Old 10-01-2012, 09:36 PM   #225
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
epic fix. <3
Jesse is offline   Reply With Quote
The Following 2 Users Say Thank You to Jesse For This Useful Post:
Sigh-on-Rice (10-02-2012), TennisHsu (10-02-2012)
Old 10-02-2012, 02:18 PM   #226
TennisHsu
TennisHsu's Avatar
Drives: 2013 Whiteout MT Scion FR-S
One week update- still no ticks/pops, lube it up!
TennisHsu is offline   Reply With Quote
The Following User Says Thank You to TennisHsu For This Useful Post:
Old 10-02-2012, 02:21 PM   #227
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Nice! Mine is 11 days 0 pop.
Sigh-on-Rice is offline   Reply With Quote
Old 10-02-2012, 05:38 PM   #228
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Mine is in the shop taken apart right now. The Subie tech noticed it right away and apparently had another tech driving it around with him in the trunk, lol. Well I've got a Forester for the night so I really hope it snows...then melts tomorrow before I pick up the BRZ.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
The Following User Says Thank You to NYC BRZ For This Useful Post:
Old 10-03-2012, 08:02 PM   #229
sieeegel
Drives: rsx was stolen :(
well... the noise is back. Only 4 days after lubing it up with WD-40, although the noise isnt as pronounced as it used to be, but its definitely back. Ill lube her up again later.
question:
do you spray the wd40 deep inside the 2 beams or just near the little opening where the two metal pieces are seperated
sieeegel is offline   Reply With Quote
The Following User Says Thank You to sieeegel For This Useful Post:
Sigh-on-Rice (10-03-2012)
Old 10-03-2012, 08:12 PM   #230
dsgerbc
Drives: BRZ(sold), STI
I drove with rear seats down today, dropping off some wheels to be sandblasted. Didn't hear a tap. I'd suggest a different spray and spraying deep too.
dsgerbc is offline   Reply With Quote
Old 10-03-2012, 08:12 PM   #231
Sigh-on-Rice
question:
Oh noes! That's not good.
I sprayed at the opening. I did not put the WD-40 spray tube deep inside. But I sprayed a lot until it started to drip and I believe I saw some coming out from the space by the upper panel. So far, mine is no pop for 12 days.
Old 10-03-2012, 08:22 PM   #232
anteater86
Bo Ding!!
Drives: 2013 FR-S/Asphalt AT
question:
I would use something more substantial than WD-40, like a grease type lubricant, silicon, etc..
Good luck!
anteater86 is offline   Reply With Quote
The Following User Says Thank You to anteater86 For This Useful Post:
Old 10-03-2012, 08:27 PM   #233
Sigh-on-Rice
Good luck!
Yes, my plan was to try White Lithium Grease if WD-40 didn't work. The original owner who thought of this fix used silicon. Maybe sieeegel can try one of those 2 instead of WD-40 and see how it goes.
Old 10-04-2012, 05:47 PM   #234
irxproductions
irxproductions's Avatar
Drives: 2013 FR-S, 2015 Speed Triple
Hi everyone, super-big update time with GOOD NEWS from my recent dealer visit!
On Tuesday, I took my FR-S into the dealership to have the following issues reviewed: the chirp at idle, the A/C idle, the rear deck tapping, and buzzing in the passenger door (door panel vibrations).
Problem #1 Idle Chirp
The dealer had the local Scion rep on-hand to investigate the chirps and determined it was the high pressure pump shaft chirping. They replaced the pump, manifold, throttle chamber, fuel delivery pipe, and fuel pipe (basically, the entire system). This fix eliminated the chirp (though we've got to give it a few hundred miles to see if it rears its head again).
BTW: I got a glimpse of the dealer's copy revealing over $2,000 in parts for the fuel system replacement. This is quite the goldmine for your local dealer (they get paid from Scion for these repairs).
Edit: This is the repair from the newly-released TSB.
Problem #2 A/C Chirp
The fuel delivery replacement also remedied the A/C chirp (where the car would emit a loud single chirp every 15-20 seconds when moving with the air conditioning on).
Problem #3 Passenger Door Buzz
In a first, ever, for a car dealership (for me, at least), they tore down the passenger door and reassembled it with additional soundproofing foam. It is as tight as a drum, now. Excellent work!
Problem #4 The Rear Deck Tapping
The moment you've been waiting for:
Diagnosis - direct quote from the dealer docs: "Noise caused by rear deck cross member spot welds and panels shifting causing popping-type noise. Excessive spot weld slag rubbing on panels internally. Inspect trunk body seam spot welds, OK. Inspect quarter body seams and spot welds, OK.
Roadtest confirms noise. Remove rear interior deck cover, and third brake light assembly. Adjust rear deck cross member spot weld seams on upper and lower section. Apply HHS-K to all adjusted spot weld seams and panels. Roadtest on various road types - noise is gone."
And they're right! The noise IS gone. In layman's terms, they re-welded (so not a word) some spot welds and applied HHS-K, a high-pressure lubricating oil. Similar to our home remedy fix of white lithium or silicone grease, this did the trick. For the moment, the noise is gone.
I've only had the car for a day, but I can say that it is the most silent it's been since I've gotten it. My recommendation - if you can, try and schedule your appointment so the local Scion regional representative can be on-hand.
P.S. I'm still waiting on the ECU for the Daytime Running Light delete. When they say "back-ordered," they really mean back-ordered!
irxproductions is offline   Reply With Quote
The Following 5 Users Say Thank You to irxproductions For This Useful Post:
Marrk (10-05-2012), SF-FRS (10-04-2012), Sigh-on-Rice (10-04-2012), WazzuGrad (12-30-2014), zoomzoomers (10-05-2012)
Old 10-04-2012, 07:17 PM   #235
Sigh-on-Rice
Nice to know that idle chirp TSB would get rid of the A/C "ting" noise too. Mine's getting louder and louder. In a covered parking lot, it sounds like I hit a metal pipe with another metal pipe. It's loud enough to draw people's attention who are like 5 car length away and it's embarrassing. "TING!!!"
It's nice to hear that they took care of your rear deck noise. And thanks for the good news.
Old 10-04-2012, 07:39 PM   #236
Derrick
Derrick's Avatar
Drives: FR-S Raven
wowoww, this just happened the other day for me, and i just stumbled upon this thread! thanks for the information! will get this done asap because its been bugging me
Derrick is offline   Reply With Quote
The Following User Says Thank You to Derrick For This Useful Post:
Old 10-04-2012, 08:12 PM   #237
JohnS_Rosamond
Drives: Mazda MX5
I don't own this car yet, but I was wondering.... Could you pop rivet the two pieces of tin together rather than spray lube or hammering welds? Please forgive my ignorance if this is a dumb idea.
JohnS_Rosamond is offline   Reply With Quote
Old 10-04-2012, 08:40 PM   #238
Sigh-on-Rice
That might work, but I don't know if anyone is willing to create new holes to try it.
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
