Old 02-26-2015, 12:45 PM   #225
Racecomp Engineering
I had some more things to say but I'm totally blanking. I just came back from lunch.
- andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Calum (02-26-2015)
Old 02-26-2015, 01:03 PM   #226
fika84
fika84's Avatar
Thanks for all that Andy! Have you played around with the roll center correction kits at all?
fika84 is offline   Reply With Quote
Old 02-26-2015, 01:25 PM   #227
Yes and they are helpful. I can tell if one is installed in a back to back drive but the effect isn't super noticeable unless you're at an inch of drop or more. I've only tried the Whiteline kit which doesn't relocate the outer pivot a ton but it's easy and includes the tie-rod extenders for bumpsteer.
With the bigger drops on these cars you NEED roll center correction and/or some very firm spring rates especially up front (and that's pretty obvious whether you're looking at the KRC or FAPs or just the camber curve). A lot of people JUST try to pick spring rates on these cars by picking suspension frequencies and designing for a flat ride at 80 mph or whatever and IMO that's leaving a lot on the table and pretty shortsighted.
- Andy
civicdrivr (02-27-2015)
Old 02-26-2015, 01:31 PM   #228
RBbugBITme
Drives: S60R/Corvette
I think this analysis from post #216 may be the most informative. The saw tooth at the far right of this analysis is at OEM ride height. You're looking at camber and FAP height and from other images I've posted, the kinematic roll center is also under good control here, which is not a coincidence since it is also the area with the least camber gain.
What I see is at steady ride height, the FAP heights vary greatly with roll angle. The FAPs also pass through the ground plane at lower ride heights and you can see from the list on the right JackCGL is negative while JackCGR is positive when FAPheightL is negative and FAPheightR is positive. I would think just like I stated with the kinematic roll center, you wouldn't really want the FAPs to pass back and forth through the ground plane every time you turn the car.
Additionally, camber gain with some steering is quite large even at OEM ride height and you guys now have that quantified. I think this is also why Jarrett at Raceseng suggested up to 1deg more caster made a big improvement.
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
Old 02-26-2015, 01:39 PM   #229
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
- Andy
Care to toss out an approximate value on what a "bigger drop" is? Also, I saw you mentioned the whiteline kit doesn't do a lot of correction. What one would you recommend to make a bigger difference? I see Megan makes a really affordable RC correction option, but I haven't yet emailed these companies to inquire about the actual measured differences vs OEM. Any help or input is appreciated. Hopefully I don't seem lazy in asking this :/
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 02-26-2015, 01:43 PM   #230
fika84
fika84's Avatar
- Andy
Thanks for the input. I'm a little over an inch drop on ST Suspension coilovers. I don't do much tracking, but as my daughter gets older (only a month old at the moment) I'm sure I will venture to the track more! Either way, something else to add to the list of mods!!
The Following User Says Thank You to fika84 For This Useful Post:
Racecomp Engineering (02-26-2015)
Old 02-26-2015, 02:04 PM   #231
IMO an inch is a "bigger drop" for some of the same reasons Ryan said...past that drop things start to change more drastically. Not insurmountable without the RCK but it is nice to have at that point.
I do recommend the WL kit even though it's not a ton of correction...it's just a pretty well designed complete kit at a good price. With just the ball joint extenders you have a bumpsteer problem and a lot of the more expensive kits don't account for that.
- Andy
Old 02-26-2015, 04:00 PM   #232
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by RBbugBITme View Post
You're right but the roll center for this car isn't that controlled. Depending on your ride height you can see RC heights during roll from -1" to +10" or +1" to -10". That is a big swing worth noting.
That's exactly the group of curves that I don't believe. They are greatly exaggerating RC height movement with roll the nearer static RC height gets to 0.
Its also worth noting that RC movement is fairly well controlled at stock ride height so I would guess a properly designed roll center correction kit would be worth while.
Looking at those curves again, if far left is -3" and steps are 0.1", black vertical line is -1", but the far right is more like +0.5", not +2".
Either way, at OEM height this curve family still suggests a lot of movement of RC height with roll, about the SAME as for -2" lowered! Curves show that at OEM height the RC height is getting lower with roll, so as you corner you lose roll stiffness, whereas at -2" your gaining a similar amount of roll stiffness. But I don't think that's what's really happening. For sure it's not happening to the extent suggested for the -1" lowered case!
Whatever points are "passing through the ground plane", it is still a (nearly) linear and continuous change. It's not like a sudden discontinuous change in handling behavior.
Nothing magical or spooky happens when these points pass the ground plane.
Is it better to have the roll center somewhat above the ground plane? To a point, yes. But in most cases, lowering a car with no geometry-"correcting" mods will still give handling benefits despite the lowered roll center height.
I would worry more about usable suspension travel when lowering.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Calum (02-26-2015), toeout (02-26-2015)
Old 02-26-2015, 04:13 PM   #233
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
- Andy
Can you please tell me what the consequence/s is/are of fitting a RCK only at the front?
Old 02-26-2015, 05:09 PM   #234
fika84
fika84's Avatar
I'm pretty sure its because the rear is double wishbone and not quite as sensitive to lowering. Just my guess. I'm sure Andy will know best.
Old 02-26-2015, 05:35 PM   #235
Calum
That Guy
Drives: 2013 asphalt FRS MT
Old 02-26-2015, 06:42 PM   #236
Mostly that. It's much more necessary at the front. You can look at the plots Ryan posted and basically with a 1 inch drop you'd have a 1 inch lower COG but the geometry and camber curve of the stock ride height. That's good. Or 20 mm, I can't remember the exact correction the WL kit gets you and I'm at the bar now.
It would increase front grip and decrease understeer.
- Andy
Old 02-28-2015, 09:32 AM   #237
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Old 03-03-2015, 12:43 PM   #238
Calum
That Guy
First a good link on FAPs (Force Application Points) vs. Kinematic roll centers that might help everyone that's interested in this discussion:
https://drive.google.com/file/d/0B3p...ew?usp=sharing
It's worth reading...and rereading a couple more times.
- Andy
I downloaded that to my phone the other day, expecting to read it at work. I tried to open it today but it's blank. I've tried to open it on my work computer aswell, nothing. Is anyone able to read what Andy linked to?
New Rumor: Subaru Developing Turbo 4 2.0T for BRZ Hachiroku BRZ First-Gen (2012+) — General Topics 350 02-02-2013 01:52 PM
Need opinions on two new items we're developing! yospeed Cosmetic Modification (Interior/Exterior/Lighting) 56 12-03-2012 02:13 AM
Chances of Someone Developing 5x114.3 HUBS (not spacers)? Entropy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-04-2012 03:35 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 07:16 AM
