Old 12-14-2016, 07:06 PM   #225
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
So what has actually happened?
Scrappydoo is offline   Reply With Quote
Old 12-17-2016, 06:42 PM   #226
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Originally Posted by norcalpb View Post
What is the size of the stock rear sway bar on your '17?
Curious about this as well
NLSP is offline   Reply With Quote
The Following User Says Thank You to NLSP For This Useful Post:
stock (12-17-2016)
Old 12-19-2016, 02:07 AM   #227
TkTk
TkTk's Avatar
Drives: 2014 TRD GT86 CUP, 2014 991 GT3
Ace A/350 and Anaconda xfire
So what works better for you?
TkTk is offline   Reply With Quote
Old 12-20-2016, 03:31 PM   #228
.RYAN
AWOLBRZ
Drives: 2017 BRZ
Besides oem, what front pipe have you run? Ace?
.RYAN is offline   Reply With Quote
Old 12-29-2016, 03:28 PM   #229
I have an Ace front pipe, but am currently using OEM to keep the car quiet while I putz around town!
Old 01-05-2017, 08:49 PM   #230
gtengr
Drives: 2017 BRZ
- I much prefer the output of the 2013's HIDs, to the 17's LEDs. The HIDs could be leveled manually, whereas the LEDs are fixed height. The factory aim is legal, but on the high side, and regularly blinds drivers on the other side of the road. I've quite frequently been high-beamed by a driver at an opposing stoplight, who thinks I have my high beams on.
I've found this to be a problem too. Anytime I'm on a cresting roadway profile it will aim high at approaching traffic. I hope some sort of patch is eventually offered.
gtengr is offline   Reply With Quote
Old 02-18-2017, 06:01 AM   #231
steve99
@CSG Mike
what sort of gain did you get from stock to ace header on e85 with the 2017
is the peak power better than earlier cars, and how does it compare to earler cars power delivery, ie does the new manifold make much difference na on tuned car ?
is their less gain over stock with the 2017 due to the better stock header better air filter intake tube manfold and the stock tune seems better ( doent run super rich top end)?
does this result is less gains available na as your starting from a better baseline
driggity (02-18-2017)
Old 03-06-2017, 03:53 PM   #232
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I literally eyeballed it at the track. My normal alignment shop would have a heart attack if they knew what I did, but they couldn't squeeze me in. I got the car back Thursday evening, installed an oil cooler, changed all the fluids, and headed out to the track. Ghetto alignment at the track friday (eyeballed), installed pads, flushed brake fluid, then drive 6 hours to another track Saturday for 86CUP...
My guess would be around -3.5 to -4 camber. Toe was eyeballed to 0, as was toe. Friday was used as a shakedown to determine "more or less" with alignment and pressures for Saturday. The picture is from the end of Saturday. This was done with a floor jack, a few wrenches, and a set of allen keys, and a tape measure.
This is just temporary.
I believe this is the most evenly chunked set of stock tires I've seen.
Mike, Are you running this camber on the street also?
Lunatic is offline   Reply With Quote
Old 03-06-2017, 08:36 PM   #233
Yes; I've never run less than -3 in the front, except when the car was stock.
dowroa (03-06-2017)
Old 03-06-2017, 09:06 PM   #234
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
On Subaru's (with the aid of camber plates and crash bolts), I have always ran around -3 degrees since I realized how much dynamic negative camber our cars lose up front.
Even tire wear.
- brian
dowroa is offline   Reply With Quote
Old 07-26-2017, 06:19 PM   #235
Lust
Drives: 2017 Subaru BRZ
Any updates?
Lust is offline   Reply With Quote
Old 09-10-2019, 12:03 AM   #236
Randoman5
Oh noooo. Just found this. Had such high hopes.
Randoman5 is offline   Reply With Quote
Mad Mike's Firestorm Build Mad_Mike Member's Car Journals 83 03-14-2025 01:16 AM
My thoughts on my build (Down South in Africa)! 86 South Africa Member's Car Journals 2 02-02-2016 08:55 AM
Mike&Ikes WRB Build Mike&Ike Member's Car Journals 8 09-18-2015 04:12 AM
Mike Mac's Raven FR-S NYC Build ScionFR-S Member's Car Journals 5 06-07-2014 02:49 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 10:11 AM
