Old 03-12-2015, 03:08 AM   #2423
s2d4
s2d4's Avatar
Originally Posted by Kostamojen View Post
Do you have an availible constructive reply?
Just wondering, I have never come across this scenario so I was interested?
Other than that, are you OK? That was a rather snappy reply, go have a beer maybe?
Old 03-12-2015, 03:17 AM   #2424
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
VERY long day...
Anyway, I'm not happy with how limiting the launch control is so far, I think my foot might be too fast for the software LOL
I have ZERO tuning experience and I'm not a programmer, and I'm sitting here trying to figure everything out from scratch. I'm fine with the stock UEL tunes for now (until I can get down to VISHNU for an actual tune in the future) minus the launch control/FFS which I don't need/want. I also don't think I have the 91 octane map loaded, just "Stg2 UEL A01C".
Also not sure if I have the 2.063 latest updated files actually loaded into OpenFlash manager... Need to figure out the whole Data Logging thing too and decide when I want to try that.
But ya, I think I want a Stg2 UEL map for 91 octane with the LC and FFS disabled.
Kostamojen is offline   Reply With Quote
Old 03-12-2015, 06:03 PM   #2425
elBarto
elBarto's Avatar
Drives: Toyota GT86
Originally Posted by Wayno View Post
Considering all the data from the ECU is already metric and OFT converts it into imperial, I'd say it should be easy to to. Putting an option to switch between 2 though is more code.
My thoughts exactly,
only one man who can answer this:
@Shiv@Openflash : Is it possible to make a Imperial/Metric button on the OFT?
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 03-14-2015, 08:10 PM   #2426
Kostamojen
Nevermind about the launch control... Tested it out a bit ago, it actually works quite nice
Old 03-14-2015, 09:52 PM   #2427
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
What speed have people found is best for LC?
Old 03-15-2015, 05:06 AM   #2428
Kodename47
Kodename47's Avatar
Drives: UK GT86
ECUtek set theirs at 4k so I guess around there is a good idea.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Wayno (03-15-2015)
Old 03-15-2015, 03:40 PM   #2429
Kostamojen
I managed to do a data log for the first time (yay!) and actually recorded an instance with the car "bogging" from a start.
Here is a photo:
I'm not sure I included the right info with the log, but you can see with full throttle that the RPM's actually drop instead of accelerate and the car just doesn't do anything.
Old 03-15-2015, 08:13 PM   #2430
Wayno
Wayno's Avatar
I'd expect any car to do that in gear at 1500rpm.
Old 03-15-2015, 08:49 PM   #2431
Kostamojen
It was at idle at a stop with the clutch out. Basically a launch with trying to avoid a burnout by revving the motor and dropping the clutch.
Here it is a little later, same situation but didn't bog...
Basically, the car right now is very finicky with acceleration from a stop... Either its a normal/granny start, or you have to rev it and drop the clutch. If you do anything else in between, you wind up with a bogging situation a lot of the time.
Old 03-15-2015, 09:13 PM   #2432
Wayno
Wayno's Avatar
Coolant T?
Old 03-15-2015, 09:58 PM   #2433
Kostamojen
Coolant T?
Coolant Temp was 182 (oil 156) during the bogging pic, and 192 (oil 195) during the second non-bogging pic.
Old 03-28-2015, 07:39 PM   #2434
OmarYasin
OmarYasin's Avatar
So i finally got my OFT replacement lastnight. Did a couple 3rd and 4th gear pulls to redline. Im seeing 11.57-11.91 AFR and multiplier at .97 fuel trims are looking good nothing above or 5 or negetive 3. Am i running a little rich or lean? Is the higher the aft at wot leaning or enriched? Steve?
OmarYasin is offline   Reply With Quote
Old 03-28-2015, 07:40 PM   #2435
OmarYasin
OmarYasin's Avatar
@steve99
Old 03-28-2015, 10:10 PM   #2436
cjd
cjd's Avatar
Drives: 2017 BRZ
You're running a touch rich.
The Following User Says Thank You to cjd For This Useful Post:
OmarYasin (03-28-2015)
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
