Old 04-05-2015, 08:51 PM   #2451
mission2toilet
mission2toilet's Avatar
Download the OFM update manually from openflash site and template file
Delete the openflash folder completly to remove old or corrupted ofm software
reinstall ofm from manually downladed update.
connect oft let it update
install latest template filed downloaded previously
I reinstall the file from their web but still says same thing..
"Error in opening file"
mission2toilet is offline   Reply With Quote
Old 04-05-2015, 09:51 PM   #2452
steve99
Drives: FT86
Only thing left would be turn off antivirius\firewall while oft updates then turn back on. if that does not work contact oft guys directly by email or phone.
Old 04-05-2015, 10:02 PM   #2453
mission2toilet
Thank you for your concern. Look like I have to call them..
Old 04-05-2015, 10:37 PM   #2454
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Having an issue with OFM 1.18.4... I simply can't open a log of ~45 minutes of driving. The part that renders the spreadsheet style table in OFM simply doesn't load and OFM just hangs forever. Any other way to retrieve the log? I'd like to just disable the pretty much pointless spreadsheet view in OFM...
Old 04-06-2015, 12:38 AM   #2455
steve99
Drives: FT86
The new logs are different format to old logs so not interchangeable.
Once the oft has updated itself via new oft the old log is toast.
Just delete the old log don't try to display it.
Old 04-06-2015, 08:41 AM   #2456
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I made the log yesterday immediately after updating everything....
I can't delete it because as soon as I click the log to select it OFM hangs up. I guess I could click delete in that couple of second window while it's reading but I was on a laptop and I'm not fast enough with the touchpad, lol.
The point still stands, I've made logs that long before, no reason I shouldn't be able to do it now.
@Shiv@Openflash, any suggestions?
Old 04-06-2015, 04:41 PM   #2457
Mufasah
Mufasah's Avatar
Drives: White Series.Blue
D00C lc and ffs when?
Mufasah is offline   Reply With Quote
The Following User Says Thank You to Mufasah For This Useful Post:
cameronjones239 (04-07-2015)
Old 04-07-2015, 06:06 PM   #2458
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
@Shiv@Openflash
I made another log today that I can't open. Can we please get a fix for this so I can get reasonable sized logs for maf scaling?
Old 04-07-2015, 08:00 PM   #2459
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
@Shiv@Openflash
As I recall, after about some newer updates, log files can only be record for about 20 minutes. Multiple files, but 20 minutes each. Correct me if I'm wrong, but this is could be the root of your problem.
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
The Following User Says Thank You to Blu-by-U For This Useful Post:
DocWalt (04-07-2015)
Old 04-07-2015, 09:28 PM   #2460
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
If that's the cause that's fine. I didn't see any mention of that, but I didn't read every post of every thread. I saw that the maximum memory is 60 minutes, which is fine, but I didn't see a per log limit.
Old 04-07-2015, 09:32 PM   #2461
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
quick question. when logging injection mode is (1) port only, (2) direct only and (3) blended???
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 04-07-2015, 09:43 PM   #2462
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Look here
http://www.ft86club.com/forums/showp...9&postcount=14
Old 04-07-2015, 09:54 PM   #2463
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Ah, ok. Thank you. I guess I'll have to be more careful about how I split up my logs.
Old 04-09-2015, 01:01 AM   #2464
gepeyo
Opal86
gepeyo's Avatar
Drives: 2013 10 Series #Opal86
So I received my OFT from a friend who unmarried the OFT from his car and I erased the file off the OFT before i used it on my car. As i did the first read with my OFT the screen and it seemed to had saved all the way. But suddenly turns into numbers with an okay box under it. I ended up unplugging the OFT because the message kept coming up over and over and over again giving me a "6041". As i plugged the OFT back into the car it was only able to write (the read option was greyed out) so i tried stage 1 tuning and it worked out successfully. I thought I should of tried tuning my car back to original after driving my car for a while and when i tried to go back to original the OFT said there was an error and reseted and suddenly the car info said i was at original save. I got worried that my OFT corrupted my original tune file, so i retuned it back to Stage 1 and left it as is and came here to see if theres anyone whose experience this or what i should do.
gepeyo is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
