Old 12-10-2016, 01:51 AM   #225
celek
Resident Gear Head
celek's Avatar
Originally Posted by CounterSpace Garage View Post
There are off the shelf header available to take on this endeavor, but it is severely dependent on what type of powerband is being used. For example, the ACE A-350 maximizes the factory FA20 powerband extremely well offering the best overall power delivery out of all the ACE headers, the A-250 shifts the optimal powerband slightly north, the CS400 shifts the optimal powerband down, etc. At that point, we need to know exactly where you are planning to use the power and where you are willing to give up before making a recommendation. Thank you!
Well its a 2.3 liter stroker engine 13:1 compression and race cams
http://www.pipercams.co.uk/pipercams...d=SUBFA20BP320
I believe the power band down low will be fine with the compression and larger stroke. I need it to breath up top
celek is offline   Reply With Quote
Old 12-12-2016, 01:41 PM   #226
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Originally Posted by gramicci101 View Post
I had been thinking A350 or Anaconda 42.7mm, with the Anaconda 48mm if he really needed the ability to move a lot of exhaust gas. 9500 RPM is far enough outside the realm of normal usage that I can't even guess at his requirements. You guys are the experts though.
Anaconda 48mm is based on fairly specific parameters. If you are interested in that realm, we can have you fill out a form to identify whether or not the 48mm is good for you.
Originally Posted by Summerwolf View Post
What is the powerband of the Ace 150 then?
Shifts the powerband north the 250. The collector design shortens the "2" section and lengthens the "1" section in the 4-2-1 header. For reference, we have posted up a video of an owner in Korea running an A-150 doing 8k pulls on track.
All based on the type of scavenging characteristics and needs. While it can breathe to 9500RPM, what about usability and application? The Synergy V8 runs to 11000RPM, but it looks like a slug coming out of corners due to lack of torque. We'll discuss when you're ready to order. Thank you!
CounterSpace Garage is offline   Reply With Quote
Old 12-12-2016, 05:34 PM   #227
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Lightbulb
Originally Posted by nikitopo View Post
I don't think you'll notice anything with a drop in filter. A real waste of money. Personally, I didn't notice any improvement.
So I've read a few things on here in regards to drop-in K&N ( bolt on upgrades sticky thread) or TRD , vs going with a full out ($350+) CAI system.
So what is the consensus ? Is it possible to go K&N drop in, and rig up the snorkel air inlet system so it's sucking in colder air from outside the car ?
Thanks in advance
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 12-12-2016, 05:39 PM   #228
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Most NA mods won't provide significant gains without a custom tune.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
Adam_L (12-12-2016)
Old 12-12-2016, 05:40 PM   #229
gramicci101
Off Topic
Thanks in advance
A drop-in filter is all you really need. It's already pulling air from the mouth of the bumper. The OEM intake is very very well optimized. Most of the CAIs "make" power by leaning out the AFR, which is bad. The one that doesn't is GrimmSpeed. They have a thread covering the development and testing of their intake, and they did a great job with it. If you really want an intake and you're not going to get a tune to address the AFR issue, get a GrimmSpeed intake. Otherwise, get a drop-in filter and call it a day.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
Adam_L (12-12-2016), GrimmSpeed (12-13-2016)
Old 12-12-2016, 05:53 PM   #230
Somerandom18
Drives: 2017 manual BRZ
Anyone know a drop in that fits the 2017 /w manual trans yet?
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 12-12-2016, 06:06 PM   #231
Adam_L
Adam_L's Avatar
@Somerandom18 : it should be the same as '13-16 model years.
Thanks for the input you guys. I've done some research into this, but yeah sounds like a drop in is best overall cost/benefit ... ROI . Thanks again for cutting the crap out (filler) , and getting to the heart of the matter.
Old 12-12-2016, 06:11 PM   #232
gramicci101
Off Topic
Here's some reading material for you, detailing testing of the OEM intake with factory and modified snorkels, aftermarket filters, and design of the GrimmSpeed intake.
http://www.ft86club.com/forums/showthread.php?t=56358
http://www.ft86club.com/forums/showthread.php?t=56341
http://www.ft86club.com/forums/showthread.php?t=78902
The Following User Says Thank You to gramicci101 For This Useful Post:
Adam_L (12-12-2016)
Old 12-12-2016, 06:18 PM   #233
Hawk77FT
Drives: GTS 86
Same drop in that fits the 2013-2016! Nothing special really
Hawk77FT is offline   Reply With Quote
Old 12-12-2016, 08:22 PM   #234
Adam_L
Adam_L's Avatar
Next quick question, Intake related . On the new '17 red intake manifold (trying to find the thread on here that outlines the '17 changes) , has anyone done any tests to see what kind of (real world) bump in hp/torque changes there are by adding this to your FR-s /BRZ ?
http://www.ft86speedfactory.com/suba...l#.WE858NIrLcs
Old 12-12-2016, 09:09 PM   #235
Somerandom18
It's not. The filter design was changed for 2017 manuals along with various other parts of the intake.
Old 12-12-2016, 10:32 PM   #236
Hawk77FT
Drives: GTS 86
Same filter size though! So replacing it with the same aftermarket filter used for 2013-2016 should not be a problem.
Old 12-13-2016, 12:56 AM   #237
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Does the drop-in-filter filter as well as oem? Best of luck finding information on this. It may be the drop-in-filter is high tech and removes as much particles as oem but who knows? It is also possible that less filtration only makes itself known after 200,000 kilometers. I am suggesting filtration is inversely proportional to air flow. I am not saying you don't get a drop-in but you know, compromise.
You might like to get an used oil analysis done to see how the drop-in is working.
My car has only has 46,000 kms on the clock but has had 4 oem filter changes just because.
Old 12-13-2016, 03:06 AM   #238
churchx
churchx's Avatar
Drives: 2014 GT86
One can get more air flow even with same filtration, if eg. filter's filtering area is larger then that of stock (by eg. more and higher folds or bigger box/filter itself like in TRD intake). I've also heard that oiled filters can filter better if of same resistance then dry ones.
Of course it's also possible for some aftermarket filters to decide on different filtering/flow compromise sacrificing former for later.
The Following User Says Thank You to churchx For This Useful Post:
Captain Snooze (12-13-2016)
Recommended cheaper power gains mods emishor86 Scion FR-S / Toyota 86 GT86 General Forum 38 03-27-2016 09:49 PM
POWER Mods for NA setup NYCsubaruBRZ Engine, Exhaust, Transmission 61 02-17-2016 10:19 AM
Mods to reduce drivetrain power loss? FRSW12 Engine, Exhaust, Transmission 31 12-28-2015 06:10 PM
Easy mods for power and sound. LWAA BRZ First-Gen (2012+) — General Topics 40 09-13-2015 10:20 PM
More Power VS. other Performance Mods Darryljr11 Mid-Atlantic 38 08-11-2013 09:53 PM
