Old 02-26-2013, 04:21 PM   #225
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Anything for $50 or less? I just want it to compare my gauge location to what the OEM location says on the track so a phone might actually be more ideal?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-26-2013, 04:39 PM   #226
Foobar
SLO NO MO
Foobar's Avatar
I'd check swappa.com for used android phones in that case.
Sent from my Nexus 4 using Tapatalk 2
Old 02-26-2013, 07:21 PM   #227
Ingen
Drives: Ultramarine FR-S 6MT
Since this seems better than any current IOS setup what's the cheapest way to get into a Android device that will support/run Torque? An old beat up phone? Cheap tablet? Just needs bluetooth and I'd guess some min food-related OS or whatever?
If you live near me, a local store is selling refurbished Samsung galaxy 2 7" tablets for $150. They're white, but nothing some vinyl wrap scraps can't fix.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 02-26-2013, 09:32 PM   #228
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
To get set up the easy way, without much fuss, you need A- a platform that supports Bluetooth, B- has Google-Play for app store.
Plenty of cheap tablets out there that don't support Bluetooth or have Google-Play. The only cheap one I've found (and was shortly sold out) was the Best Buy's cheap Chinese made 7" Double Power for $79. It is not discontinued, and no ETA, but they'll have it in stock some time in the future....
The problem with cheap tablets is glare, especially on the track on a sunny day.
Keep in mind that the mounts for these 7" tablets are not very sturdy, and track officials may take issues with the mounts.
My middle age crisis started prematurely… at 16!
I'm also independently very, very..... dependent!
Kamran is offline   Reply With Quote
Old 02-26-2013, 10:07 PM   #229
so26
Drives: Raven FR-S 6MT
Originally Posted by brichard0625 View Post
I tried to do some runs on a somewhat flat road. it was a little wet on the road but not sure if it wud affect the numbers that much.
3rd gear 3.7
4th gear 4.8
5th 6.7
6th 9.3(not sure why it took that long)
My girlfriend put hess gas in my car i usually go shell or sunoco so im not sure if im running on crappy gas but doing the pull in 6th felt super sluggish
So I tried a few more pulls today with 3/4 a tank of gas. Times in 3rd, 4th, and 5th gears were all similar to my previous #'s. Pulls in 6th gear however varied from 8.2 - 9.3s. It seemed like they would lengthen to the 9s range if the road had any sort of incline.
so26 is offline   Reply With Quote
Old 02-27-2013, 12:53 AM   #230
AsphaltLover
AsphaltLover's Avatar
Drives: 2006 Scion TC, 2013 FR-S Asphalt
Would one of those screen protectors help get rid of the glare? I know they make a bunch of 7" models, so you could throw one on there on the cheap and get rid of it once and for all.
AsphaltLover is offline   Reply With Quote
Old 02-27-2013, 01:23 AM   #231
reeves
A 4.5" android phone works just fine.. showing me 18 different readings/guages at the same time! Once you get familiar with looking at them, it's not as confusing as it first looks.
the phone stays very well secured in that location for me too!
No need to look at the factory "temperature" guage when I got the oil & coolant temp guages instead
reeves is offline   Reply With Quote
Old 02-27-2013, 06:38 AM   #232
nix
nix's Avatar
Drives: AVO BRZ
This works for boost, but maybe someone can provide a more accurate method.
Settings - OBD2 Adapter Settings - Boost Calculation Method: Prefer MAF
Vehicle Profile - Boost Adjustment: 0, Volumetric Efficiency %: 100
I tick "Don't display psi as in/Hg" in Settings - Units and use a graph type "Turbo Boost & Vacuum Gauge" with a min value of 0.
nix is offline   Reply With Quote
Old 02-28-2013, 01:16 PM   #233
aiiee
Drives: 2011 Porsche Cayman S
Originally Posted by reeves View Post
Why doesn't anything show up for this guage? Is there a custom PID you need for this too? I see 2 Transmission temperature selections.. tried both, but none of them works.
This may be something recent, but the one I use is Transmission Oil Temp ( Method 3 ). There is some controversy about this as it may be the same as engine coolant.
It is labeled as transmission oil temp tho.
PID: 0105
Long name: Transmission Temperature ( Method 3 )
Short name: Trans
Minimum Value: 0
Maximum Value: 200
scale: x1
Unit: <degree sign, i don't have it on my keyboard>C
Equation: A-40
OBD Header: TCM
aiiee is offline   Reply With Quote
Old 02-28-2013, 01:30 PM   #234
2forme
PID: 0105
Short name: Trans
Minimum Value: 0
Maximum Value: 200
scale: x1
Equation: A-40
OBD Header: TCM
This for AT's?
Old 02-28-2013, 02:36 PM   #235
aiiee
Originally Posted by 2forme View Post
This for AT's?
Mine is MT
Old 02-28-2013, 02:37 PM   #236
reeves
PID: 0105
Short name: Trans
Minimum Value: 0
Maximum Value: 200
scale: x1
Equation: A-40
OBD Header: TCM
Was this a custom PID you added? I only see Method 1 & 2 on my Torque app.. I have the paid version too.
Old 02-28-2013, 02:37 PM   #237
2forme
Mine is MT
Interesting, didn't know we had a transmission oil temp sensor.
Old 02-28-2013, 02:51 PM   #238
xjohnx
Grip>Slip
xjohnx's Avatar
I don't see any reference to it in the shop manual.
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
