Old 04-09-2015, 04:17 AM   #2465
steve99
Originally Posted by gepeyo View Post
So I received my OFT from a friend who unmarried the OFT from his car and I erased the file off the OFT before i used it on my car. As i did the first read with my OFT the screen and it seemed to had saved all the way. But suddenly turns into numbers with an okay box under it. I ended up unplugging the OFT because the message kept coming up over and over and over again giving me a "6041". As i plugged the OFT back into the car it was only able to write (the read option was greyed out) so i tried stage 1 tuning and it worked out successfully. I thought I should of tried tuning my car back to original after driving my car for a while and when i tried to go back to original the OFT said there was an error and reseted and suddenly the car info said i was at original save. I got worried that my OFT corrupted my original tune file, so i retuned it back to Stage 1 and left it as is and came here to see if theres anyone whose experience this or what i should do.
Sounds a bit suspect.
I would talk to the openflash guys on the phone
does the car run ok when you wrtite the original file ?
If so write the original file back to car . make sure it runs ok.
Then erase oft using ofm and start from scratch again. ie read original file ect.
But talk to the openflasdh guys first.
Old 04-20-2015, 04:50 AM   #2466
86Tony
Drives: 2015 AOZORA EDITION
Hey guys I'm from Canada I use 94 petro here what map do I run also mines a 2015
86Tony is offline   Reply With Quote
Old 04-20-2015, 07:44 PM   #2467
troek
troek's Avatar
Drives: 2012 Toyota 86
try the 93 map, do some logs and see how it runs.
Old 04-21-2015, 10:06 AM   #2468
RFB
RFB's Avatar
Drives: FRS
93 toon, Pierre Elliot Trudeau Ripped Off CANada 94 octane corn piss, catted header, cat back.
Runs fine, but once in a while it needs a tiny shot of Torco iff'n I get some bad socialist gas.
I found it was a rare occurrence (so far) as I monitor knock closely.
When I use real 94 (mix - Sunoco 91 and race gas, using no ethanol) the car shows similar knock characteristics, but butt dyno and xhaust sound (smoother, louder, change in pitch) indicate to me and others who have tracked my twin that mo powa is being generated.
I have tried our pure gas (Sunoco 91 without alcohol) and brought the octane up to varying levels, and that accomplishes the same thing. I do that when pure hi-octane race gas is unavailable.
Placebo perhaps but I doubt it .
When I get some spare sheckels I'll add them to the rubles that are left over from track fees, waste it on a dyno and see the real numbers.
RFB is offline   Reply With Quote
Old 06-06-2015, 09:26 PM   #2469
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
Oh look another bugged-up thread (shows 114 pages, but trying to load page 114 redirects back to 113). :/
SilverlightPony is offline   Reply With Quote
Old 06-06-2015, 10:12 PM   #2470
jdcorbitt3
jdcorbitt3's Avatar
Drives: 2013 red FR-S, OFT. 2000 Miata SE
Originally Posted by Grip Ronin View Post
quick question. when logging injection mode is (1) port only, (2) direct only and (3) blended???
I have been wondering the same thing. I never found an answer.
John
2013 firestorm FR-S OFT, OFH, U-Haul Trailer Hitch
2007 Stormy Blue Mica PRHT GT NC Miata, OFT
jdcorbitt3 is offline   Reply With Quote
Old 06-06-2015, 11:52 PM   #2471
troek
troek's Avatar
its been covered a few times in the forums, i cant seem to find it now though lol. i think maybe in the maf scaling tutorial..
Old 06-07-2015, 12:34 AM   #2472
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
MAF Correction After Start AT/MT difference.
Could the difference in these tables account for the wildly different MAF behavior between AT and MT?
OTS MT with OTS MAF scale and stock intake AFR behavior:
http://datazap.me/u/deanveljkovic/86...2657-2699-2677
OTS AT with OTS MAF scale and stock intake AFR behavior:
http://datazap.me/u/wayne/206-stg2-u...1330-1354-1371
The MT seems to cross over into each MAF cell about 200rpm later. Could these tables be why I've been chasing my tail for months? Or is this wishful thinking as these tables are only used in idle/start/etc and need to just work around it. I've never seen an AT with flat AFR curve on OTS tune like MT's have.
After updating to Td-d's latest definitions instead of using the ones from openflash, you can clearly see this is the only major difference defined between AT and MT that could possibly effect AFR's.
@Td-d
@steve99
@Shiv@Openflash
@Kodename47
Old 06-07-2015, 01:10 AM   #2473
steve99
@Wayno , i am pretty sure those maf offset tables only effect maf offset after start and once startup sequence comple no further effect , although only the rom gurus would know 100%.
might be difference in maf sensor itself ,my car always runs pig rich on oft tunes mine ran 11.2 on e85 tunes just flatlined at rich limit of sensor like some others, where as other cars run closer to the ol fuel table like yours, seen it in usa guys cars as well some run rearly rich some dont.
the ones that run rearly rich can get that low rpm high load bogging issue
it could also be 02sensor placement issue on aftermarket headers
Old 06-07-2015, 01:23 AM   #2474
Wayno
Wayno's Avatar
It's not so much that it runs rich or lean, it's just that it goes super rich at 3.2v, then ok at 3.4v, then rich by 3.9, then super lean at 6400rpm at 4.06v, then finally super rich in the same MAF cell, doesn't matter how much you let it adapt, it always goes from 12.5 to about 11.5 in one cell.
Old 06-07-2015, 01:42 AM   #2475
steve99
I believe the is an Engine Load Compensation table EL Comp, i have not used it but @ztan and @MFB have mentioned using it, i believe to sort out those kind type of issues
Old 06-07-2015, 02:00 AM   #2476
Wayno
Wayno's Avatar
Yep, I've seen that but 4800rpm and above is all zero'd on AT and MT. Trying to find an obvious cause rather than work around it. I have 3 4th gear dyno graphs of AT cars with the exact same shape. 3.7 gets rich, 3.9 gets super rich, 4.0 gets super lean then super rich again. MT on the other hand is usually flat, still shitty rich and inconsistent, but flat.
Old 06-07-2015, 02:05 AM   #2477
steve99
yep thats weird pretty much out of ideas
Old 06-07-2015, 02:10 AM   #2478
Wayno
Wayno's Avatar
Yeah apart from the box itself and the ecu, there's nill hardware differences, so has to be something software related.
I'll switch to the MT MAF comp table and test it today.
I should also mention the same difference in behavior is at the same intake temp for both AT and MT.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
