Old 06-15-2018, 12:30 PM   #239
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Does anyone have a better picture of the location of the underside plugs?
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 06-19-2018, 12:42 PM   #240
Impureclient
Drives: 2015 FR-S
Were these installed in the later model cars?
Impureclient is offline   Reply With Quote
Old 06-19-2018, 11:03 PM   #241
norcalpb
norcalpb's Avatar
Maybe the lower ones by your dealer, but the upper ones is just someone measuring the hole at 1.5” hole (37mm) and shoving a 40mm plug in there.
Old 06-19-2018, 11:04 PM   #242
norcalpb
norcalpb's Avatar
If you have the JDM underbody panels it is literally right between the rear jack stand point and the panel itself.
Old 06-28-2018, 04:35 PM   #243
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Well, I figured since I have a 2016 I would have these plugs installed. Wrong. Now I just bought the last set of rocker plugs on ebay and still need to hunt down some strut plugs.
Trueweltall is offline   Reply With Quote
Old 07-26-2018, 03:06 PM   #244
Trueweltall
If anyone is looking for the frame rail plugs that are near the rear tires look under your spare tire. I had already purchased and installed some, taking my rear trunk apart to do new suspension and I found the pair that came with the car sitting under the spare tire.
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 02:56 PM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 02:57 AM
Impressive boot space! BD AUSTRALIA 14 08-24-2012 04:30 AM
Fatal FRS Flaw!! Skin Scion FR-S / Toyota 86 GT86 General Forum 4 07-12-2012 04:21 PM
Pics of rear passenger area with plastic removed JRitt Cosmetic Modification (Interior/Exterior/Lighting) 20 06-12-2012 08:17 AM
