Old 02-02-2016, 06:53 PM   #225
Limited
Drives: Monogram FR-S
Thank you OP for this mod. 7/8 inch, 2 pack at Lowe's worked perfectly.
Limited is offline   Reply With Quote
Old 02-02-2016, 09:52 PM   #226
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
I like the vroom, I'll keep it unplugged!
VROOOM!
RichardsFRS is offline   Reply With Quote
Old 02-23-2016, 04:37 AM   #227
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by mezdup View Post
This mod is only for people who do not wish to delete the sound tube, but want to suppress the cabin noise and be able to undo the said noise suppression whenever they'd like.
Sent from my HTC Rezound using Tapatalk 2
Or for people like me who couldn't be bothered to actually remove the sound tube
I like driving!
86 South Africa is offline   Reply With Quote
Old 02-23-2016, 12:04 PM   #228
Calum
That Guy
Drives: 2013 asphalt FRS MT
But, it's like 1.2 pounds!!! And it's above the CoG of the Car!!!!! I easily gained 8 seconds on my local autocross course with this mod!!!1!1!1
I took mine off to give me more room in the engine bay, but I've got really big hands so it was probably more important to me than a lot of other people.
The Following User Says Thank You to Calum For This Useful Post:
86 South Africa (02-24-2016)
Old 03-04-2016, 03:16 PM   #229
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
Originally Posted by Tech View Post
enouf has discovered that you don't actually need to buy the plug I have used. You can use the 12V adapter cover that is in everyones glove box.
This is probably redundant and unnecessary, but I don't see a post referring to this: beginning with model year 2014, the power tap is in the center console storage bin, covered by a plastic cap which is secured by an integral strap. It seems silly to cut it off just to find the design has changed and it doesn't fit. So, I just rummaged around in the garage and used a couple compacted cotton balls to stuff the tube and then pressed a garden hose cap over the whole rubber tube surround. I'll see if it works, then go to Lowe's later if I have to. Thanks to you all for enabling this lazy bastard to lounge around longer reading your most excellent posts.
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
Old 03-04-2016, 08:31 PM   #230
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
There's also a 12V socket and associated cap inside the glove box.
That one may be detachable. I haven't checked.
But then you have an open socket in the glove box. Winning!
pfaffendorn (03-07-2016)
Old 03-04-2016, 10:39 PM   #231
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
If you read the OP it is the glove box plug that is suggested.
nzer is offline   Reply With Quote
The Following User Says Thank You to nzer For This Useful Post:
Old 03-04-2016, 11:22 PM   #232
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
The cap in the glove box of my '15 is removable and works perfectly. Using it does leave a live socket in the glove box and to me it's not worth the potential for a cock up. The Lowes caps work great and if that's too rich for you a small roll up foam ear plug works just as well. I used both.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Old 03-05-2016, 01:28 AM   #233
Since I do not tend to carry ammunition, nuts, bolts, screws or any other small conductive materials in my glove box I pulled the plug out at the dealers and shove it in the tube before I even left the lot. The salesperson thought I was insane until I explained. Then she thought I was a genius. I took full credit for the idea and enjoyed the view as she bent into the car to see what I was plugging.
Old 03-07-2016, 10:20 PM   #234
pfaffendorn
Thanks to all you gentlemen for continuing to steer me to the glove box. I have finally discovered the power tap there -- on the firewall behind and above the glove box, way where it is hard to see. That's my excuse, anyway. What an odd place for it, except I now have a place to charge my phone--in the glove box, and the charger seals the socket to eliminate the short hazard. I discovered that my garden hose end cap worked even better to seal the sound tube, and the car now purrs along beautifully. Can I send anyone my plastic cap as a thank you? Let me know.
Old 06-19-2016, 02:18 PM   #235
Prmspen
Student Driver
Prmspen's Avatar
Drives: 2016 Subaru BRZ Limited
VROOOM!
Me too. I did this mod with a $2 rubber plug from Orchard Hardware. Put the plug in at Orchard, drove around for a while, and took it out when I got home. To me, it sounds too much like a normal car with the sound tube blocked. YMMV.
Prmspen is offline   Reply With Quote
Old 06-19-2016, 02:23 PM   #236
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Buy a nice muffler and enjoy the car. The sound tube is ...
Old 10-17-2017, 09:40 PM   #237
pacaveli420
Drives: Badass
I pulled the rubber grommet out, as well. If you do this, 881290 from Lowe's (in the hardware aisle with all the bolts) will make a snug fit into the hole. It's a 1" cap like these from Amazon:
https://smile.amazon.com/dp/B007Q94BMQ/
pacaveli420 is offline   Reply With Quote
Old 10-23-2017, 08:21 PM   #238
notout86
Drives: GTS 86 auto
I have wondered about doing this too. With just the tube plugged, engine compartment noise is still transmitted to the firewall. By disconnecting the tube/grommet, did you notice a reduction in cabin noise?
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
enouf is a damned genious, plug, sound tube, toyoburu kazoo banned.
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Switching stereo from TC to "FR-S" mode frsinpa Electronics | Audio | NAV | Infotainment 8 06-21-2012 11:48 PM
*NSFW* "Check Out My Subaru" on You Tube Axel Other Vehicles & General Automotive Discussions 4 01-17-2010 06:56 PM
