#2535 | ||
The Stig's German cousin
14.6.D and 14.10.B do not have any language about "devices may perform no other functions." Plugging a disable device into your ODB port counts as electrically disabling those functions. If I wanted to use a beastronix, I would build to the rule book and happily take my chances with a protest committee. I think you'd be on very solid ground. The only technicality I see actually is that the non-ABS-disable version does disable EBD. You could claim that is a traction control function as it almost meets the definition (sticking point is "attempted acceleration," although there are documented cases of EBD activating under acceleration that's not its main use). And even if the PC didn't buy this, you can fall back on this being a comfort and convenience item as the factory already has this mode programmed into the car, you just came up with a way of automating the input. For reference: Quote:
| The Following User Says Thank You to renfield90 For This Useful Post: | cjd (09-28-2016) |
#2536 |
Drives: 2013 Raven FR-S
What's considered the optimal ride height for STX? I'm currently lowered about 1" from stock, but it always seems like other 86 drivers are lower than me. Since we aren't allowed to do geometry correction, I wonder how low we can really go before diminishing returns?
#2537 |
Drives: 2015 CWP BRZ
Another good question to go with that is how low can you go in the rear before you need rear LCA's? I'm new to STX and still doing my research.
#2538 |
Drives: 2017 BRZ
Ride height as low as you can while doing everything else you need to do. There isn't exactly a ton of travel available to give up, and you need to stay off the stops. Spring rate will play a role here... I've heard anything from 1.5" to 2" being the limit. I'm probably in that range all four corners, and am both lower and on higher rates than most around me at events... At the moment.
I would consider a rear LCA key to a proper even alignment and the ability to set it where you want.... Unless you stumble upon a setup that just works exactly right. You could do the eccentric UCA bushing instead but whomever does your alignment will likely hate you. |
| The Following 2 Users Say Thank You to cjd For This Useful Post: | smg1138 (10-05-2016), strat61caster (10-05-2016) |
#2539 |
Should I spend the $ or not? Is this a good upgrade or does it actually have a negative effect on the car's handling as some have stated?
TIA DP
#2540 |
I've never used one, but from everything I've read, it doesn't offer any noticeable increase in performance. The money would probably be better spent on other parts.
| The Following User Says Thank You to smg1138 For This Useful Post: | Blue Gt (10-14-2016) |
#2541 |
Drives: '22 BRZ
Front strut brace isn't legal in STX due to the classification of our factory strut braces and the money is better spent elsewhere anyway
| The Following User Says Thank You to DocWalt For This Useful Post: | smg1138 (10-15-2016) |
#2543 |
Drives: 2013 FRS, 2024 Trueno
Strut brace is LEGAL it just cant be a triangulated strut bar. It can only connect the 2 strut towers.
#2544 |
Drives: '22 BRZ
I was pretty sure there was a special rule in one of the fast tracks saying that it specifically wasn't legal?
Either way, it's money better spent elsewhere, IMO. edit: Doing a quick google search and found this gem from Terry Fair... when will more people realize his modus operandi is complaining about cars then making a bunch of parts for them, then claiming that they're now amazing and the best things ever? "Again, I don't feel the FT86 twins will be a threat to STX, but they should at least be competitive here, unlike in STR, where they would have been cannon fodder."
#2545 |
APEXHNTR
Drives: 10 Series FR-S #1867
From what I remember that was discussed a few hundred pages back in this thread you can either upgrade the two factory bars OR do a 2-point across the two strut towers but you can't add a 3-point or remove the factory bars
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#2546 | ||
IMO this chassis is so stiff that an STX prepped car will not generate enough grip to make chassis flex a big problem. The factory reinforcement bars are there for a reason. |
#2547 | |
#2548 | |
Drives: '22 BRZ
What would you want to spend 4-6 grand on? I feel like my 75% build was pretty fast and there were a lot of easy changes to make still.
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 07:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 02:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 12:02 PM |
