Sam Strano
Old 03-12-2015, 11:18 AM   #2353
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Originally Posted by Shark_Bait88 View Post
The lack of contingency for the ZII* has me a little disappointed in my choice, as does the trend of everyone "in the know" going with 245/40 RE71Rs. :/ Thought about calling TireRack to switch my order, but I figure I might as well stick it out and see how the Star Specs perform. Given all the data I've been seeing from you guys, it looks like they're very close. My driver mod is going to be a bigger factor anyways.
Side note, anyone planning on running the Wilmington Prosolo in May? This is going to be my first national event and I'm really excited for it!
If you're still working on your driving, and showing up to the first national event, there's really no point in worrying about contingency. Remember all of this tire variance bullshit is about 1-2% of the overall success of the full equation, with driving still being 85+% of the process.
235/40/17 Dunlop ZII's took the fastest time of I think 23 twins at 2014 nationals, so even with newer tires this year, they can't be that slow. I think you'll be fine. The same tires were on my car all winter long, and may be on my car again at the Wilmington pro. I'll see you there.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
The Following 3 Users Say Thank You to SeanRTR For This Useful Post:
AustinTX (03-12-2015), Jawnathin (03-12-2015), Shark_Bait88 (03-12-2015)
Old 03-12-2015, 11:25 AM   #2354
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Anybody here attending the Jersey pro?
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 03-12-2015, 12:21 PM   #2355
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Agree 100% (if not higher on the 85 ) The CS fields are generally large and can be really tough. Contingency isn't a factor for the vast majority, but if the 'shiny new thing' starts winning, there is likely to be a follow the leader effect.
If I were ordering today, I'd almost definitely go with the 235 ZII*, but since I don't have a meaningful event until May, I can wait a while longer and see if we get any real info (besides some anecdotes and one preliminary tirerack test).
... anyone planning on running the Wilmington Prosolo in May? This is going to be my first national event and I'm really excited for it!
I'm in for all 3 OH Pro's (package deal) and just registered for NJ last night as well.
jdrxb9 is offline   Reply With Quote
The Following User Says Thank You to jdrxb9 For This Useful Post:
Old 03-12-2015, 12:28 PM   #2356
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Sweet, CYA there. Looking at the class so far it almost looks like a spec class lol
Old 03-12-2015, 01:22 PM   #2357
jonesy
jonesy's Avatar
Drives: 2010 Corvette GS
Signed up for Jersey, Lincoln, and Wilmington #1 (would have done #2 instead of Lincoln but I registered 7 minutes after opening and it was sold out).
Planning on doing the MSNE event this Sunday and the NNJR/PCA event on April 4th at Metlife. Running my old compound Z2s until there is a verdict on the new crop of 200TW tires. Can't wait to get out again, it's been a long winter!
Matt
#73 GS Focus ST/#82 STX BRZ
jonesy is offline   Reply With Quote
Old 03-12-2015, 01:24 PM   #2358
vroom4
Whos going to dixie?
vroom4 is offline   Reply With Quote
Old 03-12-2015, 07:33 PM   #2359
Jawnathin
Drives: Toyobaru FRZ
Originally Posted by jdrxb9 View Post
I don't think it's that any size has a big gearing advantage - more like the actual time over distance differences are small when you on the limiter with one tire vs another and those small differences are offset by the improved accelerations elsewhere.
Apologies in advance for the wall of text
I think we're on the same page, though maybe we value or weigh the findings a little differently. What I was trying to say is that the acceleration advantage you get from the shorter 235/40 isn't offset by the higher MPH you get from the 245/40. I figured what is better would sway one way or another depending on the course, but even on a course where I thought the 245/40 would have an advantage it ended up as a wash. On a course where you're never on the rev limiter or have to get into 3rd, the 235/40 will be slightly quicker on every acceleration zone than the 245/40 and the 245/40 never gets a chance to 'reel it back in' up top.
The sentiment from some folks around here believe the advantage isn't notable. Sure, I get that it isn't large, but my position is that I'll take any advantage I can get and I would expect every competitive autocrosser to do the same. Using the math from your ProSolo data, extrapolated from a 37~ second course to a 130~ second course (top CS combined time at Nationals) it ends up being a little over a tenth. Lots of trophy, contingencys, and positions have been split by a tenth before and people spend far more to get less than that. I spent $200~ on a single exit exhaust to save 20lbs that I'll never be able to feel or quantify the benefit. I know it won't account for much while out on course, but again I'll take any help I can get
The counter point as I've understood it is that you can exit a corner faster on a 245/40 than a 235/40 due to the additional width and would negate any acceleration advantage you'd get with the shorter tire. But I'm not so sure the 245/40 is going to give you any more usable tire than a 235/40. The benefit of the additional width is a little harder to quantify so I'm not sure we can solve it on this thread, but these are still 9" wide tires on 7" wheels. The larger width will give you 5mm on the outside and 5mm on the inside, but the tires curl up about an inch on each end due to being pinched so contact patch while not loaded up is going to be the same. While cornering you'll certainly lean and use the outside shoulder, the inside shoulder is practically untouched. Even after 300 runs, my inside shoulders looked new. So at the very best, we get an additional 5mm and that assumes the middle/inside of the tire continues to make as much contact as a 235 when rolling onto the shoulder during a hard turn. Similar to my thoughts on the acceleration advantage, I'll take all the help and tire I can get, but what you get here is questionable while the benefit of a shorter tire is quantifiable. Plus as you mentioned, a lower CG and stiffer sidewall. In the end I think there is a advantage to one tire size or another depending on the courses that you run, but there isn't an obvious one size fits all choice here.
