#2507 | |
Wes
#2508 |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
I didnt but my friend with just a Greddy RS exhaust did a pull that same day on his FRS. It was automatic so we assumed it was 10 whp lower. It ran a 150 whp.
So we calculated that we had anywhere between a 90-100 whp gain over stock.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
| The Following User Says Thank You to Xxyion For This Useful Post: | StraightOuttaCanadaEh (09-18-2017) |
#2509 |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Totally theoretical, but I've got catless headers + custom (resonated) headerback. What sorta HP can I expect with the edelbrock kit. Rest is stock basically - aside from a flexfuel kit.
I like driving!
#2510 | |
Depends on your exhaust setup. I can't get specific unless you get specific. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | 86 South Africa (09-27-2017), coxxoc (07-10-2018) |
#2511 |
#2512 |
#2513 |
Thanks!
I'm leaving the stock exhaust manifold because the car is as loud as I want it and because of emissions. If it weren't for emissions I'd probably go turbo instead, but that doesn't really seem to be a viable option unless I plan to uninstall it every two years to pass Ohio E-Check. That being sad I like the Edelbrock kit. Seems way overbuilt for the application and that gives me confidence in terms of heat management and longevity. BTW I'm new here. How do I thank a post? |
#2514 | |
![]() I have a custom headerback with little restriction and a catless header (made by RMS here in SA)... so can't give you much more than that for now. Otherwise stock.
I like driving!
#2515 | |
Even with the stock header, we can get you to around 265-270whp with supporting mods and a tune. Add ethanol to that and 300whp on the stock manifold is very possible. PM me when you're ready to order. That's the best way to say thanks |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#2516 |
The header will have a bigger impact by itself, than everything behind the header combined!
| The Following User Says Thank You to CSG Mike For This Useful Post: | 86 South Africa (09-27-2017) |
#2517 | |
| The Following User Says Thank You to Randoman5 For This Useful Post: | CSG Mike (09-28-2017) |
#2518 |
I took a few readings of the heatsoaked manifold (quick 15 minutes run around town) in order to get an idea of where a majority of heatsoak for IATs are coming from. Here's what I've collected. It was about 85 F ambient, sunny, humidity around 80%
MAF Housing ![]() Supercharger ![]() Oil Cooler ![]() Liquid to Air Intercooler ![]() Air Filter Box ![]() Passenger Lower Intake Runner ![]() Passenger Upper Intake Runner ![]() Driver Lower Intake Runner ![]() Driver Upper Intake Runner ![]() Driver Head ![]() Passenger Head ![]() The heating of the filter box and MAF sensor housing are the first two things I'm aiming to work on a solution for. I've heard the gold foil tape doesn't attach well to the type of surface for the airbox and I'm not sure that would help much anyways since most of the air coming in bounces of the high pressure area in front of the radiator. What has everyone else come up with for lower IAT? |
#2519 |
Drives: GT86 Harrop S/C
Are people getting heatsoak IAT issues with this kit are they?
#2520 |
my measured IAT is always about 25 degrees over ambient, even with the Verus hood vents
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
