#2521 |
Drives: Scion fr-s
I just got my OFT about a week ago and my screen all of a sudden is very bright and white, to the point where I can't read the text on some screens. I played with the brightness, did a screen calibration and nothing has changed it. Its the same when plugged into the car or laptop via USB.
Anyone else seen this before or do I have a dud OFT?
#2522 |
Drives: '13 SSM BRZ Limited 6MT
i get that sometimes, i end up just turning it off and then back on (via my on/off OBD cable but an unplug/replug will work too).
#2523 |
Drives: Scion fr-s
Mine is every time now, it worked perfectly for 2 days and now its constantly like this on every screen, the touchscreen works fine but the display is god awful. I've made sure the connection is good, and its the same when plugged into my laptop.
#2524 |
It's time to reload your stock ROM and send it back to Shiv. That's no ordinary white screen. Shiv might need to send you another one, so you better reload your stock ROM and send it back to Shiv, before your OFT stops working completely.
If I say yes, will that make you think I understand?
#2525 |
Drives: FR-S Whiteout
Why are you setting load limit values so low below 2200rpm? It's it a AT vs MT thing? I'm hitting engine loads beyond 1.2 g/rev at RPMs that low. Not quite sure how this thing works beside that by increasing the value in the field AFRs will become richer with no change to MAF scale. Also changing the load limit under say 2200rpm will effect AFR's in both lower and higher RPM's, not only at 2200rpm. so confusing...
Intent > Content
cowardice is the mother of cruelty. |
#2526 | |
Drives: JAWS
#2527 | |
I just started playing with these tables.
Intent > Content
#2528 | |
eg if you go wot at 2000 rpm the calculated load will likely be over 1.4 which is at limit of the tables so without load limits at 2000 rpm wot the ecu would look up very rich fueling and very retarded timing as it would use the actual calcultated load. This is what happens in usa oft stage2 roms as load limits were set at a1.5. if you set the limits back to what the other oft roms are then load at 2000 rpm is limited to about 0.8 when you go wot at 2000, the ecu now looks up the timing fueling ect using the load value od 0.8 result is less rich fueling and more ignition advance and car no longer boggs down. |
#2529 |
Drives: JAWS
@steve99 yes but he's saying that changing the load limits at lower rpm are also affecting his higher RPM AFR. I'm also suspecting this because after lowering the load limit at 3600 rpm to .9, and raising the values in my OL maf scale, my entire OL log became leaner..when it should have gotten richer.
#2530 | |
Drives: Toyota 86 GTS
#2531 | |
i think your best getting your maf scaling correct and leave it, then only use the load limits or the Engine Load Compensation table if you have to. |
#2532 |
I've been using the OFT for 7 months now and I have noticed that when I'm running the stage 2 El e85 tune, I would randomly lose the ability to use cruise control. It happens probably once a week and ive never noticed it when I was using the stage 1 El 91 tune.
I have to turn the car off and on to get cruise control back. Are there any settings to stage 2 or e85 specific tunes that would affect cruise control? |
#2533 | |
check the P0420 cel code (cat efficiency) is disabled in tune, if that trips it will disable cruise comtrol also check P050B is disabled if you have altered post start ignition timing to quieten cold start that code is (post start ignition timiing performance) |
#2534 | |
I've made a modification to my clutch pedal level but I was on thr stage 1 91 tune the last five months and never had this issue until switching to e85. Weird. It's barely an inconvenience but I'm just curious. |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 12:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
