Old 07-27-2015, 07:13 PM   #225
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Originally Posted by Bergen23 View Post
Much advice. So wow. Such engineer.
Btw I haven't forgotten about your tune file, I just was stuck in an all day meeting and couldn't RomRaider on my phone lol
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 07-27-2015, 07:50 PM   #226
Bergen23
Drives: '15 Halo FR-S
No worries man, I have nothing but time. Back in town on August 5, and my car is currently sitting at the dealers.
Only reason I really want it, is for the cold start tone down so that my dad can drive the car to work guilt free in the early morning haha
Bergen23 is offline   Reply With Quote
Old 07-27-2015, 08:39 PM   #227
drift86
Drives: GT86, 22 BRZ
I've been running Wayno's tunes with the modified cranking tables for e85 but I'm still having cold start issues when temps are < 16 degree C.
If I'm lucky, it will start in 2 goes, but sometimes it takes up to 6 goes before it starts. I've always managed to start it in the end though.
Any advise on what I can do?
Do I just keep increasing the values in the cranking tables until it can start more easily?
Is there any downside to having cranking tables that are too high?
Why are there 6 tables (A, B, C, D, E, F)?
Thanks guys..
drift86 is offline   Reply With Quote
Old 07-27-2015, 08:55 PM   #228
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Don't keep increasing cranking, remove some of the startup timing and maf adjustments.
Old 07-28-2015, 01:01 AM   #229
steve99
+1 on what @Wayno said.
alternativly run caltex eflex in winter instead of united e85 , eflex less e% and starts easier or add 5 litres of 98 petrol to a full tank of united e85 and it will light up on the first crank.
you only need about e60 to run these tunes
Old 07-28-2015, 01:57 AM   #230
Wayno
Wayno's Avatar
I haven't cranked more than once all winter with the startup adjustments.
Old 07-28-2015, 03:11 AM   #231
drift86
Do you mean further retard the timing on startup? And decrease the MAF adjustment for startup?
Thanks.
Old 07-28-2015, 03:19 AM   #232
Wayno
Wayno's Avatar
Easiest to compare and or copy the tables from the attached roms. I beleive i listed the exact tables for quiet start in the op, which includes both the timing retard and maf after start adjustments. There's lots of posts on the subject too. My changes just aren't as aggressive as some of the suggestions.
Old 07-28-2015, 05:47 AM   #233
drift86
Sorry to be a pain. But do you mean it starts easier with the loud start values or the cold start values for maf and timing?
Old 07-30-2015, 09:38 PM   #234
Bader
Drives: 2013 WRB BRZ
@Wayno
I've just started checking out your tune files. Thank you for all the hard work by the way.
Any reason why the Cranking Fuel Injector Pulse Width F (ECT) table is the only one with changes in the petrol AT rom? (v80 A01I)
You don't happen to have a modified def for the K and J roms (Long shot)
Bader is offline   Reply With Quote
Old 07-30-2015, 09:55 PM   #235
Wayno
Wayno's Avatar
You can't rely on what tables the comparison list highlights for you, you have to open both tables and compare. It will highlight them different because the axis/scaling is off in some regions.
I'll look into defs for other regions only if they're AT.
Old 07-30-2015, 10:18 PM   #236
Bader
Thanks. Don't worry about the deffs. Figured it out.
Old 07-31-2015, 02:14 PM   #237
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
@Wayno
Before I do some forensics in RomRaider - your BPB tune is UEL AND BPB? And there is no .bin for stock header AND BPB?
If it is for UEL, do I just look at the differences between UEL+BPB and UEL?
Old 08-01-2015, 10:18 AM   #238
alamando
Drives: 2014 86 GT
thanks for your all your work Wayno.
Is the A01G E85 tune on the first post for MT, AT or both?
alamando is offline   Reply With Quote
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 09:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 10:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 12:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 05:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
