Old 07-13-2016, 05:56 PM   #2451
renfield90
The Stig's German cousin
First of all, when I went to Dorman's site to check it out, under 2013 Scion they did not have FRS listed. Massive fail.
Second, when I pull up Subaru BRZ, all the studs they have available do not have the threadless dead zone at the start of the stud. This makes it easier to cross thread the lug nut. The ARP has the dead zone which forces the nut to go on almost perfect straight every time, reducing the risk of cross threading.
Just my 2 cents.
Old 07-15-2016, 04:07 PM   #2452
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Dorman wheel studs
Wheel stud wear out. I bought dorman prior to arp having standard length stud. Eventually if I need to replace them again I will install ARP as I have them at work.
BRZ short ARP wheel studs
2superblus is offline   Reply With Quote
Old 07-21-2016, 06:31 PM   #2453
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
What are you guys using for brake fluid? My Motul RBF600 is about ready to be changed and I'm considering trying either Torque RT700 or Castrol SRF. I realize that's probably overkill for AutoX, but I'm planning to do some HPDE and Track-X events in the coming months as well.
smg1138 is offline   Reply With Quote
Old 07-21-2016, 08:07 PM   #2454
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I like Valvoline DOT4... Cheap as chips, doesn't get destroyed after a track day like RBF600 and did I mention it's cheap? I haven't boiled it either, even while destroying a set of XP10s on track.
That said, the Torque RT700 is apparently the way to go if you can afford it.
Old 07-21-2016, 08:14 PM   #2455
e1_griego
e1_griego's Avatar
Drives: Many
I've always run Valvoline just because it's locally available and good enough.
e1_griego is offline   Reply With Quote
Old 07-22-2016, 02:15 PM   #2456
renfield90
Big shout out to FT86 SpeedFactory for helping me source some STX-legal LCAs on tight timeline. If you guys haven't shopped there I recommend it, they understand what autocrossers need.
Old 07-22-2016, 03:48 PM   #2457
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I've always had great experiences shopping with them. They aren't far from Chicago, so shipping to me is super fast too.
Plus, one of the guys who works there was my instructor for my last track weekend! Very nice and helpful instructor. They really love these cars there and appreciate the hell out of this community. They deserve our business.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 08-05-2016, 04:12 AM   #2458
Tofurky
Tofurky's Avatar
Drives: 2013 FRS
i have a splitter, diffuser, and sard wing
not that it will make much difference at autox but will that disqualify me from STX?
Tofurky is offline   Reply With Quote
Old 08-05-2016, 08:57 AM   #2459
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yes. Run SM.
Old 08-05-2016, 10:19 AM   #2460
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
3.5 seasons @ 50 tire swaps a season (minimum). Never had one stud break, strip, or give me any grief whatsoever.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 08-05-2016, 11:55 AM   #2461
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
I see a lot of people with bushing upgrades. do they really make that big of a difference? I have SPL lower control arms, which has titanium bushings, i know i need to change it if i do enter serious competitions, i guess i can just call up SPL and ask if they have urethane bushings for it instead?
slyphen is offline   Reply With Quote
Old 08-05-2016, 12:36 PM   #2462
Thorpedo
The SquadWhisperer
Depends what other mods you have done/will do.
Just as an example, with stiffer rear springs (or coils) the upper control arm bushings squish, limiting the spring/damper combo's ability to control wheel movement and allowing your camber to adjust itself. (Replacing these with poly will limit the probability of wheel hop and will improve traction over both smooth and rough surfaces)
Yes, bushings make a difference, but if you pick just the right ones you can limit NVH and yield 80% of the performance improvements with just a few bushings.
As for SPL, why don't you just fire them off an email??
Old 08-07-2016, 11:48 PM   #2463
sugoi
Drives: 2015 BRZ Limited CWP
Please report back. I'm interested to know as well.
sugoi is offline   Reply With Quote
Old 08-08-2016, 12:19 AM   #2464
ka-t_240
Yup, studs usually are not the problem; however, I do feel the oem lugs are crap.
ka-t_240 is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
