Old 07-23-2013, 06:35 PM   #225
amird
Drives: seat ibiza sport Coupé
Awesome work!!
I cant wait to see you place the wheel-compressor in to it
amird is offline   Reply With Quote
Old 07-23-2013, 06:44 PM   #226
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Originally Posted by amird View Post
Awesome work!!
Yeah that may be the next step. I need to machine the motor shaft. What were actually thinking of doing is hooking up the motor, chucking it in the lathe and machine the shaft with the motor's own power.
Old 07-23-2013, 07:23 PM   #227
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Those pics give me an e-rection.
SloS14 is offline   Reply With Quote
Old 07-24-2013, 04:31 AM   #228
Danh818
Drives: Asphalt FR-S Porsche 944e
What will you be using as a power source? Or have you not decided yet?
Danh818 is offline   Reply With Quote
Old 07-24-2013, 08:20 AM   #229
neutron256
neutron256's Avatar
For initial testing I'll be using a LiPo pack which will be located in the inside the car. LiPo is not suited for use in the engine bay due to the chance of thermal runaway so it will probably be lead acid batteries for the final system, but I'm still looking at different options.
Old 07-24-2013, 08:31 AM   #230
Gardus@Supersprint
Drives: Clio TCE
I always wondered how can a electrical supercharger be really efficient.
Starting from the fact that if you take power from the stock alternator you won't have enough boost to note any difference, I'm guessing such a system should include a different power source (a battery pack).
The charge should be anough to use the compressor a few times, like a "boost button".
But isn't it just a less efficient version of a electric KERS?
After all the KERS transfer power directly to the wheels or gearbox, a much more direct route.
Are there any calculation of the kind of power you can get and for how much time, based on a reasonably sized battery pack that can fit in the car?
Gardus@Supersprint is offline   Reply With Quote
Old 07-24-2013, 09:23 AM   #231
ft_sjo
Drives: GT86
I don't think the goal here is efficiency, it's just power! Powah!!
Old 07-24-2013, 09:37 AM   #232
Wild Weasel
Wild Weasel's Avatar
Drives: 2001 Sunfire GT + 2007 Mazdaspeed3
Read this thread to learn all about it.
http://www.ft86club.com/forums/showthread.php?t=39719
It's not easy to do, and there's a million scams out there. But it CAN be done, and is being made available in a reasonable kit for the first time. Rather than running off-topic in this thread, go to the one I linked and all your questions will be answered. Separate power source. Available whenever you want it. Works quite nicely.
Wild Weasel is offline   Reply With Quote
Old 07-24-2013, 09:57 AM   #233
Gardus@Supersprint
Drives: Clio TCE
Got it, if you use the correct battery (charged from a source off the car like a wall plug) and a time-limited boost it's physically possibile. Thanks for the link.
Old 07-24-2013, 11:29 AM   #234
mid_life_crisis
Drives: FR-S 10 #103 AT
No, charged by the alternator but after the foot comes off the gas so there is no heavy load on it.
Old 07-24-2013, 12:15 PM   #235
neutron256
neutron256's Avatar
Think of it kind of like a hybrid you charge when demand is low and give back when demand is high.
The difference being with this you're going for extra power not extra MPG.
My proof of concept will just use a pre-charged battery with no on board charging system, but if it works a charging system will be the next step.
Old 07-24-2013, 01:35 PM   #236
Wild Weasel
Go to the thread I linked. It's charged from the car (when not under boost) and provides boost for as long as you'd like (so far as we've been able to use on the street). Please go read. You'll be pleasantly surprised.
No more responses in this thread! By all means, post more questions in the other one.
Old 07-29-2013, 12:37 PM   #237
amird
There is news about the project?
Old 07-29-2013, 12:50 PM   #238
Ingen
Drives: Ultramarine FR-S 6MT
Originally Posted by BRS View Post
Roadkill put leafblowers in a monza!
I saw that episode and couldn't help but facepalm While the theory was sound, the "more blowers = better" idea was bad. Especially since all the piping was the same size. In order to get the flow from those 5 blowers they should have probably had a 6 or 8 inch pipe going past the driver into the engine. Leaf blowers aren't designed to sustain pressure, the clearances on the impeller aren't tight enough.
This isn't a leaf blower, it's a compressor
Also, 15 feet of charge tube is kind of silly from a fluid dynamics losses point of view.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
hairdyerperformance, only pulls hard one gear
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
DUP THREAD MODZ PLZ DELETE KTHX SloS14 Forced Induction 0 07-09-2013 05:41 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 02:16 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 09:20 PM
