Old 09-18-2017, 02:45 PM   #2507
StraightOuttaCanadaEh
Wes
Originally Posted by Xxyion View Post
I ran this SC with stock Headers and JDL Ultra quiet FP.
I managed 240 whp on 91 Octane.
As far as your noise worries. The stock FP is going to be the most quiet. If you change it even to a High Flow Cat it WILL be louder than the stock one. Not by much but it was noticeable to me (i'm back on stock fp right now).
Thanks! Did you do a baseline dyno prior to the s/c?
Old 09-18-2017, 08:12 PM   #2508
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
I didnt but my friend with just a Greddy RS exhaust did a pull that same day on his FRS. It was automatic so we assumed it was 10 whp lower. It ran a 150 whp.
So we calculated that we had anywhere between a 90-100 whp gain over stock.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
The Following User Says Thank You to Xxyion For This Useful Post:
StraightOuttaCanadaEh (09-18-2017)
Old 09-26-2017, 02:38 PM   #2509
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
I don't know. You'll have more gains with an uncatted header + stock FP, than two aftermarket cats. Two aftermarket cats is not very efficient for eliminating smell OR gaining power, and isn't something I've seen tested.
Totally theoretical, but I've got catless headers + custom (resonated) headerback. What sorta HP can I expect with the edelbrock kit. Rest is stock basically - aside from a flexfuel kit.
I like driving!
86 South Africa is offline   Reply With Quote
Old 09-26-2017, 03:28 PM   #2510
CSG Mike
CSG Mike's Avatar
anywhere from 245whp to 295whp.
Depends on your exhaust setup.
I can't get specific unless you get specific.
86 South Africa (09-27-2017), coxxoc (07-10-2018)
Old 09-26-2017, 04:40 PM   #2511
Randoman5
How specific can you get?
Say E-Force, Delicious tune, D-Box, 93 Octane, Nameless header back exhaust w/ high flow cat, stock exhaust manifold.
Randoman5 is offline   Reply With Quote
Old 09-26-2017, 05:53 PM   #2512
CSG Mike
CSG Mike's Avatar
290whp Nameless headers are discontinued though...
Old 09-27-2017, 01:08 PM   #2513
Randoman5
Thanks!
I'm leaving the stock exhaust manifold because the car is as loud as I want it and because of emissions. If it weren't for emissions I'd probably go turbo instead, but that doesn't really seem to be a viable option unless I plan to uninstall it every two years to pass Ohio E-Check.
That being sad I like the Edelbrock kit. Seems way overbuilt for the application and that gives me confidence in terms of heat management and longevity.
BTW I'm new here. How do I thank a post?
The Following 2 Users Say Thank You to Randoman5 For This Useful Post:
15limited (09-27-2017), CSG Mike (09-27-2017)
Old 09-27-2017, 01:09 PM   #2514
86 South Africa
Thanks - I know, just wanted sort of "range of expectancy" to play with.
I have a custom headerback with little restriction and a catless header (made by RMS here in SA)... so can't give you much more than that for now.
Otherwise stock.
I like driving!
Old 09-27-2017, 02:17 PM   #2515
CSG Mike
CSG Mike's Avatar
Thanks!
Hit the "thanks" button on the lower right of a post.
Even with the stock header, we can get you to around 265-270whp with supporting mods and a tune.
Add ethanol to that and 300whp on the stock manifold is very possible.
PM me when you're ready to order. That's the best way to say thanks
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
botbs (11-28-2020), nos145 (10-04-2017), OkieSnuffBox (09-27-2017)
Old 09-27-2017, 02:18 PM   #2516
CSG Mike
CSG Mike's Avatar
Otherwise stock.
The header will have a bigger impact by itself, than everything behind the header combined!
Old 09-28-2017, 08:06 PM   #2517
Randoman5
Turns out I need more posts to get the button. You provide a ton of value to this site, when I buy stuff you'll be my first choice. I'll probably ask you a hundred questions though.
The Following User Says Thank You to Randoman5 For This Useful Post:
CSG Mike (09-28-2017)
Old 10-03-2017, 10:51 AM   #2518
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I took a few readings of the heatsoaked manifold (quick 15 minutes run around town) in order to get an idea of where a majority of heatsoak for IATs are coming from. Here's what I've collected. It was about 85 F ambient, sunny, humidity around 80%
MAF Housing
Supercharger
Oil Cooler
Liquid to Air Intercooler
Air Filter Box
Passenger Lower Intake Runner
Passenger Upper Intake Runner
Driver Lower Intake Runner
Driver Upper Intake Runner
Driver Head
Passenger Head
The heating of the filter box and MAF sensor housing are the first two things I'm aiming to work on a solution for. I've heard the gold foil tape doesn't attach well to the type of surface for the airbox and I'm not sure that would help much anyways since most of the air coming in bounces of the high pressure area in front of the radiator. What has everyone else come up with for lower IAT?
B T is offline   Reply With Quote
The Following 2 Users Say Thank You to B T For This Useful Post:
Bonburner (10-17-2017), nos145 (10-04-2017)
Old 10-03-2017, 11:52 AM   #2519
Bfranklyn86
Drives: GT86 Harrop S/C
Are people getting heatsoak IAT issues with this kit are they?
Bfranklyn86 is offline   Reply With Quote
Old 10-03-2017, 12:00 PM   #2520
B T
my measured IAT is always about 25 degrees over ambient, even with the Verus hood vents
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
