, dpfarr
Old 07-26-2017, 06:25 PM   #2423
funwheeldrive
Originally Posted by Dan37BRZ View Post
I took the chance and got the Seibon TS hood, happy to report NO CLEARANCE ISSUES! Fits perfectly with the Edelbrock SC.
Got her painted and all is well, might be placebo but car feels like it runs stronger with less heatsoak.
Looks good. Now it's time to get some hoodpins.
Old 07-27-2017, 07:57 PM   #2424
PhyrraM
Drives: '17 BRZ PP, old Legacy SSs and SVXs
As I'm doing research to add this kit to my 2017 I noticed that the E.O. for this kit (https://arb.ca.gov/msprog/aftermkt/d...o/D-215-93.pdf) has been updated to include the 2017 models with no differentiation between manual and automatic transmissions.
I immediately called Edelbrock and was told that they do not support the 2017s as of yet. Basically the same story as I researched here.
To my thinking, how can the kit be exempt when an official Edelbrock tune is not yet available?
Thoughts? Am I missing something? Does the provided 2013-2016 tune/s work as-is on the 2017?
Other than that, I'm ready to buy the kit as soon as it goes on sale some place or Edelbrock is officially 'done' with the 2017 versions.
PhyrraM is offline   Reply With Quote
Old 07-27-2017, 08:51 PM   #2425
They do not officially support the 2017 in terms of fitment; the alternator issue is present. The tune itself works perfectly fine on 2017, and has already been CARB'd.
Old 07-30-2017, 03:34 PM   #2426
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Can anyone assist... would I have any issues fitting this to a RHD 86/frs?
I like driving!
86 South Africa is offline   Reply With Quote
Old 07-30-2017, 03:56 PM   #2427
Kodename47
Kodename47's Avatar
Drives: UK GT86
Download the install manual and look closely at the parts that are side dependent like battery connections and brake lines etc. I know the supplied wiring for the coolant pump needs changing, I can't remember if anything else was mentioned.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
86 South Africa (07-31-2017)
Old 08-02-2017, 12:28 AM   #2428
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Visited Moto-East and got dyno tuned for Flex Fuel. Ambient temps around 87-88 degrees, Ethanol content was E60 during the run. Hit 271/215 uncorrected on a Dynojet. Almost 50HP gain over 93 octane and almost a 40 ft/lb torque bump.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
CSG Mike (08-02-2017)
Old 08-02-2017, 12:29 AM   #2429
Dipstik-sportech
Dipstik-sportech's Avatar
Wow that's actually surprisingly low for even e60
Sent from my S60 using Tapatalk
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Old 08-02-2017, 01:30 AM   #2430
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Is Edelbrock the only mod you have? Drift office made 286, on 92 Pump.
I do have to agree that it does look a little low, but it would be expected if you were stock everywhere else.
http://www.ft86club.com/forums/showthread.php?t=95730
Edit: Forgot to add that drift office was making 286 whp on pump.
Alltezza is offline   Reply With Quote
Old 08-02-2017, 07:47 AM   #2431
Dipstik-sportech
Looks like he has at least a header and a full exhaust.
Old 08-02-2017, 08:12 AM   #2432
Bfranklyn86
Drives: GT86 Harrop S/C
That's the thread for the drift office build. I'm guessing BirdTRD has stock exhaust.
Bfranklyn86 is offline   Reply With Quote
Old 08-02-2017, 09:57 AM   #2433
Dipstik-sportech
Says right on his YouTube vid that he has the header and exhaust
Old 08-02-2017, 12:52 PM   #2434
Alltezza
Alltezza's Avatar
Yeah i forgot to add in my post that Drift Office made those same E60 numbers with pump gas lol my bad.
But even though he has UELs and a CBE, He should be making a lot more especially with moto east tuning it.
Old 08-02-2017, 08:12 PM   #2435
BirdTRD
Simply Forgotus
BirdTRD's Avatar
It is what it is. (unless your saying there's something broke or wrong with my setup...then I'm all ears!)
The point I was really attempting to show was the difference between 93 and Flexfuel with the fuel and tune being the only difference. Although the engine bay was probably a bit hotter on the E60 pulls than the 93 pulls which was after a 2.5-hour drive in 90-degree weather to get to Moto-East.
Since my goals don't include having the highest possible HP # for a Edelbrock SC Automatic BRZ, I'm fine with the HP and Torque #'s. What's important to me is daily drivability, reliability, and to safely add power which @moto-mike is fully aware of. Being an automatic does also present some unique challenges in balancing power with drivability and I lean towards drivability.
As for what's on my car besides the obvious Edelbrock kit (w/stock pulley), I have the Tomei UEL, Gruppe-S over pipe, 200 cell high flow cat, 2.5" pipes all the way back thru one 18" resonator to a QTP exhaust cut out valve, with the other side going thru another 18" to the stock muffler (yes, stock muffler, the Magnaflow I originally had was just too F'n loud! If I want loud, I just crack the bypass valve open a bit ). The valve was open on the E60 runs so the muffler never came into play.
Different cars with different goals with different mods on different dynos with different tuners in different environments on different days are going to yield......different results.
Lonewolf (08-03-2017)
Old 08-02-2017, 09:43 PM   #2436
Alltezza
Alltezza's Avatar
Not really, was just asking questions. Definitely thinking that you can squeeze out a lot more power than what you're getting. Not sure how much of a difference an AT would make.
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
