#2367 | |
read the links below especially ECU logging link. with an injen intake i will be supprised if your ltft is less than 10% at lower rpm, they reqiure maf scaling and tend to be a bit turbulant or resonant in some flow ranges making maf scaling a bit tricky. @nelsmar may have a base injen intake maf scale he could post up. |
| The Following User Says Thank You to steve99 For This Useful Post: | winsometang (03-03-2015) |
#2368 | |
Drives: '13 SSM BRZ Limited 6MT
#2369 | |
Drives: 14 Ultramarine FR-S
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
| The Following User Says Thank You to Phantobe For This Useful Post: | tracerit (02-28-2015) |
#2370 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
Just installed some Revworks headers and uploaded the Stage 2 UEL OPT tune.
Car runs great, sounds great, pulls nice now! But I am having the bogging issue something fierce... Reminds me of AWD bogging with my N/A Impreza, but a little worse cause if I try to compensate I end up doing a burnout LOL! Was there ever a solution for the bogging? I've been trying to do some searches and read through the threads, but there is a lot of info to sift through. |
#2371 | |
Drives: Neptune GR86
The pedal feel will return to normal after a couple drives.
#2372 | |
I'll drive it a week or two and see how it goes. |
#2373 |
So i was trying to figure out this noise im getting from my engine bay, sounds like a solenoid going out or tps and i totally forgot the keys were in the ignition and i took the maf sensor pigtail out and plugged it back, long story short igot maf codes both p0113 and p0203 i believe. Cleared them up and let car idle everything seems fine so i sgould be fine without having to retune or relearn right? My oft is currently broke so if i need to retune im shit outa luck
#2374 | |
#2375 |
#2376 |
Yeah, the first bit of pedal travel does nothing after a flash. Put your car in neutral and press on the gas. You'll see that it does nothing until it's pressed down a bit.
#2377 |
#2378 |
Drives: Hot Lava FR-S
Yes. It'll go away after a week or two.
Why not?
| The Following User Says Thank You to D.Scrye For This Useful Post: | OmarYasin (03-01-2015) |
#2379 |
Poor College Kid
Drives: ~.~
Hey just want to be sure. Which tune should I run if my mods are the entire exhaust except for headers, inlet hose, and air filter? I'm assuming tune stock 93?
#2380 | |
Drives: 2013 Asphalt Fr-S
If you're in an area that has 93 regularly available, yes. That's your best tune option. If not, I would run 91 oct. tune. If you're E85, however, run Stage 2 EL E85 tune preset -- Even if bone stock
| The Following User Says Thank You to Celadrielas For This Useful Post: | Kelbyat07 (03-01-2015) |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 12:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
