Old 07-07-2017, 12:09 PM   #2409
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Originally Posted by Dan37BRZ View Post
Anybody running a carbon vented hood with their EBSC kit? Specifically the Seibon TS style ones?
I ordered one (ETA 6-10 weeks) and just realized, since it has vents, it drops down a little inside the hood, I know with the stock hood clearance is real tight, so tight that we had to remove the bottom insulation during the install.
I'm crossing my fingers this hood fits with the SC or else I'm screwed.
Sorry, not sure on the TS-Style Seibon Hood. I have the Seibon VS-Style and that clears no problem. Edelbrocks BRZ has the Seibon DV-Style, which they had to cut out some of the support bracing to clear the supercharger. Hopefully someone can show a picture of the underside of the hood as BigFatFlip stated.
Nitro22 is offline   Reply With Quote
Old 07-07-2017, 03:34 PM   #2410
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
So, I am sad to say that after a wonderful 15 months or so, I now have problems with my Delicious-tuned, Edelbrock set-up. It started last week during stop-and-go traffic, where the revs would swing from 1000 to 3500 and back smoothly, but continuously, when I came to a halt. It went away for a couple of days and then this morning it is back, showing as surging while driving at low speed.
Interestingly, when I shut everything down and start back up, it is gone, but I have only tried this once.
I have a wild idea, but not sure if it is possible. Since everything was fine for a long time and now this has come about after a lot of cruise control use, is it possible I have switched from one map to another, causing this strange issue...?
Any ideas out there? I will try to log it this weekend.
Thanks.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 07-07-2017, 04:37 PM   #2411
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Thanks.
Have you contacted Zach@Delicious? Are the rpm swings happening during idle? I would hazard a guess that you have a leak somewhere or a tube has popped off.
Old 07-07-2017, 04:47 PM   #2412
paiceyfan
paiceyfan's Avatar
No, I haven't contacted Zach yet. I wanted to explore some ideas first. Yes, it happens on idle, but shows as surging at low speed. I will check for popped tubes tonight when the engine's cold.
Cheers.
Sent from my Moto G (5) Plus using Tapatalk
Old 07-07-2017, 04:51 PM   #2413
armstrom
Drives: none
I had a similar experience the other day. do a quick datalog and look at your battery voltage. In my case I was getting surging at part throttle (smooth at full throttle) and I noticed that my voltage was changing from the typical 14V down to 12V when the surging was happening. I ended up tightening down the alternator cable and it fixed the problem. That may not be what is happening for you but it's a quick thing to check. I also have the Delicious tune but I'm running a Harrop rather than Edelbrock.
-Matt
armstrom is offline   Reply With Quote
The Following 2 Users Say Thank You to armstrom For This Useful Post:
CSG Mike (07-07-2017), sato (07-07-2017)
Old 07-07-2017, 05:37 PM   #2414
paiceyfan
paiceyfan's Avatar
-Matt
Thanks for the advice...I will give that a look, too.
Old 07-11-2017, 03:31 PM   #2415
paiceyfan
paiceyfan's Avatar
Yesterday, I left from work and within a few hundred yards the car partially died, or more accurately at high throttle, it was acting like it had very little throttle. I could put my foot to the floor. I stopped and restarted the car several times with no improvement. Then I opened up the hood and checked all the pipes and cables I could find. I got back in and it started fine and drove home. It had a code P2119, related to throttle position control. I cleared the code when I got home.
Now, I know this is crazy, but I am wondering if, after the comments above that, a cheap Bluetooth OBDII dongle had been draining the battery and causing this issue. The dongle was left in permanently for months, as I don't like attaching and detaching due to the pins deforming. Since, the dongle has been removed, all seems well again now. I will keep you informed of what I find as I continue to investigate.
Old 07-11-2017, 03:44 PM   #2416
BigFatFlip
BigFatFlip's Avatar
Interesting, that code (THROTTLE VALVE RETURN SPRING MALFUNCTION) sounds more like mechanical issue, but I have no idea. I do vaguely remember somebody else here getting that same code.
Edit: Found it
http://www.ft86club.com/forums/showp...postcount=1520
Don't know how it was resolved though. @Tomcat07 ?
Old 07-11-2017, 03:57 PM   #2417
paiceyfan
paiceyfan's Avatar
Edit: Found it
Thanks...I did a search on the forum and found a few code references, but not that specific thread. Battery voltage is 12-13v right now, so I think that it is ok. Just started her up again and no issues, revs nicely and idle rock solid.
Old 07-12-2017, 07:15 PM   #2418
Colin86
Drives: 86
Don't have that Seibon, but I do have a VIS carbon hood (AMS style) and it fits perfectly -even with the rain guards.
Colin86 is offline   Reply With Quote
Old 07-14-2017, 12:34 AM   #2419
paiceyfan
paiceyfan's Avatar
OK...latest...since removing the Kobra OBDII dongle, I have had zero issues...can this really be responsible for such major issues? :eek:
Old 07-14-2017, 07:06 AM   #2420
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Rather than wreck your OBDII port constantly plugging things into it, use one of these:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I routed mine over to the passenger side, but yeah, I wouldn't leave anything plugged into the OBDII port long term for fear of battery drain or worse yet, device failure.
BirdTRD is offline   Reply With Quote
The Following 3 Users Say Thank You to BirdTRD For This Useful Post:
bhmax (07-14-2017), Dadhawk (07-14-2017), paiceyfan (07-14-2017)
Old 07-23-2017, 02:18 AM   #2421
Dan37BRZ
Senior Citizen
Drives: 2015 WRB BRZ
I took the chance and got the Seibon TS hood, happy to report NO CLEARANCE ISSUES! Fits perfectly with the Edelbrock SC.
Got her painted and all is well, might be placebo but car feels like it runs stronger with less heatsoak.
Dan37BRZ is offline   Reply With Quote
The Following 4 Users Say Thank You to Dan37BRZ For This Useful Post:
funwheeldrive (07-26-2017), johan (07-23-2017), Nitro22 (07-27-2017), PR138 (07-24-2017)
Old 07-26-2017, 11:29 AM   #2422
Dipstik-sportech
Dipstik-sportech's Avatar
Has anyone hit over 450whp on this kit yet?
Sent from my SM-G925W8 using Tapatalk
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
