#2521 |
Drives: 2014 Subaru BRZ
You can also stand 2 tires up behind the driver seat and stack two behind the passenger seat, leaving the entire trunk empty.
#2522 |
Grip>Drift
Drives: FRS
Since we are talking about bigger tires the 265/35/18 RE71r is a lot wider than the 245/40/17, so who's gonna get 18x9s and test it out? Expensive experiment I know.
Sent from my SM-G550T using Tapatalk
#2523 |
Might work really well with 2017 models with 4.3 rear.
#2524 | |
Drives: 2017 BRZ
No, but they're pretty stiff and it's about 5mm I'd need to find. Really not sure it's worth it.
I don't drive except to/from events or road-trips, so typically everything just stays in the car and there's really no reason to keep the spare in there. I have 4 spares most race days... I'd have a bit of a tough time fitting things as you describe, but that's just due to the specific bits I bring. I'll probably take advantage of this to cut noise levels in the cabin though, it gets really loud with the seat down.It's going to be fun with 4 tires unmounted, and 4 mounted, all in the car, when I go to get them swapped. I might have to hang one out the drivers side window like I see people do with the steering wheel...I guess the fit in the car matters more than I anticipated.
#2525 |
Yeah I had thought about that, it puts it about the same as the older models gearing wise. Finding wheels in 18x9 5x100 is tough though, the Rota G-Force and Drag DR-31 are about the only two I know of. Lots of 18x8.5 options though.
#2526 | |
Grip>Drift
Drives: FRS
Forgestar can make whatever width/offset you need. Sent from my iPhone using Tapatalk
#2527 | |
The Stig's German cousin
I've given up on 4 tires + 4 wheels all at once - I've done it with stock wheels and 225s, but not sure I can make that work with STX sizes. I take two at a time now. My tire guy moved and is now 30-40 minutes one way, so maybe I will try to be more creative again.
#2528 |
#2529 | |
Grip>Drift
Drives: FRS
See. Cheaper than heavy cast 17x9s! Sent from my iPhone using Tapatalk
#2530 |
APEXHNTR
Drives: 10 Series FR-S #1867
Speaking of the 2017 and it's 4.30 rear diff....is that a legal swap for STX under updating/backdating?
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#2531 |
Drives: '14 BRZ
There. Is. No. Update/Backdate. In. Street. Touring.
| The Following 4 Users Say Thank You to conedodging For This Useful Post: |
#2532 | |
Grip>Drift
Drives: FRS
Not legal. Honestly I think the 3.73 rear end from the auto would help more for autox. Much more MPH in 2nd gear. But again not legal. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to BlaineWasHere For This Useful Post: | e1_griego (09-27-2016) |
#2533 | |
Drives: 2022 BRZ, 2008 S2K CR Delete
There are two versions, one with the ability to disable the ABS, which wouldn't be legal (and is what they're referring to indirectly with the response). (sorry for the slow reply, it apparently takes a while to get an account authorized, I prefer just lurking...) Annie |
| The Following 2 Users Say Thank You to Banannie For This Useful Post: | 2superblus (09-27-2016), strat61caster (09-27-2016) |
#2534 | |
Drives: 2017 BRZ
That's a general question for discussion, not directed at anyone in particular. Last edited by cjd; 09-27-2016 at 11:38 PM. |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 07:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 02:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 12:02 PM |
