#2437 |
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
So I have a couple questions:
About a month ago I left work and upon starting the vehicle it ran for about 3 seconds and then died. Attempted to turn over again and nothing. I waited about 20 minutes reading through some other posts and tried again. Engine started but it had a very rough idle and no response when I pressed the accelerator. Turned the car off and waited another 30 minutes. This time the car started no issue and everything read normal on my gauges except CODE P2135. The next day in the morning my car battery was completely dead. Went to a shop and found out the battery had a bad core and replaced with a BOSCH. Code hasn't come back and no issues since then. Should I do anything else to follow up with this issue? Second issue. Prior to the battery issue and still to this day I have had issues, especially when the A/C is on, the car will die coasting from 2nd gear to a stop, or before I can down shift from 2nd to 1st. I did not have this issue until I installed a new ACT clutch with a prolite flywheel. I'm assuming I just need to send in some logs to Delcious to see if that is the issue? I also have terrible idle noise coming from the flywheel/clutch while the A/C is on. Will a tune revision fix these issues? idle at or above 1k rpm is great but once under 900 it sounds like silverware in a dryer. |
#2438 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
#2439 | |
Do you have anything aftermarket on the car in terms of electronics? Headlights, tailights, interior lights, foglights, audio, etc.? If you do, remove them. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Silverfox (08-03-2017) |
#2440 |
#2441 | |
#2442 | |
Drives: 2014 Porsche Cayman S
Sent from my Moto G (5) Plus using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
| The Following User Says Thank You to paiceyfan For This Useful Post: | Silverfox (08-03-2017) |
#2443 | |
Yeah I just read about your issue earlier. I may just have to plug it in as needed. Going to give it some time with the new battery to see what happens. So far battery and startup has been fine. Sent from my iPhone using Tapatalk |
#2444 |
Wes
Question for those of you who run this kit:
Has it altered the handling characteristics of the car at all? I am aware that the kit weighs roughly 80 lb, and recently I saw a video on youtube (his username is Law) where the guy actually took off his edelbrock and decided to go down NA route cause he didn't like what it did to the car. He didn't really elaborate, for whatever reason, so I thought I'd ask you guys. Is there a palpable change in handling characteristics? |
| The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | 86 South Africa (08-19-2017) |
#2445 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
| The Following User Says Thank You to BigFatFlip For This Useful Post: | StraightOuttaCanadaEh (08-14-2017) |
#2446 | |
The kit does not weigh 80 lbs. The box the kit is shipped in is rather bulky, and I can move one around without too much effort. I'm not exactly swole. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#2447 |
Drives: Stock
How much does it way from what I heard it was about 50lbs. And then the stock manifold was around 20 so only nets about 30lbs?? So in a since if you go with a light weight battery and lose 20lbs roughly only a net of 10lbs not much at all. And the battery sits as high as the supercharger so balance is only thrown off left to right. This should even be better because it centers the weight! But I don't know everything. Any correction or thoughts?
| The Following User Says Thank You to -Willis-86touge For This Useful Post: | StraightOuttaCanadaEh (08-14-2017) |
#2448 |
Drives: 2017 BRZ
My spreadsheet says it adds 62.5 lbs net. I don't have a reference for the number though.
#2449 |
Drives: '13 FRS - STX
Even if it's 70 lbs that's <3% of the total weight of the car, I'd be surprised if the c.g. moved more than 0.2" by adding any supercharger in any location.
#2450 |
Drives: Stock
Even if it's 70lbs with a light weight battery it only net 30lbs so like it says it the weight shaving thread loose the water in your washer, lose some weight on your brakes, wheels etc and find the balance
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
