, dpfarr
Old 08-03-2017, 05:06 PM   #2437
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
So I have a couple questions:
About a month ago I left work and upon starting the vehicle it ran for about 3 seconds and then died. Attempted to turn over again and nothing. I waited about 20 minutes reading through some other posts and tried again. Engine started but it had a very rough idle and no response when I pressed the accelerator. Turned the car off and waited another 30 minutes. This time the car started no issue and everything read normal on my gauges except CODE P2135. The next day in the morning my car battery was completely dead. Went to a shop and found out the battery had a bad core and replaced with a BOSCH. Code hasn't come back and no issues since then. Should I do anything else to follow up with this issue?
Second issue. Prior to the battery issue and still to this day I have had issues, especially when the A/C is on, the car will die coasting from 2nd gear to a stop, or before I can down shift from 2nd to 1st. I did not have this issue until I installed a new ACT clutch with a prolite flywheel. I'm assuming I just need to send in some logs to Delcious to see if that is the issue? I also have terrible idle noise coming from the flywheel/clutch while the A/C is on. Will a tune revision fix these issues? idle at or above 1k rpm is great but once under 900 it sounds like silverware in a dryer.
Silverfox is offline   Reply With Quote
Old 08-03-2017, 05:27 PM   #2438
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by Alltezza View Post
Is Edelbrock the only mod you have? Drift office made 286, on 92 Pump.
I do have to agree that it does look a little low, but it would be expected if you were stock everywhere else.
http://www.ft86club.com/forums/showthread.php?t=95730
Edit: Forgot to add that drift office was making 286 whp on pump.
The dyno we use routinely makes much less than other dynos, and these are uncorrected numbers in 90+ degree dyno room temps and high humidity. Just how it goes.
Xero-Limit is offline   Reply With Quote
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
BirdTRD (08-03-2017), PR138 (08-03-2017), Silverfox (08-03-2017)
Old 08-03-2017, 07:24 PM   #2439
Raise your idle.
Do you have anything aftermarket on the car in terms of electronics? Headlights, tailights, interior lights, foglights, audio, etc.? If you do, remove them.
Old 08-03-2017, 07:38 PM   #2440
Silverfox
Silverfox's Avatar
Raise your idle.
Just the P3 Vidi gauge that plugs into the OBDII.
Old 08-03-2017, 07:48 PM   #2441
Raise your idle, and get some log and send them over to me and/or @DeliciousTuning
Old 08-03-2017, 07:50 PM   #2442
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Check my posts...the OBDII dongle was draining my battery. Since removing, I have had zero issues for a couple of weeks now. Very similar symptoms to yours. I could not believe that it would have such a major effect on the running of the car, but evidence would say otherwise.
Sent from my Moto G (5) Plus using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
The Following User Says Thank You to paiceyfan For This Useful Post:
Old 08-03-2017, 07:51 PM   #2443
Silverfox
Silverfox's Avatar
Yeah I just read about your issue earlier. I may just have to plug it in as needed. Going to give it some time with the new battery to see what happens. So far battery and startup has been fine.
Old 08-14-2017, 09:36 AM   #2444
StraightOuttaCanadaEh
Wes
Question for those of you who run this kit:
Has it altered the handling characteristics of the car at all? I am aware that the kit weighs roughly 80 lb, and recently I saw a video on youtube (his username is Law) where the guy actually took off his edelbrock and decided to go down NA route cause he didn't like what it did to the car. He didn't really elaborate, for whatever reason, so I thought I'd ask you guys. Is there a palpable change in handling characteristics?
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
86 South Africa (08-19-2017)
Old 08-14-2017, 10:51 AM   #2445
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Going off memory (I no longer have the car) I did not notice any change in handling characteristics after the SC install. I regularly took the car on canyon runs and I've taken the car to several trackdays but I still consider myself a novice, so my skill level is probably not high enough to "feel" the effects. Theoretically, I think even though you are adding weight to the car, the place of the bulk of the weight (the SC itself) is right above the engine and above/slightly behind the axles, so weight balance front/back is probably not affected too much. Granted, the SC does put more weight above the engine, so CG is probably moved up a few inches.
The Following User Says Thank You to BigFatFlip For This Useful Post:
StraightOuttaCanadaEh (08-14-2017)
Old 08-14-2017, 01:36 PM   #2446
99.9% of the drivers out there will not notice a difference in handling characteristics. The ones that can will easily be able to make changes to their car to suit their preference.
The kit does not weigh 80 lbs. The box the kit is shipped in is rather bulky, and I can move one around without too much effort. I'm not exactly swole.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
PhyrraM (08-14-2017), Silverfox (08-14-2017), StraightOuttaCanadaEh (08-14-2017)
Old 08-14-2017, 07:15 PM   #2447
-Willis-86touge
Drives: Stock
How much does it way from what I heard it was about 50lbs. And then the stock manifold was around 20 so only nets about 30lbs?? So in a since if you go with a light weight battery and lose 20lbs roughly only a net of 10lbs not much at all. And the battery sits as high as the supercharger so balance is only thrown off left to right. This should even be better because it centers the weight! But I don't know everything. Any correction or thoughts?
-Willis-86touge is offline   Reply With Quote
The Following User Says Thank You to -Willis-86touge For This Useful Post:
Old 08-14-2017, 08:05 PM   #2448
gtengr
Drives: 2017 BRZ
My spreadsheet says it adds 62.5 lbs net. I don't have a reference for the number though.
gtengr is offline   Reply With Quote
Old 08-14-2017, 08:52 PM   #2449
strat61caster
strat61caster's Avatar
Even if it's 70 lbs that's <3% of the total weight of the car, I'd be surprised if the c.g. moved more than 0.2" by adding any supercharger in any location.
ineedyourdiddly
Old 08-14-2017, 10:50 PM   #2450
-Willis-86touge
Drives: Stock
Even if it's 70lbs with a light weight battery it only net 30lbs so like it says it the weight shaving thread loose the water in your washer, lose some weight on your brakes, wheels etc and find the balance
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
