#239 | |
Drives: Vortech Supercharged M6 FR-S UM
As stated by another member, CARB certification does emanate from the California based agency, but has been adopted by several other states as their guidelines as well. The certification process is lengthy and expensive, but we've never had any trouble being granted an E.O. on any system we set out to get one on. The FT86 system should be less complicated than others, considering none of the factory fuel components are required to be changed or upgraded. We have applied, so the process has begun. All complete systems sold prior to CARB approval are retroactively covered once the E.O. is issued. |
| The Following 2 Users Say Thank You to Brian@Vortech For This Useful Post: | Fly Guy (04-13-2013), Huehuecoyotl (04-09-2013) |
#240 | |
Drives: DGM BRZ Limited
#241 |
#242 |
Drives: 2013 SWP BRZ
I couldn't imagine it having an effect on the OBDII like that. It would be the same if you had a regular EcuTek tune. As long as codes are cleared, readiness should be fine.
Even if Vortech's mapping had codes shut off, it still wouldn't effect anything. When I had Hydra in my STi, I had an opensource tune done to my stock ecu that cleared all codes and the readiness so I could just literally plug it in and pass emissions. |
#243 | |
Automotive Connoisseur
Drives: too many cars
Readiness should all be good to go.
LSx Powered 86/ASE Master Certified Automotive Technician
#244 |
Drives: GT86
@Brian@Vortech
Can you confirm this is the compressor map for the latest compressor supplied with the kit? ![]() If so it appears that this supercharger may be able to flow up to 400bhp or so on a 2 litre engine. Assuming the engine is built/tuned correctly, would you support/warrant use of this package at boost levels as high as 1.0-1.2 bar on the FA20? It doesn't appear that it would be over-speeding according to this graph. Thanks! |
#245 | |
#246 |
Drives: GT86
#247 |
http://www.ft86club.com/forums/showthread.php?t=34171
Looks like that's with the 12psi pulley & e85 so yes it looks like this kit definitely supports 400bhp! And that's warranted I believe, is that correct Vortech? ![]() ![]()
#248 | |
SLO NO MO
#249 |
Drives: GT86
Yeah, my power figure was based on pump fuel, which would be pushing this charger going by that graph.
#250 |
Ah, I see.
#251 |
#252 |
Drives: Forced Induction and LSx Swaps!
Brian, I just had a nerdgasm looking at that compressor map. For a small-displacement engine, that is BEAUTIFUL! That 70% island is huge!
ft_sjo, 45 or so lbs/min at 14-16psi looks great, but remember that boost is a measurement of how much more air the compressor is moving than the engine can ingest, and judging from the numbers we're seeing I think the only way to hit that kind of actual pressure ratio on the FRS/BRZ would be to overspin the blower. Pulley the blower to stay under max RPM at redline and whatever boost reading you've got is what you've got. Back to my lunch...
| Vortech Supercharger | denverizzles | Forced Induction | 176 | 10-19-2013 07:48 PM |
| New Vortech Supercharging System Information... | Brian@Vortech | Forced Induction | 306 | 11-08-2012 06:49 PM |
| Supercharging the GT86 | Billy2224 | Engine, Exhaust, Transmission | 13 | 06-05-2012 04:58 PM |
| Turbo/Supercharging Your FRS | BoostJunkie | Engine, Exhaust, Transmission | 123 | 05-18-2012 07:26 PM |
| Supercharging: the forgotten form of FI | madfast | Engine, Exhaust, Transmission | 76 | 03-02-2012 06:06 PM |
