, dpfarr
Old 08-15-2017, 01:29 PM   #2451
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Even if it's 70 lbs that's <3% of the total weight of the car, I'd be surprised if the c.g. moved more than 0.2" by adding any supercharger in any location.
That might very well be true. Was just guesstimating for worst case
Old 08-15-2017, 02:37 PM   #2452
Dan37BRZ
Senior Citizen
Drives: 2015 WRB BRZ
Question for those of you who run this kit:
Has it altered the handling characteristics of the car at all? I am aware that the kit weighs roughly 80 lb, and recently I saw a video on youtube (his username is Law) where the guy actually took off his Edelbrock and decided to go down NA route cause he didn't like what it did to the car. He didn't really elaborate, for whatever reason, so I thought I'd ask you guys. Is there a palpable change in handling characteristics?
Definitely not 80lbs, 60lbs sounds about right, after deducting for all the stock parts you won't reuse which is probably 15lbs of OEM stuff, I'd say more like 45lbs total added.
In my particular situation, I've added an HKS EL header (saves 7lbs) and will be adding a 5lb Shorai Lithium Iron battery(saves 25lbs) which saves me about 32lbs over stock. So in total, I've only added roughly 13lbs of net weight after my deductions.
Dan37BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to Dan37BRZ For This Useful Post:
funwheeldrive (08-16-2017), StraightOuttaCanadaEh (08-15-2017)
Old 08-15-2017, 02:48 PM   #2453
Dan37BRZ
Senior Citizen
Regarding Law's experience with his supercharger, my impressions after the Edelbrock kit is probably the exact opposite of his.
The car feels exactly the same as before in the handling department, the same tossable charm and I didn't notice any extra weight in the front. In fact, I think it feels a lot livelier and lighter now because of the extra power. In stock form, the car feels lethargic and lazy to get up to speed, now it feels very energetic and willing to play all the time.
In one of his videos, he says the car feels like it's about to explode in the upper revs and he feels the engine moves around a lot more. After experiencing none of that, I'm questioning if his kit was installed properly or maybe he received a defective kit.
In fact, after the kit, the engine feels a lot smoother in both sound and feel. Here is a quick 20-110mph pull.
The Following 4 Users Say Thank You to Dan37BRZ For This Useful Post:
brzaapi (08-15-2017), CallmeDave (04-02-2019), CSG Mike (08-15-2017), StraightOuttaCanadaEh (08-15-2017)
Old 08-15-2017, 03:26 PM   #2454
Wes
Thanks everyone for your replies. It is on my wish list, and I'm just waiting for the 2017 specific version to be released, as well as my savings to reach the appropriate level of course lol, so a few comments here and there spooked me a little and I wanted to clarify just to make sure these are isolated cases and personal opinions/preferences.
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 08-15-2017, 03:28 PM   #2455
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
I concur.....On the road you can not feel any difference in handling. The rear isn't more unsettled because of the extra weight in the front. The car doesn't understeer any differently because of said weight. In fact the car feels very much like a stock BRZ with more power. And after modding several cars, that is a nice discovery. Usually, while modding you lose some of the OEM character that drew you to the car to begin with.
As for handling on the road I don't see where the EBSC causes any compromises in handling. On the track, I can't say for sure. But, if you are feeling a handling difference after installing the EBSC there is another problem most likely or its a placebo.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
The Following 6 Users Say Thank You to brzaapi For This Useful Post:
86 South Africa (08-19-2017), CallmeDave (04-02-2019), CSG Mike (08-16-2017), Dan37BRZ (08-15-2017), StraightOuttaCanadaEh (08-15-2017), strat61caster (08-19-2017)
Old 08-15-2017, 11:34 PM   #2456
gtengr
Drives: 2017 BRZ
The kit weighs 81 lbs per a shipping scale from this post (http://www.ft86club.com/forums/showp...&postcount=124).
I'm guessing I subtracted the aluminum intake from the '17 to get 62.5 lbs net.
gtengr is offline   Reply With Quote
The Following 2 Users Say Thank You to gtengr For This Useful Post:
StraightOuttaCanadaEh (08-15-2017), WRBrzRX (08-16-2017)
Old 08-16-2017, 11:19 AM   #2457
toast
Drives: 14 BSP Edelbrock BRZ
So the box and crate that the unit ships in gets installed in the car too?
toast is offline   Reply With Quote
Old 08-16-2017, 12:55 PM   #2458
WRBrzRX
Drives: runs&drives
In the post everything is weighed out separately then added together. Not to be a ****penis but did you even look at the link provided to you?
WRBrzRX is offline   Reply With Quote
The Following 2 Users Say Thank You to WRBrzRX For This Useful Post:
gtengr (08-16-2017), Icecreamtruk (08-18-2017)
Old 08-16-2017, 04:33 PM   #2459
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Originally Posted by paiceyfan View Post
Check my posts...the OBDII dongle was draining my battery. Since removing, I have had zero issues for a couple of weeks now. Very similar symptoms to yours. I could not believe that it would have such a major effect on the running of the car, but evidence would say otherwise.
Sent from my Moto G (5) Plus using Tapatalk
OK, I am back. I had the car sit for a week while I traveled and the issue is back. I fiddled under the hood with all connections and now it's back to normal...really frustrating. I wonder if it is a connection after all, but the symptoms are so strange.
I will keep you updated...
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 08-18-2017, 01:54 PM   #2460
toast
No. I read the '17 as 17# and thought the weight he came up with was 81 pounds minus 17 pounds. Apologies.
Old 08-19-2017, 06:41 AM   #2461
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
True enough but adding weight is still one of the downsides.
I like driving!
86 South Africa is offline   Reply With Quote
Old 08-24-2017, 08:24 PM   #2462
Zut
Drives: 2013 FRS
Got my kit tuned earlier this week at Turn-In Concepts. Guys there were really on top of their game and did an excellent job.
I'm running the Edelbrock S/C, catless JDL EL header, Motiv O/P, JDL UQFP, stock cat back, JR Dual radiator & oil cooler, and Radium PCV catch can.
On 93 pump gas, car pulled 278whp on their DynoDynamics dyno (~17% less than a DynoJet according to the shop). Stock FRS pulls ~140 on their dyno so not too shabby.
Power is insane throughout the whole range now and all of the idiosyncrasies of the Edelbrock tune are gone. Only problem is, I ran out of fuel capacity around 6500RPM so it runs poor above that. Onto bigger injectors and pump
Post dyno chart is attached. Didn't get the pre tune chart.
Zut is offline   Reply With Quote
The Following 2 Users Say Thank You to Zut For This Useful Post:
djdnz (08-30-2017), nos145 (08-29-2017)
Old 08-30-2017, 10:26 PM   #2463
georgiafrsguy
Drives: white 2013 frs
awesome numbers. that's about max you can get out of 93. I did 275 on my retune. buy you should not have ran out of fuel. I had no issue about 6500. there may be some other issue goin on. you shouldn't need a bigger pump and injectors unless goin e85 or smaller pulley. ill try to dig up my chart
georgiafrsguy is offline   Reply With Quote
Old 08-31-2017, 07:08 PM   #2464
Dan37BRZ
Senior Citizen
Hey guys so I've ran into this random issue twice now. Taking off hard and redlining all the gears, shifting as quick as possible, car would lose power as soon as I hit 3rd. Doesn't bog or anything, just feels like the car stops making boost. This has happened only twice, once when trying to merge onto the freeway and today while racing a modded Golf R.
Unfortunately I wasn't logging when this event happened. Traction and VSC were both turned off.
Anybody having anything similar to this happening?
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
