Old 02-27-2015, 07:57 PM   #2367
steve99
Drives: FT86
Originally Posted by winsometang View Post
Noob here. I just flashed stage 2 uel 91 on my frs. Running Ofh, nameless fo/op and zeta catback with injen intake. I was wondering what kind of range I should be seeing for short term and long term trims if it is running properly? Sorry if this has been answered, but I'm kinda lost and would greatly appreciate knowing how to read the diagnostics
plus 1 on what @phrosty said
read the links below especially ECU logging link.
with an injen intake i will be supprised if your ltft is less than 10% at lower rpm, they reqiure maf scaling and tend to be a bit turbulant or resonant in some flow ranges making maf scaling a bit tricky.
@nelsmar may have a base injen intake maf scale he could post up.
Old 02-28-2015, 12:13 AM   #2368
tracerit
Drives: '13 SSM BRZ Limited 6MT
Originally Posted by Shiv@Openflash View Post
We are currently exploring the possibility of integrated our Procede computer with the OFT much like we do with BMW N54. This gives could potentially give us the same added functionality (real-time mapswitching, flex fuel, closed loop boost control, overboost protection, PWM methanol control, etc,.) As far as flexfuel goes, it reads the raw freq signal from the GM Flexfuel sensor ($75) so no additional control boxes would be required.
Our own shop car will likely be getting a turbo soon and such options will be evaluated
Shiv
This is a post from March 2014, but I was wondering if there are any updated plans for the flex fuel integration? I'm thoroughly enjoying the E85 map now but I'm always worried about my fuel trims, mixing in 91 a bit at a time and constantly glancing back and forth at the OFT when driving haha. I drove @Phantobe 's car with the OFH (still waiting for mine due to the port delay) and it felt similar, so I may switch to a Stage 2 91 UEL map, unless the Stage 2 E85 UEL map is out of this world, which maybe the case :P
tracerit is offline   Reply With Quote
Old 02-28-2015, 12:23 AM   #2369
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
You will LOVE the E85 Stg2 UEL map
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 02-28-2015, 11:32 PM   #2370
Kostamojen
Just installed some Revworks headers and uploaded the Stage 2 UEL OPT tune.
Car runs great, sounds great, pulls nice now!
But I am having the bogging issue something fierce... Reminds me of AWD bogging with my N/A Impreza, but a little worse cause if I try to compensate I end up doing a burnout LOL!
Was there ever a solution for the bogging? I've been trying to do some searches and read through the threads, but there is a lot of info to sift through.
Old 02-28-2015, 11:55 PM   #2371
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Is it actually bogging or just the non-responsive pedal that you have?
The pedal feel will return to normal after a couple drives.
Old 03-01-2015, 12:04 AM   #2372
Kostamojen
It may be a non-responsive pedal, I don't hear the engine knocking or doing much of anything.
I'll drive it a week or two and see how it goes.
Old 03-01-2015, 12:06 AM   #2373
OmarYasin
OmarYasin's Avatar
So i was trying to figure out this noise im getting from my engine bay, sounds like a solenoid going out or tps and i totally forgot the keys were in the ignition and i took the maf sensor pigtail out and plugged it back, long story short igot maf codes both p0113 and p0203 i believe. Cleared them up and let car idle everything seems fine so i sgould be fine without having to retune or relearn right? My oft is currently broke so if i need to retune im shit outa luck
OmarYasin is offline   Reply With Quote
Old 03-01-2015, 12:20 AM   #2374
steve99
Drives: FT86
if you have fixed problem and cleared codes you will be fine no need for anything else
Old 03-01-2015, 12:22 AM   #2375
OmarYasin
OmarYasin's Avatar
Thanks steve. All i did is disconnect the plug and plugged it back but i forgot i had the keys in the ignition. So i cleared the codes
Old 03-01-2015, 12:25 AM   #2376
Andrew025
Andrew025's Avatar
Yeah, the first bit of pedal travel does nothing after a flash. Put your car in neutral and press on the gas. You'll see that it does nothing until it's pressed down a bit.
Old 03-01-2015, 12:43 AM   #2377
OmarYasin
OmarYasin's Avatar
Should it be normal to feel a little dead pedal feel?
Old 03-01-2015, 12:37 PM   #2378
D.Scrye
D.Scrye's Avatar
Drives: Hot Lava FR-S
Yes. It'll go away after a week or two.
Why not?
D.Scrye is offline   Reply With Quote
Old 03-01-2015, 08:10 PM   #2379
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Hey just want to be sure. Which tune should I run if my mods are the entire exhaust except for headers, inlet hose, and air filter? I'm assuming tune stock 93?
Kelbyat07 is offline   Reply With Quote
Old 03-01-2015, 08:38 PM   #2380
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
If you're in an area that has 93 regularly available, yes. That's your best tune option. If not, I would run 91 oct. tune. If you're E85, however, run Stage 2 EL E85 tune preset -- Even if bone stock
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
