Old 10-31-2011, 03:49 PM   #225
ryridesmotox
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
Originally Posted by Allch Chcar View Post
Very good explanation, I think huh. We need more Ethanol Guys like you.
20KG = 40lbs. Where it is can be just as important as how much. Nose weight is the hardest to lose don't you agree?
As far as Ethanol goes... I am a relative rookie so to speak. I run it in my car, I understand how it works in cars (advantages) and I know what is not so fun about it (disadvantage 30% more fuel usage= less MPG).
As far as weight... There is a fine line between light enough and too light... weigh balance is key... take rear engine cars... many of them actually under steer (atom v8 to name one) due to a light nose and heavy tail... there isn't enough weight to keep traction on the tires and they just slip over the tarmac instead of being squished down on it. Ideally I would like to put the front wheels on a scale and the rear ones on another scale and have it be within about 10-15 kilos of difference... kind of ridiculous, I know, but a boy can dream can't he?
Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91
ryridesmotox is offline   Reply With Quote
Old 10-31-2011, 03:51 PM   #226
Sip
Drives: Rx7, MR2, Celica GT-4, STi sedan GC
200hp, 151tq and 2600lbs. That is what I had expected, but I had hoped for a lower curb weight. It's going to be a fun car but it's not going to be the featherweight screamer I and everyone had hoped. It will put up RX8 performance numbers, but hopefully for half the price.
Sip is offline   Reply With Quote
Old 10-31-2011, 03:52 PM   #227
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Originally Posted by LionZoo View Post
Kind of bummed that the low spec has everything I want except for vented rear discs. Could also stand to lose another 50 or so pounds too. (Yes I have high standards, but if Toyota wants me to buy this instead of an Elise, they better get on the Jenny Craig diet. Not directly comparable cars I know, but I was looking at this as a lower cost alternative.)
The steel wheels are the bare spec are HEAVY! So you can loose another 20-40lbs just with lighter wheels.
Plus, ditch the rear seats, thats another 30-40lbs, ditch the junk in the trunk (spare/jack/etc.) for another 30-50lbs, and maybe some lightweight bumper beams like they sell for Imprezas (have them on mine, saved ~20lbs each). This car can EASILY be down to 2500lbs
As for the brakes, vented rears would be nice, the conversion probably won't be that expensive either but I suspect all the cars sold here in the states will have them. But as others have said, this car probably just needs quality pads to out-brake pretty much everything out there. Don't need brembo's or other huge brakes unless you throw in a turbo motor with another 50+hp.
One thing to note: The "De-contented model" is a Type-RA version. Subaru almost always sells a Type-RA model STI in Japan. They usually have no stereo, no foglights, none of the amenities and are sold specifically for privateer rally racing. Here is a good example of a brochure for one:
The sad thing about these models is they are never sold outside of Japan
So I don't expect that no-content FT86 with the unpainted models to be sold anywhere outside of Japan either.
Kostamojen is offline   Reply With Quote
Old 10-31-2011, 03:56 PM   #228
Allch Chcar
Drives: N/A
Originally Posted by Aki View Post
It is recommending "premium unleaded gasoline" in the scan.
Yes, I caught that later. Thank you.
I should have said recommend. Modern engines will simply pull timing if you don't, so to make the stated power it does "require" it though. Yes, it'd run on 87, it'll just pull timing until the knock is gone.
I'm not familar with DI enough to know if it makes a difference. I guess it can inject during compression to prevent pre-ignition.
I wasn't trying to knock of you at all. But there are people who would be not be aware of this fact and misunderstand.
To those that don't know. Current cars have knock sensors now and the ECU can detune engines for lower octane. This is not something DI related at all. There were cars that could do this in the 80's automatically, so it's not something to worry about one bit. Performance will be best on the recommended fuel even Fuel Economy will likely be better too.
These leaks are seriously terrible (for them, great for us). Heads will roll if the person(s) is caught. Don't recall something getting leaked so comprehensively.
I certainly hope not. This person was either authorized/told to do so beforehand or if not they should be promoted by now.
Originally Posted by tranzformer View Post
You mean Subaru reliability right?
Nothing wrong with that either.
Originally Posted by fred_boosted View Post
Agreed, I might begin to mod the exhuast, intake, cams when 10K miles, swap seats, wheels, suspentions when its 25K miles, and do turbo build in about 30~35K miles.
If bare bone is an option... then...
Cool
Originally Posted by TwinDarkness View Post
are they making the Ft-86 in Auto tranny as well?
Yes sir. Please for questions like this. It has been thoroughly advertised as offering 6spd manual and 6spd automatic gearboxes.
Welcome to the forum newcomer!
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 10-31-2011, 04:00 PM   #229
Streetice
Local Nut...
Streetice's Avatar
Drives: Soon FR-S
16 pages in 8 hours! Holly Crap!
Yo MOD! check genius world records see if theres a fastest growing theard records we may have one here
Thanks for the spec sheet it really helps in giving a good idea what might be availble USDM models.
If the spec sheeet for USDM is anything close its look quite hard to decide given the price range is resonable for high and low spec.
Im going to check back in a few hours just to see how many more pages come up for this.
Yeah its an 86 you want some BMW 1 Series
Streetice is offline   Reply With Quote
Old 10-31-2011, 04:00 PM   #230
Allch Chcar
Drives: N/A
Originally Posted by ryridesmotox View Post
If I get this thing in a reasonable timeframe after it's released, you can be the first to run E85... right after me lol... on my turbonetics ball bearing turbo build muahahahahaha
You are my rival. >:|
Switching to PM.
