Old 04-24-2019, 11:47 AM   #225
Ashikabi
Ashikabi's Avatar
Originally Posted by spitfire481 View Post
controlling an auto trans beyond something like a 2jz a340 trans would take a ton of development time. Firmware for the a340 is almost finished from what i have heard.
How do they do it on cars like the GTR? Is that a separate computer that is native to the chassis?
Old 04-24-2019, 12:04 PM   #226
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
hundreds of hours of R&D and a high demand
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
wparsons (04-24-2019)
Old 04-24-2019, 12:25 PM   #227
Ashikabi
Ashikabi's Avatar
Right but they are just programming a standalone to run it then right? I'm not arguing that you should do it for this chassis, I'm just curious now
Old 04-24-2019, 12:35 PM   #228
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
From what I have seen, they communicate with the factory Transmission controller. Same for the BMW DCT Syvecs works with.
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
Ashikabi (04-24-2019)
Old 04-24-2019, 02:33 PM   #229
BirgeyT1
too soon jr
BirgeyT1's Avatar
Drives: 2014 Sterling Silver BRZ Limited
That is correct. The factory TCM is still utilized on the GTR when running Motec.
T1 Race Development
ID Injector Dynamics
BirgeyT1 is offline   Reply With Quote
The Following User Says Thank You to BirgeyT1 For This Useful Post:
DustinS (04-24-2019)
Old 04-24-2019, 02:40 PM   #230
Ashikabi
Ashikabi's Avatar
Are most Auto transmission controlled this way? How much do they have to talk to the ECU?
Old 04-24-2019, 03:36 PM   #231
Reamer
Drives: 2015 FRS
Seems to vary a bit. The FR-S transmission is controlled by the ECU, but Porsche (at least back in the 996 days) had a separate TCM (transmission control module).
Sent from my Pixel 2 using Tapatalk
Reamer is offline   Reply With Quote
Old 04-30-2019, 06:51 PM   #232
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
wanted to bump, any updates regarding the motec?
pgranberg11 is offline   Reply With Quote
Old 05-01-2019, 12:16 AM   #233
spitfire481
Drives: 2JZ FRS
We have the first finished harness. Still waiting on the first production oil pan before we can do anything else
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
Draco_PR23 (05-03-2019), pgranberg11 (05-01-2019)
Old 05-01-2019, 12:45 AM   #234
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
What else is planned?
A reversible manifold is needed, but I think I have seen Skunk2 manifolds that are in a reversed position or designed to be in the opposite direction.
There are already k24 to s2000 transmission adapters.
Intakes are fairly universal.
Old 05-01-2019, 09:20 AM   #235
spitfire481
Drives: 2JZ FRS
We used the skunk 2 reversed. Only issue with it is that you have to use an electric water pump because of clearance with it reversed
Our header has been jigged up for production
Oil pan in in process again, after the last shop that was doing it for us vanished after 4 months of doing nothing
This harness should be the final. at this point we just need the oil pan so we can put the car back together in a running state to make the basemap file
MoTeC
Build Thread
@spitfire481
Draco_PR23 (05-03-2019), Irace86.2.0 (05-01-2019)
Old 05-01-2019, 09:42 AM   #236
Ashikabi
Ashikabi's Avatar
Why doesn't the stock oil pan fit? Can you just do a quick and dirty "cut a chunk out and weld it back closed" kinda deal to get moving again?
Old 05-01-2019, 10:46 AM   #237
spitfire481
Drives: 2JZ FRS
the sub frame is in the way. and its not just a little, its a good bit. we had to take a large section out, box it in, then add more to the sides to get the oil volume back up. also requires a modified oil pickup tube. We are basically having oil pan flanges cut, and the whole pan has to be built from scratch
MoTeC
Build Thread
@spitfire481
Old 05-01-2019, 11:04 AM   #238
Ashikabi
Ashikabi's Avatar
Maybe someone like Canton or Moroso would be able to make one for you, wouldn't be that different from what they already do.
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! Pure Automotive Engine Swaps 29 01-10-2018 02:20 AM
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap Pure Automotive Engine Swap 0 12-01-2017 12:57 PM
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 12:49 PM
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 12:23 PM
Pure Auto's 2JZ Swap Thread - The DRAGFRS Pure Automotive Engine Swaps 153 06-20-2016 07:33 PM
