#225 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Yeah - table and parameter addresses are correct - but which logging parameters are you using for injector fueling?
#226 |
Drives: Whiteout FR-S, Evo 8 RS
paramname = AFR
paramid = 0xFFF89330 isfloat = 1 scalingrpn = x,14.7,* paramname = AFR_CMD paramid = 0xFFF8DBE8 isfloat = 1 scalingrpn = x,14.7,* paramname = Fuel_System_Status paramid = 0xFFF8DC26 databits = 8 paramname = Closed_Loop_Fueling_Target paramid = 0xFFF8A6D0 isfloat = 1 ; similar to STFT / 100 old paramid 0xFFF8A5EC paramname = STFT_AF_Correction1 paramid = 0xFFF8DB8C isfloat = 1 ; same as LTFT / 100 Old paramID 0xFFF8A774 paramname = LTFT_AF_Learning1 paramid = 0xFFF8DB90 isfloat = 1 ;paramname = Port Injector Base_Pulse_Width(ms?) ;paramid = 0xFFF89744 ;isfloat = 1 ;paramname = Fuel_Injector_1_Pulse_Width_4byteExt_E60 ;paramid = 0xFFF887C8 ;isfloat = 1 ;paramname = Port_Injector_PW ;paramid = 0xFFF887C8 ;isfloat = 1 ;scalingrpn = x,0.001,* paramname = Port_Injector_PW_Ram paramid = 0xFFF887D8 isfloat = 1 scalingrpn = x,0.001,* ;paramname = Direct_Injector_PW ;paramid = 0xFFF887E8 ;isfloat = 1 paramname = Direct_Injector_PW_Ram paramid = 0xFFF887F0 isfloat = 1 |
#227 |
Can you do me a favour and log this address, in conjunction with all the ones you are logging already:
RAM:FFF887DC Ram_Fuel_Injector_2_Pulse_Width |
#228 |
And this one:
RAM:FFF8A038 Ram_Fuel_Injector_1_Pulse_Width_4byteExt_ |
#229 |
Thanks. Here's the log with the new params added:
![]() Those params look like they log the same thing no? *EDIT* Ram_Fuel_Injector_1_Pulse_Width_4byteExt_ is column H Ram_Fuel_Injector_2_Pulse_Width is column F Last edited by D-VO; 09-08-2014 at 10:31 PM. |
#230 |
Ok, fuel injector 2 seems to be the same as what you're logging as port ( / 1000).
I may have found something else, if not the FI pulse width (which i will continue). Multiply the FI1 values by 5.7602 * RPM * 0.00000012000001 and tell me what it looks like - I believe it's port injector duty cycle. |
#231 |
Add these (along with the one's I've already put up):
RAM:FFF8A06C Ram_FI_Test_1 RAM:FFF8A08C Ram_FI_Test_2 |
#232 |
Are you sure you haven't swapped these two around, i.e.
Ram_Fuel_Injector_1_Pulse_Width_4byteExt_ is column F Ram_Fuel_Injector_2_Pulse_Width is column H |
#234 | ||
![]() And for the sake of double checking what I have on my SD: paramname = Ram_Fuel_Injector_2_Pulse_Width paramid = 0xFFF887DC isfloat = 1 paramname = Ram_Fuel_Injector_1_Pulse_Width_4byteExt_ paramid = 0xFFF8A038 isfloat = 1 scalingrpn = RPM,5.7602,*,0.00000012000001,* and the two new addy's you gave me: paramname = Ram_FI_Test_1 paramid = 0xFFF8A06C isfloat = 1 paramname = Ram_FI_Test_2 paramid = 0xFFF8A08C isfloat = 1 Going logging in a couple of minutes.
#235 |
Drives: '13 10 Series FRS #1203
So tomorrow will arrive my OpenPort 2.0. I plan to immediately flash the latest OFT Stage 1 93 Tune (my car is completely stock)
From my understanding I can flash any of the tunes so long as it fits the same transmission and region as my car.. However to be safe I plan on using the same coded tune as my ECU I presume I can simply read the ECU, back up my ROM and then flash the new corresponding rom and be on my way? |
#236 |
Shady195 - yup, just pull your original rom, confirm the CALid, and make sure you are flashing the same CALid back.
#238 | |
| The Following User Says Thank You to Td-d For This Useful Post: | steve99 (09-11-2014) |
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
