Old 10-18-2013, 05:22 PM   #2297
fenton
Originally Posted by bfrank1972 View Post
Once again impressive results! I'm not 100% a fan of actual whp numbers from dynos, especially with significant atmospheric correction, but I did some % diff numbers according to your baseline - were all those runs done at the same time/dyno?
I see you are using the dynojet numbers. The numbers we got last night with Toma are even better. Stock HP 165 and boosted 207.
Stock torque in the dip 105.... Boosted 190
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
DAEMANO (10-18-2013)
Old 10-18-2013, 05:35 PM   #2298
bfrank1972
Drives: 2013 FR-S Argento
Very cool - if anything I just wanted to show what this thing really was all about - peak gains are darned good, but just look at those percentages between 3000 and 5500 rpm!
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
fenton (10-19-2013)
Old 10-18-2013, 05:44 PM   #2299
Robftss
Drives: VW
On the dynojet we ran all boosted runs...removed the compressor and installed the stock intake. ~ 5 mins apart.
Robftss is offline   Reply With Quote
Old 10-18-2013, 05:47 PM   #2300
fenton
Keeping in mind the dynojet tq300 compressor numbers were untuned and after last night we added a lot more in the mid range and top end in relation to the baseline
Old 10-18-2013, 05:52 PM   #2301
fenton
Originally Posted by Gary in NJ View Post
It does go lower. The AFR I gave before was where I engaged the ESC at 3000 to 3500 rpm.
I had to run some errands, and with this on my mind I thought I'd take a closer look at my AFR's.
Engaged the ESC @ 2000 rpm and the AFR went to 11.2. As I passed 4000 I saw it climb to 11.8. At 5000 it was at 12.2 and it stayed there until redline. I did several similar runs and got the same result.
I don't consider these too rich. It is my understanding that the target AFR at WOT (boosted) is ~12.0.
Under normal load my AFR's are running 14.5 to 14.7.
You're better off than me then. My bottom end drops out of the narrowband o2 range on the onset of boost and after last night it climbs out at about 4200 rpm that's why my tq numbers just up so much there. Imagine if I could get leaner numbers before 4000 with this comp!
Old 10-18-2013, 07:49 PM   #2302
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
I'm not a pro by any means but I've always aimed for mid 11's. 12 point anything would make me a bit nervous.
SloS14 is offline   Reply With Quote
Old 10-18-2013, 08:34 PM   #2303
fenton
Not in this engine it shouldn't. All the boost turbos and supers run 12.5.
I agree I used to be scared because I come from a STI where rich was good and lean was death.
So is not the case with the fa20
SloS14 (10-18-2013)
Old 10-18-2013, 10:21 PM   #2304
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
What AFR's are you running?
I have to tell you, Moto-Mike didn't struggle at all dialing in my AFR's. In my 2 hour tune session he spent 75% of the time working on and eliminating knock. I was amazed how quickly he was able to dial the ESC in. This was probably a combination of his experience tuning boosted FA20's and his tools (ECUtek).
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 10-18-2013, 11:28 PM   #2305
fenton
Currently 10.5 below 4000 and 12.5 above.
Toma was not able to get the low end Afr to come up.
Don't get me wrong I still make great torque 175(3000) on dyno dynamics but if we could dial in the afrs down low I think it would be even better.
The larger charger sees 160g/s down low 3000 to 3300 which is the same as it sees by the time it makes it up to 7000 rpm.
Old 10-19-2013, 09:41 AM   #2306
Gary in NJ
Gary in NJ's Avatar
Is that value from the ECU? Given how overwhelmed the MAF is at low rpm/high boost I don't think the value can be trusted.
I haven't paid much attention to grams/second, but I'll make a point to observe and I'll report back.
Old 10-19-2013, 10:08 AM   #2307
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
So exactly what setup made that latest dyno graph? Really interested again!
Old 10-19-2013, 11:06 AM   #2308
fenton
4.5 kW charger, still in development, on a dyno dynamics.
The car is completely stock except a brzedit tune and the ESC.
The 4.5kw one is proving hard to tune so we are working through that right now.
Old 10-19-2013, 11:11 AM   #2309
fenton
The stock exhaust really holds back this charger on the extreme top end however. Lots more testing required on the 4.5kw
Old 10-19-2013, 12:03 PM   #2310
fenton
That's what we though but Toma didn't think it was a false reading because bit was a smooth curve.
Let me know what you get from 2k to redline.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