Don't look at what I say as disagreement on the findings or observations, but rather acknowledgement that we both understand what is happening and we just happen to approach it a little differently. I appreciate the time you took to look at it. The top two 86s at 2014 Nationals were on 235/40 and 245/40, so we know in practice that they're competitive with each other.
And this may all be moot - if the current RE-71R hype holds up (not to mention the upcoming Rival S), I think the 235/40 ZII (with no contingency) will be really unpopular and almost everyone will be on 245/40-17's anyway
Agreed and the lack of contingency is what swayed me away from moving forward with the Dunlops. I think the compound is fast enough, the Z2 was very competitive with the RS3 v2, and I'd have to hope the Z2* is better than the Z2. My delusions of grandeur has me thinking contingency programs will actually matter for me this year, but I'll take a shot at winning $250 instead of guaranteed $0.
I'm running 245/40 because my hand was forced with the tire I wanted to run. 235/40 wasn't an option, but when I was considering the Z2*, I was truly undecided between the 235/40 and 245/40. The Rival S, Kumho V720, and 200TW R1Rs are all going to be very interesting contenders too. I hope the RE71 lives up to its hype, because I ordered a set of them
235/40 Z2* is a great tire and very capable of winning an event, even on a national level. If you still have the opportunity to switch tires, then give them a call if something else catches your eye, but if you can't or don't want to, I wouldn't be disappointed with that choice at all. All of these next gen tires are VERY good and this might be a case of 'grass is greener'.
Congrats on making it to your first national event, it is great to get an opportunity to compare yourself to the best drivers in your region. Signing up for a Pro or NT is a big step forward and you'll have a blast.
Great points here. Z2s were excellent tires, the Z2* should be even better. All of these new tires are great, so its not like you're bringing a knife to a gunfight, you're just bringing a different kind of gun.
Jawnathin is offline   Reply With Quote
The Following User Says Thank You to Jawnathin For This Useful Post:
Old 03-12-2015, 09:50 PM   #2360
bslate3
Drives: 2015 CWP BRZ
Who all is going to the College Station Champ Tour?
I'm looking forward to meeting those that will be there.
Also I think there is an autocross there the weekend before. That would make for some great setup testing.
bslate3 is offline   Reply With Quote
Old 03-12-2015, 11:25 PM   #2361
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Thanks! Yeah, I don't have any particular reason to switch other than being indecisive and somewhat looking to follow people's lead. I'm gonna stick to my guns though, as I've heard nothing but good things about the Star Specs so far. I'm really excited to race a national event this year, and should hopefully get at least one more in apart from Wilmington. This is going to be my first year running a full season of autox (my experience extends to 3 events I did in the FR-S late last year).
Also looking forward to publishing about my experiences and everything I learn this season on builraceparty.com. I will link you guys to some of the articles once I start writing, first one should be going up in the next couple weeks.
And yes, I am a shameless self-promoter. haha
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
Jawnathin (03-13-2015)
Old 03-13-2015, 12:49 AM   #2362
YawMomentRacing
YawMomentRacing's Avatar
Drives: 2013 Red 6MT Scion FR-S
I will be there and it'll be my first National event in the FR-S....pretty different from my previous car but I'm Looking forward to it!
Dave Ogburn | Yaw Moment Racing
2013 Scion FR-S - C-Street
http://yawmomentracing.blogspot.com/
YouTube Channel
YawMomentRacing is offline   Reply With Quote
Old 03-13-2015, 09:22 AM   #2363
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
In for the CS champ tour. Not gonna make the event before, though.
Autocross nut
AustinTX is offline   Reply With Quote
Old 03-13-2015, 09:57 AM   #2364
chucky12012
Drives: 2013 Asphalt Scion FR-S
I'll be there too. Looking forward to trying out the new setup for my FR-S. Should be a good early benchmark with some fast cars and drivers.
chucky12012 is offline   Reply With Quote
Old 03-13-2015, 11:27 AM   #2365
jonesy
jonesy's Avatar
Originally Posted by Arigh View Post
Pretty psyched for the NJ Pro Solo, it'll be my first national event, and this year is the first year I'll ever be at full prep in a car. Last year I just had ZII's on stock rims, strano bar, and camber bolts.
Rochester huh? Grew up there and went to RIT. Used to run w/ the WNY/FLR folks before I moved to DC. See you at NJ...
Matt
Old 03-13-2015, 02:52 PM   #2366
jonesy
jonesy's Avatar
You'll see a bunch of people from there, last I counted we have around 15 people signed up for it from FLR/WNY
Ha yeah I actually noticed that running down the registration list. I think there were only a handful or so that did national events back when I ran up there (I was not one of them, as I always had some underprepped 240sx in SM or DSP on street tires).
Matt
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
