Old 06-05-2014, 12:06 PM   #239
DatApex
Drives: 2013 WRB BRZ Limited
Originally Posted by Jason@DSG View Post
I agree, but the increased rate of acceleration is directly correlated to the increase in efficiency in the drivetrain by freeing up weight. It's one of those things, we're saying the same thing but in a different way. You actually don't increase any power by doing lightweight drivetrain parts but it increases the rate at which the engine "works" which results in higher performance (on a dyno, this translates to more power because of the way dyno's measure power)
It's really just a bunch of engineers arguing semantics at this point, heh. But saying that running a lightweight pulley nets you HP gain is categorically false, and the real answer is more complicated.
Let's just agree that it helps and leave it at that.
DatApex is offline   Reply With Quote
Old 06-05-2014, 12:08 PM   #240
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
Definitely!
Jason@DSG is offline   Reply With Quote
Old 06-05-2014, 12:15 PM   #241
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Damned, is it that obvious that I am an engineer?
Old 06-05-2014, 02:03 PM   #242
Okieman
What whp does the BRZ make? If you add 30 hp to the flywheel what will be the increase to your whp? Thanks
Okieman is offline   Reply With Quote
Old 06-05-2014, 02:15 PM   #243
Jason@DSG
Jason@DSG's Avatar
About 160whp OEM (depending on dyno type of course)
http://www.ft86club.com/forums/showthread.php?t=10366
That means 230hp = 185whp
Old 06-05-2014, 02:27 PM   #244
Tainen
Drives: First SWP BRZ-L
I'm guessing a lot of the cost is in the tune R&D. The WHP numbers are lower than other solutions out there, so I'm also guessing it's a pretty safe tune, so they can support it more easily and back their products. The cost of buying from a large aftermarket company I suppose, similar to Cobb for WRXs, Dinan for 3 series, etc. Safe tunes, full support, less whp, more money. Just a different route with different pros and cons.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 06-05-2014, 02:29 PM   #245
ProjectGT86
Drives: Fire Storm Red Slush box gt86/frs
Dyno result on a WRX before and after with OEM versus lightweight crank pulley, 10whp freed up:
http://forums.nasioc.com/forums/show....php?t=1868471
I completely agree you aren't ADDING any power perse, but the engine requires less work when running lighter pulleys (or other lightweight drivetrain parts) freeing up power that was lost due to heavier drivetrain components getting more power to the wheels that was just being lost spinning heavier OEM parts.
Another really popular example, 3000GT's and Stealth R/T switching to PST Carbon or Aluminum Driveshafts. This is pretty much the first mod any of these guys do and as you can see here, 381whp OEM driveshaft and 413whp after (post #4):
http://www.3si.org/forum/f1/pst-1-pi...t-dyno-631730/
That's exactly what I'm saying. No power is added but more of the power being produced at the crank can make it's way to the wheels
ProjectGT86 is offline   Reply With Quote
Old 06-05-2014, 02:33 PM   #246
ProjectGT86
I didn't mean it as net gains, I was rendering to more of the measured power on a dyno,
Old 06-06-2014, 12:18 PM   #247
350matt
Drives: toyota mr2/ Toyota GT86
Originally Posted by Fear View Post
This thread is worthless!!!!!!
Nameless is Cosworth is nameless
Screw Paying more for the name "Cosworth" when the real design is nameless....
support a forum vendor and the original product designer... NAMELESS
except that the Cosworth exhaust looks nothing like the nameless offering
yes they sell a 3" system and the cosworth item is also a 3" system made by nameless
but the amount of silencing is different, the resonator design is different, the overpipe has a cat and catback layout is different
I agree the manifold looks the same though
and if nameless are making the exhaust anyway
so you buy a cosworth item then you're still supporting nameless....
they made it then they get paid by cosworth
350matt is offline   Reply With Quote
Old 06-06-2014, 10:28 PM   #248
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Originally Posted by Bg8780 View Post
I agree. It is a little pricey. But I think about it this way. I've already spent.
JDL UEL, FP with resonator and HFC, and OP: $1800
HKS Legamax Sport exhaust: $1700
ECUTEK cable and tune: ~$1000
That's $4500 right there. Could I go cheaper? Absolutely, but I believe these to be high end parts and so is what Cosworth and Nameless put out. So the extra ~$1000 isn't too crazy to me. Some of that money going to the name? Sure! But I would gladly wear a Cosworth badge on my car. They have a rich and successful racing heritage and have produced some of the most legendary race engines.
Thank you! Everyone is getting so upset that high-end parts aren't priced like low-end parts, by my math the Cosworth is on the order of 50% at most pricier than its competition. Not unexpected, and it's worth mentioning that the cost of parts, and the cost of engineering are not the same thing at all. Some things in this world are quite simply expensive. Geez, how did people react to the TRD stuff?
I'm disappointed in the kit for a different reason: No catalyst, and a lumpy powerband. I should've predicted that Cosworth of all companies would calibrate for the track rather than the street though. Does anyone sell a catted header with a corresponding tune? (totally not rhetorical, please tell me)
Audible sigh...
Originally Posted by MAPerformance View Post
I can tell you the stage 1.3 package is not even close to $6700. It's not cheap either (same price as our turbo kit) but not that expensive.
Oh, you're slick. I like you.
NissanGuy is offline   Reply With Quote
Old 06-06-2014, 10:53 PM   #249
Fear
Drives: Ft86
i like your logic, tell you what...
I'll buy what ever mods you want to do from the vendor of your choice, Write my name on them, charge you a premium for my name + my cost for the parts and we can both be happy
Deal?
Fear is offline   Reply With Quote
Old 06-06-2014, 11:10 PM   #250
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Audible sigh...
People are upset that branded parts like the Nameless header and Ecutek tuning that are exactly the same as Cosworth's package but cost substantially less.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 06-07-2014, 12:14 AM   #251
s2d4
s2d4's Avatar
Originally Posted by Apoc View Post
Please are upset that branded parts like the Nameless header and Ecutek tuning that are exactly the same as Cosworth's package but cost substantially less.
Header, perhaps. Tune, not so much.
The cosworth name was showm to be about 600 more than what nameless is charging but cbe is different. Seems normal really, companies do this all the time. Not everything in our car is manufactured by Toyota.
Old 06-07-2014, 05:45 PM   #252
P86RAVES
Drives: 08 WRB WRX STi / NA Miata
That seems closer to the loss for AWD
I'm thinking 195 (@ 15% instead of 20%)
It's based on a RWD Corolla, what do you expect?
P86RAVES is offline   Reply With Quote
Vortech SC + Vishnu OFT300 power package Garrett@Openflash Forced Induction 22 03-15-2016 12:04 PM
DeatschWerks Power Package available at RallySport Direct! RallySport Direct Engine, Exhaust, Bolt-Ons 1 11-27-2013 07:51 PM
MAGNAFLOW CATBACK + AFE POWER/INJEN INTAKE PACKAGE DEAL!!! NJA Engine, Exhaust, Bolt-Ons 5 12-11-2012 09:05 PM