-Allch Chcar
Old 10-31-2011, 04:02 PM   #231
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
I'm new but i'm amazed within the week there has been plethora of leaked info coming through. I'm sure it will keep going? What's next!? I sure next I would like to see price and optionals.
Old 10-31-2011, 04:05 PM   #232
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Also don't see fuel capacity in the scan.
The last item in "engine" category in the scans. I don't speak/read Japanese but the numbers checked out and it looked close enough in google translate.
燃料タンクの容量
I also couldn't figure out a lot of the dimesnions... I'm guessing ride height is one
1520/1540 might be front/rear track width
maybe another one... cargo capacity (I compared to mx5 actual specs)
ft86 130mm
mx5 135
rx8 125
crz 150
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 10-31-2011, 04:10 PM   #233
yjs
Drives: 2009 Mazda 3 SP25
Good possibility the 'premium' spec is the only model we'll get here in Australia with options such as leather seats and sunroof etc. My guess is around $35,000 plus ORCs...
yjs is offline   Reply With Quote
Old 10-31-2011, 04:21 PM   #234
keiri
Toyobaru Wonder Twins™
keiri's Avatar
Drives: 2020 Subaru BRZ Limited w/ PP
I wouldn't be surprised if Toyota was leaking these pages and images; it does drum up interest, hype, and talk about the car.
What would be smart on their part, would be if the specs being leaked were from an older preliminary brochure and that somethings may have improved what way when they do the presser for the car at Tokyo they can give the full, accurate specs for a little "fooled you".
Doubtful, I know, but it would be nice.
keiri is offline   Reply With Quote
Old 10-31-2011, 04:26 PM   #235
Aki
Drives: '96 beater Corolla
燃料タンクの容量
Oohh that's right, I was just looking for 13 gallons but it's in liters.
Aki is offline   Reply With Quote
Old 10-31-2011, 04:28 PM   #236
Kiteless
Hot Lava
Kiteless's Avatar
Drives: 2013 Scion FR-S, 1990 Miata 5MT
Originally Posted by mkivalex View Post
I would most definatly say it is getting leaked on purpose, If you dont think toyota regularily monitors this forum and see's by leaking a littttle bit of info at the time it creats a thread with 20,000+ views in 12 hours. Its free advertising for them, and look at us, chatting like little school girls over this car, toyota is 100% putting these "leaks" out.
Who gave permission to more than 1 review company to post their review this week?....Exactly.
Very well stated. We are gabbing around the water cool aren't we? The timing of the embargo lift and the "leak" of all the info does seem to all work out very conveniently doesn't it? Not that I mind.
- Jason
2013 Hot Lava Scion FR-S 6MT
Kiteless is offline   Reply With Quote
Old 10-31-2011, 04:31 PM   #237
Spaceywilly
ZC6A2B82KC7J
Drives: 2002 WRX
- Jason
It's also suspicious that the photos have just the right amount of graininess so you can sort of make out what's there, but not really. It's 2011, even cell phones have 12MP cameras now.
Either way, I was prepared to wait another month for this info, so I'm ok with it.
Old 10-31-2011, 04:33 PM   #238
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
You'll need more than just the disc to convert it to the top spec's brakes as the caliper and pads will no longer go over the rotor.
I'd assume if the rear is upgraded with ventilated discs, the fronts are likely bigger in the top spec as well.
With our luck, the US will only get the bottom spec. Fine for the tach, but I wouldn't mind some of the other top spec brakes (primarily the brakes).
We want the higher end spec...You want the front LED clearance lights, front fog lights, standard HIDS, leather steering wheel, aluminum pedals, . auto climate control, High spec frabric, auto alarm, Auto on\off lights, 6 speakers audio (low spec has 2 speakers), white rev counter with shift light and sport pedals. Top spec also has "smart entry and start" plus digital speedo and tach. Oh and it has the better brakes. Sure it is 45 pounds more in weight for the High Spec...but what is 45 pounds? nothing...
tripjammer is offline   Reply With Quote
brz forum, brz forums, brz specs, brz sti forum, fr-s review, fr-s specs, frs review, frs reviews, ft-86 review, ft-86 specs, ft86 forum, ft86 forums, ft86 specs, scion fr-s, scion fr-s forum, scion fr-s horsepower, scion fr-s hp, scion fr-s review, scion fr-s reviews, scion fr-s specs, scion fr-s weigh, scion fr-s weight, scion frs, scion frs forum, scion frs review, scion frs specs, subaru brz, subaru brz forum, subaru brz forums, subaru brz horsepower, subaru brz hp, subaru brz specs, subaru brz sti, subaru brz sti forum, toyota ft-86, toyota ft-86 forum, toyota ft-86 horsepower, toyota ft-86 hp, toyota ft-86 review, toyota ft-86 specs
AutoBild gives specs of the Subaru BRZ Ice_Man BRZ First-Gen (2012+) — General Topics 43 10-30-2011 06:43 PM
Guessing Scion FR-S specs?? dClutch Scion FR-S / Toyota 86 GT86 General Forum 58 04-28-2011 11:07 PM
If there is no Toyota will you go with Scion or Subaru tranzformer Scion FR-S / Toyota 86 GT86 General Forum 91 04-25-2011 11:53 PM
200hp / 2700lbs - Really? Rickster Scion FR-S / Toyota 86 GT86 General Forum 385 04-18-2011 02:47 PM
TRD options and Badging? BanningFT Scion FR-S / Toyota 86 GT86 General Forum 43 11-08-2009 03:53 AM
