Old 04-09-2013, 12:20 PM   #239
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
Originally Posted by ohday View Post
I'm very interested in this as well. I know it's probably much to early to say, but do you know when a decision would be made as to whether the MAF extension harness will be made?
Can you educate me on the CARB certification? As I understand CARB is a California agency. How does CARB certification affect or play a role in other states? Is the complete kit currently street legal in all states other than California? If not, will it become street legal once certification is given?
Thanks!
As soon as I know about the MAF harness, I will pass on the information. Promise!
As stated by another member, CARB certification does emanate from the California based agency, but has been adopted by several other states as their guidelines as well. The certification process is lengthy and expensive, but we've never had any trouble being granted an E.O. on any system we set out to get one on. The FT86 system should be less complicated than others, considering none of the factory fuel components are required to be changed or upgraded. We have applied, so the process has begun. All complete systems sold prior to CARB approval are retroactively covered once the E.O. is issued.
Brian@Vortech is offline   Reply With Quote
The Following 2 Users Say Thank You to Brian@Vortech For This Useful Post:
Fly Guy (04-13-2013), Huehuecoyotl (04-09-2013)
Old 04-09-2013, 06:02 PM   #240
ohday
Drives: DGM BRZ Limited
Awesome. Thanks for the info about CARB!
ohday is offline   Reply With Quote
Old 04-10-2013, 01:39 PM   #241
2forme
Originally Posted by Huehuecoyotl View Post
will do..
Did you ever get around to testing this yesterday, Gem?
Old 04-10-2013, 01:58 PM   #242
xxscaxx
Drives: 2013 SWP BRZ
I couldn't imagine it having an effect on the OBDII like that. It would be the same if you had a regular EcuTek tune. As long as codes are cleared, readiness should be fine.
Even if Vortech's mapping had codes shut off, it still wouldn't effect anything. When I had Hydra in my STi, I had an opensource tune done to my stock ecu that cleared all codes and the readiness so I could just literally plug it in and pass emissions.
xxscaxx is offline   Reply With Quote
Old 04-10-2013, 02:05 PM   #243
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
^^^ This
Readiness should all be good to go.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 04-19-2013, 12:25 AM   #244
ft_sjo
Drives: GT86
@Brian@Vortech
Can you confirm this is the compressor map for the latest compressor supplied with the kit?
If so it appears that this supercharger may be able to flow up to 400bhp or so on a 2 litre engine. Assuming the engine is built/tuned correctly, would you support/warrant use of this package at boost levels as high as 1.0-1.2 bar on the FA20? It doesn't appear that it would be over-speeding according to this graph.
Thanks!
The Following 2 Users Say Thank You to ft_sjo For This Useful Post:
charged86 (04-19-2013), Sonolin (04-19-2013)
Old 04-19-2013, 10:57 AM   #245
Brian@Vortech
Originally Posted by ft_sjo View Post
@Brian@Vortech
Correct. This compressor map is for the H67B compressor that is currently being included in all of the FR-S/BRZ systems.
Old 04-19-2013, 11:51 AM   #246
ft_sjo
Drives: GT86
Thanks. Did you see my other questions?
Old 04-19-2013, 01:26 PM   #247
Sonolin
http://www.ft86club.com/forums/showthread.php?t=34171
Looks like that's with the 12psi pulley & e85 so yes it looks like this kit definitely supports 400bhp!
And that's warranted I believe, is that correct Vortech?
Sonolin is offline   Reply With Quote
Old 04-19-2013, 02:32 PM   #248
Foobar
SLO NO MO
Foobar's Avatar
I think he's asking if Vortech would still warranty the device operating at 1-1.2 bar (roughly 14.5-17.5 PSI).
Old 04-19-2013, 02:44 PM   #249
ft_sjo
Drives: GT86
Yeah, my power figure was based on pump fuel, which would be pushing this charger going by that graph.
Old 04-19-2013, 02:48 PM   #250
Sonolin
Ah, I see.
Old 04-19-2013, 03:27 PM   #251
Brian@Vortech
As long as the supercharger is not being spun beyond the impeller speed max for the particular unit, it should be fine.
Old 04-19-2013, 07:13 PM   #252
JordanInnovations
Drives: Forced Induction and LSx Swaps!
Brian, I just had a nerdgasm looking at that compressor map. For a small-displacement engine, that is BEAUTIFUL! That 70% island is huge!
ft_sjo, 45 or so lbs/min at 14-16psi looks great, but remember that boost is a measurement of how much more air the compressor is moving than the engine can ingest, and judging from the numbers we're seeing I think the only way to hit that kind of actual pressure ratio on the FRS/BRZ would be to overspin the blower. Pulley the blower to stay under max RPM at redline and whatever boost reading you've got is what you've got.
Back to my lunch...
JordanInnovations is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
