#2507 | |
Drives: '13 FRS - STX
#2508 |
Drives: Subaru BRZ Limited M/T
I missed this. Now my interpretation of this ruling is: launch control is NOT legal, BUT you can now deactivate the TCS ELECTRONICALLY, i.e. Thru the tune to disable it entirely.
That is electronically to me. Thoughts? Sent from my iPhone using Tapatalk |
#2509 |
Drives: '14 BRZ
Huh? ECUtek launch control has nothing to do with traction control. TC needs to be off for LC to work. It's nothing more than telling the ecu to hold revs at a specific spot.
#2510 | |
And based on the Mini protest on the previous page, not like they could do anything about it anyway. :P It's been proven that just because tc is 'off', doesn't mean it's OFF. Thanks unintended acceleration lawsuit. |
#2511 |
Drives: '14 BRZ
Well, as "off" as it could be. That's just my understanding of the ECUtek version. I could be wrong, but I've been dumb enough to forget to disable TC, use LC at the line and have it just absolutely fail to go at all, which makes me think it doesn't utilize the TC side of things.
I was more thinking the letter was about people modifying the TC parameters somehow to be actually useful (that plug'n'play motec?) |
#2512 |
Drives: 13 BRZ WRB
it refers to a device that exists that will do the Pedal Dance for you aka Beastronix. Unofficially it would be legal for CS too.
#2513 |
Drives: 2015 CWP BRZ
I know this has been talked about before, 245 vs 255. Has anyone tried 255 Re71's?
I just got a killer deal on a used set of 255/40r17 Re71's. I figured for the price it was worth trying out. |
#2514 |
Drives: 2017 BRZ
I've been running 255 and have a set of 245 going on as soon as I wear these out. I haven't compared on my car but often found getting heat into them to be more of a challenge than I observed with 245 on similarly fast (or slow) twins. We'll see what I think. Also curious to hear your thoughts once you've tried them.
#2515 |
I'm new to STX. I've been hiding out in CS for 2 years then jumped in a couple STX prepped twins and drank the coolaid.
I'm collecting parts now and hope to have a decent setup for the start of next year and just focus on seat time and testing. |
#2516 | |
The Stig's German cousin
I have not seen this comparison done on the Rival S. The upside to the 245s is you sit a tiny bit lower. If you're willing to push up your rev limiter IMO there is no real need for longer gears. YMMV. |
#2517 | |
I've also heard the story that they're harder to get heat into than the 245's for an 86 but shouldn't have a huge impact to developing your setup. |
#2518 | |
Drives: 2017 BRZ
I should add, you also can not stack two 255's in the trunk, but you can with 245's (observed, I assume that's true for everyone) |
#2519 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
#2520 | |
I much rather leave the spare tire in so I can have the cover there, which provides more flat/useful area to store tools and things. Flip the back seat down and stack two tires in the passenger area as forward as possible, and the other two tires flat behind it. Then you can put tools/supplies in the gaps between tires. Tetris is fun! |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 07:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 02:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 12:02 PM |
