Old 11-10-2013, 11:19 AM   #239
vynervt
Drives: GT-86
Originally Posted by 8686 View Post
Have these changes been applied to the K series version I recived from you through email? Because I didnt see the ZA1J700K in the download file,
Thanks again for your kind support
8686, Are you kind enough to share me the ZA1J700K???? i have sent stock ROM 2 different series ZA1J700K & ZA1J700J by email to vishnu but don't know when Vishnu side will update me.
vynervt is offline   Reply With Quote
Old 11-10-2013, 12:47 PM   #240
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
I'm not an expert here on tuning by no means, but just to add my experience with 1.33 maps. Right after flashing when I had the car idle a bit and close all the windows, I can hear a knocking. Not sure if this is the "knocking" you guys are talking about, but it didn't exist in 1.31.
This is at idle. I'm going to flash back and see if I hear it, but yeah it's really strange now when I sit in the car, I know for a fact that it was not there previously.
A little extra info:
The engine is completely cold, I didn't start it for 2 days, started the engine up, turned off the engine but left it at on, flashed from 1.31 to 1.33. Turned the engine on after flashing succeeded. closed all my doors so I can let the car idle, and as the RPMs began to warm up the car, you can hear this knocking sound above the engine's normal whine and belt noises. just a constant knock in an interval of just a little under 1 second.
Not sure if this was described by anyone, but i'm going back to 1.31 and see what's up. (my 1.31 is when it was still 1.31b -- if it makes a difference).
Edited:
1.31 and 1.31b has no difference, same date
Will reflash and report my findings within 20-30 mins.
CamryDS is offline   Reply With Quote
Old 11-10-2013, 01:13 PM   #241
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
K series tuned rom support should be available by the end of the day tomorrow.
Old 11-10-2013, 01:19 PM   #242
Shiv@Openflash
Drives: 2013 FRS
Edited:
There are no changes in the mapping that would cause any difference in engine sound. What you are likely hearing is just the normal sounds of a direct injection system. I think you, like many others, are just listening more closely to things now.
Old 11-10-2013, 01:24 PM   #243
peri.Laynz
Drives: 2014 Whiteout M/T
Placebo effects are running rampant in this thread!
peri.Laynz is offline   Reply With Quote
Old 11-10-2013, 01:48 PM   #244
CamryDS
Probably, just reporting my findings. Back at 1.31b and at idle there isn't anything, I'm going to go over and re-flash once more.
Though I did hear a difference. At first I thought maybe the clutch (since the transmission has a bit of movement) so I clutched down. no difference. I'm going to reflash once more.
Your responses are always appreciated =) Not knocking anything, just going to re-test.
You make a good point, just testing again to verify =)
-- edited --
I just finished re-testing 1.33b, but I may stick with 1.31. Even after the pedal checks for both, the 1.31 had better pedal response. Other than that, engine sounds the same again. Must have been due to the engine being extra cold over 2-3 days. After being around the block it's back to normal.
Old 11-10-2013, 03:08 PM   #245
Mixlplix
Originally Posted by cnk View Post
Did you even bother to read the first post? Dyno graphs are posted there.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Ya bubba i saw them but apparently u didnt look too close at them nor did u pay attention to my question. Now go look real close again and then read my question and see why u shouldnt have opened your mouth.
Mixlplix is offline   Reply With Quote
Old 11-10-2013, 04:35 PM   #246
cnk
Drives: '13 DGM BRZ Limited
Sigh. . didn't realize we were on a Nascar forum with the "bubba" comments. In any case, since it appears you didn't want to search or to correlate information from different posts/threads, here's a thread that provides dyno charts with gains comparing stock vs Vishnu OFT tunes. The only modification is a muffler delete which makes this comparable to a bone stock car: http://www.ft86club.com/forums/showthread.php?t=4700
cnk is offline   Reply With Quote
Old 11-10-2013, 06:12 PM   #247
8686
8686's Avatar
Drives: 86
Does this include XDF file to use the tunerpro
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 11-10-2013, 06:14 PM   #248
Shiv@Openflash
Drives: 2013 FRS
Yes there will be an XDF released as well. Not all the tables will be defined. Just the ones that are useful for most tuning work. I do all the XDF work manually so going through the entire list of tables takes a huge amount of time.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
8686 (11-11-2013)
Old 11-10-2013, 06:26 PM   #249
Cross
It's the Mad Cow
Cross's Avatar
Thank you for the reply and I agree when trying to color smoke at times you can confuse the but this did give the smell of rich too but a catch can is never a bad idea so I agree trying that first is not a bad idea at all. Thank you for getting back to me on it.
On a side note could you pm me if it's easier on my maf scaling question regarding the air raid vs stock. I just want to know your thoughts and what if any changes should be made.
Thanks again.
Old 11-10-2013, 09:32 PM   #250
3essess
Drives: frs
I had to rescale my OFT tune for my intake too but before I did I also looked at the OFT Airaid tune for reference and that one didn't have the MAF rescaled which I thought was different. I guess you can change the fueling to get to the same place? If you get a reason from Shiv can you post or forward pm to me - thanks.
3essess is offline   Reply With Quote
The Following User Says Thank You to 3essess For This Useful Post:
Cross (11-10-2013)
Old 11-10-2013, 09:48 PM   #251
Shiv@Openflash
Drives: 2013 FRS
When datalogging is enabled, it will be reasonably easy to rescale the MAF sensor to work with whatever intake you want. I'll go over that in a how-to thread when that time comes. Since I don't have the time to create custom MAF sensor tables for all the available sensors, I am only able to support the stock intake box at this time. But when modified (drop in foam filter and modified duct), it outperforms every other intake I've tested thus far in NA application.
Shiv
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
3essess (11-10-2013), Mike86 (11-11-2013)
Old 11-10-2013, 10:22 PM   #252
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
Got my OFT in the mail about a week ago and installed the v1.33 (beta) Stage 1 Map (A01C) a couple of days ago. Once I get a few more driving cycles in with it, I'll post up my butt dyno results.
Hanni_0176 is offline   Reply With Quote
The Following User Says Thank You to Hanni_0176 For This Useful Post:
Shiv@Openflash (11-10-2013)
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
anyone trying to use the openflash tablet with forced induction? FRSTEVE Software Tuning 69 12-07-2014 04:07 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
