#2451 | |
"Error in opening file"
#2452 |
#2453 |
#2454 |
Drives: '22 BRZ
Having an issue with OFM 1.18.4... I simply can't open a log of ~45 minutes of driving. The part that renders the spreadsheet style table in OFM simply doesn't load and OFM just hangs forever. Any other way to retrieve the log? I'd like to just disable the pretty much pointless spreadsheet view in OFM...
#2455 | |
Once the oft has updated itself via new oft the old log is toast. Just delete the old log don't try to display it. |
#2456 | |
Drives: '22 BRZ
I can't delete it because as soon as I click the log to select it OFM hangs up. I guess I could click delete in that couple of second window while it's reading but I was on a laptop and I'm not fast enough with the touchpad, lol. The point still stands, I've made logs that long before, no reason I shouldn't be able to do it now. @Shiv@Openflash, any suggestions? |
#2457 |
Drives: White Series.Blue
D00C lc and ffs when?
| The Following User Says Thank You to Mufasah For This Useful Post: | cameronjones239 (04-07-2015) |
#2458 |
Drives: '22 BRZ
@Shiv@Openflash
I made another log today that I can't open. Can we please get a fix for this so I can get reasonable sized logs for maf scaling? |
#2459 | ||||
Some Dumb Guy
Drives: wanting an Acabian
As I recall, after about some newer updates, log files can only be record for about 20 minutes. Multiple files, but 20 minutes each. Correct me if I'm wrong, but this is could be the root of your problem.
She said it was her or the car. Longest
she had ever seen. |
| The Following User Says Thank You to Blu-by-U For This Useful Post: | DocWalt (04-07-2015) |
#2460 |
Drives: '22 BRZ
If that's the cause that's fine. I didn't see any mention of that, but I didn't read every post of every thread. I saw that the maximum memory is 60 minutes, which is fine, but I didn't see a per log limit.
#2461 |
The Mechanic
Drives: Civic Turbo,FR-S
quick question. when logging injection mode is (1) port only, (2) direct only and (3) blended???
#2462 | |
Some Dumb Guy
Look here http://www.ft86club.com/forums/showp...9&postcount=14
#2463 | |
Drives: '22 BRZ
#2464 |
Opal86
Drives: 2013 10 Series #Opal86
So I received my OFT from a friend who unmarried the OFT from his car and I erased the file off the OFT before i used it on my car. As i did the first read with my OFT the screen and it seemed to had saved all the way. But suddenly turns into numbers with an okay box under it. I ended up unplugging the OFT because the message kept coming up over and over and over again giving me a "6041". As i plugged the OFT back into the car it was only able to write (the read option was greyed out) so i tried stage 1 tuning and it worked out successfully. I thought I should of tried tuning my car back to original after driving my car for a while and when i tried to go back to original the OFT said there was an error and reseted and suddenly the car info said i was at original save. I got worried that my OFT corrupted my original tune file, so i retuned it back to Stage 1 and left it as is and came here to see if theres anyone whose experience this or what i should do.
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 12:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
