Old 08-07-2013, 07:59 AM   #225
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Originally Posted by Turdinator View Post
So everyone using coilovers with the conical washer isn't have any issues? Is that correct?
I was using the conical washer with coilovers and still had bearing failures.
neurokinetik is offline   Reply With Quote
The Following User Says Thank You to neurokinetik For This Useful Post:
Turdinator (08-07-2013)
Old 08-07-2013, 09:22 AM   #226
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Hmm
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-07-2013, 10:07 AM   #227
cnk
Drives: '13 DGM BRZ Limited
I just have a pop in the morning when backing out of the garage and turning the wheels for the first time of the day. After that, they are silent.
cnk is offline   Reply With Quote
Old 08-07-2013, 10:30 AM   #228
feldy
feldy's Avatar
Becareful I did that for 3500 miles and then my shock snapped at the place where the top hat rest on it.
Old 08-07-2013, 01:26 PM   #229
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I'm curious how much freedom you have spinning the entire spring when the car has load on it. I can freely spin my springs even under load with my RCE Tarmacs + the conical washer + the top stock strut mount. Are you able to spin your springs with the Whitelines as well or do the springs seem bound and rigid, unable to spin, under load?
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 08-07-2013, 01:36 PM   #230
feldy
feldy's Avatar
I was able to spin my springs when the shocks were off and I was trying to fix the rotation of it. Have not tried but I assume you can't.
Old 08-07-2013, 05:44 PM   #231
wparsons
wparsons's Avatar
You can only spin the springs if you have coilovers, the bottom spring seat on stock shocks is keyed so the spring can't spin on purpose.
flickr
Old 08-07-2013, 06:10 PM   #232
neurokinetik
With coilovers, they will turn, but not that easily. It takes both hands on the spring to get it to move. I've adjusted my ride height so many times that I'm pretty familiar with it. With the roller bearings built into the perch on the Ground Control camber plates, the adjustment happens with much less effort.
TrogDor the Burninator (08-07-2013)
Old 08-09-2013, 12:47 AM   #233
cnk
I wrote Whiteline an email about my popping in the morning and they responded stating that they are testing some things out and are hoping to have something in a week or two. We'll see what happens.
Old 08-09-2013, 08:44 AM   #234
solma
Drives: Raven FRS
Got the popping noise, install a little more than a month ago, popping is getting louder and louder, so decide to check it as I had other thing to install.
I am using the conical washer with KW3, I think there is 2 kind of problem, the older one were related with not using the conical washer(with KW3), the aluminum plate was pulling on the outer bearing race, the second problem that we are seeing now seem to be link with the bearing moving inside the bearing holder when the geometry(angle of the shock change) when turning the wheel. Made a video were you can see it move from one angle to the other with the popping sound. Thats why they run fine and noise free when you are not turning to much the wheel on the road.
I really like this product and hope they will solve it, I do not think its a big to solve but it take time to have tooling made as they are made from stamp steel in comparaison with spherical bearing top plate that are CNC part(tolerance can be made better).
I have sent them the info and video, service is really nice up to now, that make me an happy customer.
solma is offline   Reply With Quote
Old 08-09-2013, 09:20 AM   #235
wparsons
wparsons's Avatar
For anyone running coilovers and getting popping, are you running thrust bearings on the front springs? That will probably totally stop the noises for you.
flickr
Old 08-09-2013, 09:34 AM   #236
solma
Drives: Raven FRS
Are you saying that actual bearing is not supporting/able to support the the vertical force produce by the weight of the car?
Old 08-09-2013, 04:17 PM   #237
wparsons
wparsons's Avatar
Nono... but some coilover companies suggest running a thrust bearing to make it easier for the spring to rotate as the strut turns with the wheels. It has nothing to do with load bearing ability.
flickr
Old 08-09-2013, 06:01 PM   #238
Calum
That Guy
Drives: 2013 asphalt FRS MT
That's normally with spherical bearings that can handle the axial load but don't turn well with it.
Sent from my GT-S7560M using Tapatalk 4
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-12-2013 12:31 AM
Buyer Beware: Motor Mounts cobrabyte Engine, Exhaust, Transmission 5 01-04-2013 09:14 PM
Autocross Camera Mounts? fritzy BRZ First-Gen (2012+) — General Topics 7 08-03-2012 11:48 PM
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports Font Motorsports Interior Parts (Incl. Lighting) 2 07-03-2012 07:43 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 08:07 PM
