM   #2553
rick s
rick s's Avatar
Just curious, does NY require all monitors to be in a ready state? In NH, if any monitor shows "incomplete" (not ready) you will fail emissions. When you reset the code all the affected monitors go to their incomplete state until the required drive cycle requirements are met. Once met the monitors are ready and you carefully drive your car to the nearest inspection site and cross your fingers .
I'll being talking to my "imaginary" friend to see what they do to get through inspection. Hopefully I'm wrong and the easy fix is to go with OFT. I'll post back later with what I find.
rick s is offline
Old 07-14-2015, 06:11 PM   #2554
Thehermdawg
Just Some Dude
Thehermdawg's Avatar
Drives: 14 FR-S Raven A/T
Originally Posted by FTemplar View Post
The rumble is at its best when WOT between 2000 and 3000 (for me) particularly in 2nd, 3rd and 4th gear, but you kind of lose it in 5th and 6th (in the driver's seat, not from another car's perspective... if you ask someone to drive next to your car in 6th on the highway, it's definitely noticable)
CEL disapeared as fast as it showed up for me, within 24 hours it was gone. I have a an aftermarket catback and K&N Drop-In air filter. It's UEL is 6 inches difference, not the most UEL there is, but I like it.
Thanks guys. I'm interested to see what it might sound like with my muffler delete now. Should sound nice.
2014 Scion FR-S Raven A/T (AKA the Sex Panther)
MODS: Berk Muffler Delete Track Pipe, HKS Drop-in Filter, Yospeed Center Console Plaque, Raceseng Shift Knob, Enkei Kojin wheels.
And stickers. Lots of them.
Originally Posted by Rocket.BRZ View Post
But the party has just begun.
Thehermdawg is offline
Old 07-28-2015, 02:39 PM   #2555
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
bump it up! we have a few left instock!
FT-86 SpeedFactory is offline
Old 07-30-2015, 07:42 PM   #2556
EXCellR8
FR-S Driver (MT)
EXCellR8's Avatar
Drives: 2013 Whiteout FR-S
So tempted to buy one of these, how many are left?
EXCellR8 is offline
Old 07-30-2015, 07:52 PM   #2557
vramsaran
Drives: BRZ Limited WR blue
Military Discount on parts ?
Do you guys ( Header manufacturer ) offer a % off for Mil service folks ?
Thanks in advance.
vramsaran is offline
Old 07-30-2015, 09:16 PM   #2558
quicksilver30
quicksilver30's Avatar
Drives: '13 LR BRZ Limited| '07 Jeep GC
Totally worth it. Then get a tune and you will be all set.
'13 Lightning Red BRZ
Mods: Grimmspeed Cold Air Intake|FT86SpeedFactory Stage 2 Tune|FT86SpeedFactory Catted header|Nameless Catted and Resonated OP/DP|Perrin Resonated Cat-back|
quicksilver30 is offline
Old 07-31-2015, 09:45 AM   #2559
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Thanks in advance.
They sure do, this might help ya .
http://www.ft86speedfactory.com/military-discount/
JonAvalon is offline
Old 07-31-2015, 09:23 PM   #2560
EXCellR8
FR-S Driver (MT)
EXCellR8's Avatar
bump! ordered one, along with a couple other goodies
EXCellR8 is offline
Old 08-17-2015, 07:27 PM   #2561
DarkRealm
DarkRealm's Avatar
Drives: Scion FR-S
any ideas on how loud it would be if i got this?
i have your speedfactory v1 exhaust unresonated and dont want an insanely loud sound
DarkRealm is offline
Old 08-17-2015, 11:30 PM   #2562
drifter-s
drifter-s's Avatar
I had this exact setup. Recently changed it out though so unfortunately I can't provide a sound clip. They compliment each other perfectly. It is a little louder with a little more rumble to it. Still no highway drone, but it is a little more louder on the freeway. There is a very slight rasp at wide open throttle in the upper RPMs, but sometimes that isn't even noticeable.
drifter-s is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
